Question about Samsung LN-S4051D 40 in. LCD Television
No picture but there is audio - Samsung LN-S4051D 40 in. LCD Television
  • 148 Answers
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this helped you (or not) please rate, thank you!
Posted on Feb 03, 2010
I hooked up my wii on av1 with a component cable with audio on audio 1 and i have sound but no picture.
If I am reading this right, you are only hooking up one cable for audio. There is another cable needed for video. This jack is normally color coded yellow and labeled video out/in. You can use your audio cable to try this and then you will picture but no audio.
Feb 16, 2014 | Yamaha RXV371
Powers on but no picture
Does the audio stay working and just the picture goes out, or does everything drop out picture and audio?
Oct 24, 2012 | LG 42LC2D 42 in. LCD HDTV
No speaker audio Magnavox plasma TV
Re check all connections on the boards that you worked on. Make sure they are tight.
Jun 18, 2012 | Televison & Video
Hdmi audio not working when conected to tv
Follow these steps to change the audio output settings for the HDMI option.
  1. Follow steps 1 through 8 above.
  2. From the Windows Vista™ default Start menu, click Control Panel.
    View Picture
  3. In Control Panel, using the default Control Panel Home setting, click Hardware and Sound.
    View Picture
  4. In the Hardware and Sound window, under Sound click Manage audio devices.
    View Picture
  5. In the Sound dialog box, click to select Digital Output Devices (HDMI).
    View Picture
  6. Click Set Default, and then click OK
    View Picture
Note: The default audio setting for your notebook is Speakers / Headphones.
You must change the audio output back to the Speakers / Headphones option for the computer to once again be able to use the internal speakers and headphone jack.
Sep 24, 2009 | Gateway T-1620 Notebook
Audio Yes, Picture No
From your description, it could be the back light has 'gone'.
Feb 16, 2009 | Sony BRAVIA KDL-40V3000 Television
Soyo dylto32c
The DVI input on this set is meant for picture only.. ex. to display computer picture.
if you want audio with your picture. you must connect to either inputs YCBCr or YPbPr which both of those inputs has audio inputs.
Mar 19, 2008 | Soyo DYLT032C 32 in. LCD Television
There audio but no picture
I don't know how you connect the unit to the tv.
Let's just start on basic:
composite video/audio(yellow-video, white/red-audio) connect to TV composite video/audio input behind the TV.
If the audio works but no picture,try to use another video input behind the tv.if that still doesn't work,use a different video cable!
Jan 20, 2008 | Toshiba SD-V392 DVD Player/VCR
No Audio on Primary Screen
HELLO . WELL THE DIFFRENCE BETWEEN THEM IS THAT THEY ARE TUNER'S AND THEY ARE SEPRATE FROM EACH OTHER.!!! JUST LIKE THE VHS TUNER'S YOU HAVE .!!! THERE IS THE PRIMARY WITCH .!!! WOULD BE (A) AND THEN THE SECONDARY WITCH WOULD BE (B) IT SOUND'S LIKE YOU NEED TO REPLACE THE AUDIO BOARD. OR THE (IC'S) ON THE BOARD. IT WOULD BE CHEPER TO DO. IF YOU KNOW HOW.? " WELL "GOOD LUCK"
Aug 28, 2006 | Sony KP-61V75 61" Rear Projection...
Samsung LN-S4051D 40 in. LCD Television Logo
407 people viewed this question
Jerry Greenberg
Jerry Greenberg
