The following directions will help you decode your 2002-2006 Nissan Altima's Service Engine Soon (SES) light and reset it.<br />
<br />
<span style="font-weight: bold;">Obtain The Trouble Code</span><br />
<ol>
<li>Turn the ignition key to the ON position and wait three seconds.</li>
<li>Put the accelerator pedal to the floor and release it five times in less than five seconds.</li>
<li>Wait exactly seven seconds. Put the accelerator pedal to the floor for ten seconds until the SES light flashes.</li>
<li>Release the accelerator pedal and start counting flashes to obtain the four-digit trouble code.<br /></li></ol>
<ul>
<li>Long flashes (0.6 seconds) indicate the first digit of the code; count
the blinks one through nine and write down the first digit. (Ten blinks
indicates a zero.) </li>
<li>
The next three digits blink
faster (0.3 second) and have a 1 second pause between digits.</li>
<li>The ECM code repeats until you turn the ignition key to the OFF
position.</li>
<li>You can look up the trouble codes in the Service Manual.</li>
<li>If you get four blinks of ten, or 0000, the ECM indicates no malfunction.<br /></li></ul>
<br style="font-weight: bold;" /><span style="font-weight: bold;">Clear The Trouble Code</span><br />
<ol>
<li>
Clear the code and the SES light by holding the
accelerator pedal down to the floor for 10 seconds or more while the SES light is
blinking.</li>
<li>When the pedal is released, the ECM will erase the trouble
code(s).</li></ol>
check all fliud levels antifreeze/oil/power steering/ transmission/even washer fluid.. as some have level switches on them.. these will cause your light to activae also..
IF you are absolutely certain YOU know why the light is on ... and there is no other reason ... you can probably have this code cleared by someone with a SCAN tool ... expect to pay for the service ... and probably pay near what it will cost to repair the problem. When the mechanic clears the code, he or she will have to get enough money to "recover" when you come back in a few weeks and say HE or she DID IT AND NOW MY CAR WILL NOT WORK.
theres nothing wrong with the fuel pump..did you test the mass air floww sensor or have the egr valve replaced..it will save you trouble from keeping your 2002 nissan altima from dying out.
If the light was flashing when it came on, then it means your engine is misfiring.
A solid light can mean anything from a loose/faulty gas cap to a transmission issue.
This
light comes on when the computer detects a
fault of some sort in its diagnostic tests. If it keeps detecting this
issue, the light will remain on. If the light turns off, then it has
detected that the issue may no longer be present.
In
order to find out what the exact reason was for your light, You need to
have your car computer scanned to retrieve the code that
the computer would have stored when the light triggered. Most garages
will do this free of charge. The code will tell you what may have
caused the light to initially turn on.
Sounds like Crank and Cam Sensors. Had the same problem. First get the SES light checked to see what the actual problem is. IF it is the Crank or Cam sensors...it was covered in a recall a while back, you might get it for free.
