Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Won't start Vacume stopped when inflow was plugged and overheated. Will it restart?
  • bonefixr Feb 20, 2008
    Thank you. I'll give it a try.
  • Anonymous Feb 23, 2008
    My vacuum stopped working mid vacuum and won't restart. I checked for blockages but there were none. I'm still waiting for it to cool down to see if it will restart.
    President:
  • 1,673 Answers
It should after it has cooled down. But first make sure all ports are checked for blockage, including the hose. There a number of covers that will come off easily.
Posted on Feb 20, 2008
Vacuum stopped working. I think it overheated and I cleaned it out really well. Still won’t start
These days many electrical appliances are protected by a thermal fuse or breaker so overheating will cause the circuit to be broken. The thermal breaker should in theory reset itself when the motor cools but that isn't always the case in practice. The thermal fuse needs replacing when it "blows".
It might be by complete coincidence something completely different but the only way to discover the fault is to dismantle the cleaner and check the circuit with a multimeter.
Mar 03, 2018 | Vacuums
DC07 Shuts Off, won't restart
If it was running for a while... It may be overheating. It has a reset: http://www.ehow.com/how_5943288_reset-dyson-vacuum.html
But maybe just let it cool for an hour or two and try it again?
Oct 07, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Hoover vacuum cleaner is not picking up from the carpet like it used to. Like it's having difficulty picking up strings, fuzz, etc. from the carpet. Suction power seems to be fine. The belt and the...
YOUR VACUME SHOULD HAVE A HOSE THAT PLUGS INTO THE LOWER PART OF THE VACUME OR MAY COME APART AT THE BOTTOM . IT SOUNDS LIKE THE TUBE IS STOPPED UP AT THE FAN MOTOR
Jan 16, 2011 | Hoover Vacuums
My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Apr 01, 2010 | Vacuums
My bissel vacume was not picking up the dirt on the carpet. So I found that the hose was clogged. I unclogged it but the vacume still is not picking up the dirt. I also changed the filters.
I found out that if you remove the front filter holder, tip vacuum back and look down inside. Sometimes there is hair caught back in there and you won't get suction. I had to use something long, knife, very long type tweezers, to pull all the hair out. Worked great after that. About half way through vacuuming I will stop and remove the foam rubber filter and clean it. Oh yea, you will have to use a flashlight to look down inside to see all the hair caught behind the foam rubber filter cup.
Dec 14, 2009 | Bissell 6594 PowerForce Bagless Upright...
Vacuum working perfectly and everything stopped. Went to the utility room and found a plastic bag on top of the equipment. Tried the reset button, etc. nothing works.
sounds like a bad relay in the tank just a simple repair but should be done by a vacuum tech or electrician. Could be a motor is nothing is starting at all, but not as likely.
Jun 14, 2009 | Broan-NuTone CV353 Central Vacuum
Panasonic vacume#MCV573500
it is probably a thermal issue. contact any local vacuum dealer.
Aug 15, 2008 | Panasonic MC-V7355 Upright Vacuum
Vacume Overheating
There will be a filter between the cylinder/bag and the engine. If your vacuum has a HEPA filter there will be one on the other side of the engine. Remove both of these and clean them out with water, allow to dry and replace.
Jun 18, 2008 | AEG Vacuums
Oreck XL 21
My old vacume had the same problem - the wire had a 'plug' on both ends. 1 to the wall outlet and 1 to the vacume, which you could pull out of the vacume. It was making poor contact at the vacume and eventialy burned out (melted)
See if the plug/wire to the unit is removable, if so is it damaged?,
could need a cleaning, or it may not be pushed in all the way.
Good Luck
Mar 22, 2008 | Oreck XL21 Bagged Upright Vacuum
Dyson Vacume dco7
Vacume overheated when inflow was plugged. Will it restart when it cools off.
Feb 17, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
43 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
