Question about Intel Compaq EVO D500 (RBMDTCPQP42400) PC Desktop
PC will not start, fan starts to spin and it stops
Compaq EVO 500 will not start, fan starts to spin and it stops, light next to power button is red and blinking. No beeps.
  • 25 Answers
I think the problm with motherbard or fan please check
Posted on Feb 03, 2010
New build with asus M4A79XTD EVO and AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor. When you hit the power button, the fans start but...
Hello
It almost sounds like a mistake at the pc start switch and reboot switch.
Check that you have your pc start wires from the front start button of the case, in the correct spot on the motherboard.
Also remove the memory sticks and reseat them.
The green light on the motherboard is good it means your getting power from the power supply.
The start and reboot switch wiring can be tricky if one plug is in the wrong spot on the motherboard.
Feb 03, 2011 | ASUS M4A79XTD EVO Motherboard
HP Compaq Evo D310 Desktop. After connecting the mains supply to the desktop and swithing the power on, nothing happens when pressing the power button on the front of the unit. I notice there is a small...
That switch is there to select between European and US voltage - if the pc has worked before then leave it as it is. Change it to the wrong setting and the power source will be fried.
Your pc doesn't start because you have a hardware fault.  Disconnect the data cable from the hard disk and try again. Next you must test the power source itself , outside of the pc - take it out then connect the green wire from the big connector to the black wire next to it; if the fan of the source doesn't start then it's fried, replace it. If it does then you must try the other components. If you haven't done that before , or if you don't have other components to swap for testing ,  then it's time to take it to a shop, nothing more you can do to it
Aug 05, 2010 | HP Compaq Evo D310 PC Desktop
Hello my compaq evo n610c don't start with power cord & battery
1>NEEDS TO TRY RESEATING OF THE RAM(SWAP THE RAM WHILE PLACING THEM BACK IN) AND THEN TRY TURNING ON THE COMPUTER
2> IF THIS DOES NOT WORK THEN NEEDS TO REPLACE THE MOTHERBOARD
BEST OF LUCK
Feb 08, 2010 | HP Compaq Evo n610c Notebook
Compaq Evo D510 errors
the RAM may be corrupted or not properly installed into the slot. also check if the processor fan is working properly.
Nov 19, 2009 | Compaq Evo D510 PC Desktop
Pc wont boot up, instead a red light flickers.
Flickering LED means power supply is overloaded with something. It might be inside of the supply, but sometimes it is something else. Try that:
1. Disconnect everything from the motherboard except power supply and power button;
2. Disconnect all power connectors from all drives;
2. Remove any cards from the motherboard so all you have is power supply and motherboard with CPU and RAM, nothing else. You can keep connected the monitor and keyboard;
3. Press Power button. Will motherboard turn on normally?
If no - check electrolytic capacitors especially around the CPU, if some of them are "popped" replace them.
If yes - connect drives and cards one per time to localize the problem.
Sep 14, 2009 | Compaq Evo D500 PC Desktop
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
Compaq Evo D5 power light flashes red.
try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
Nov 13, 2007 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Intel Compaq EVO D500 (RBMDTCPQP42400) PC Desktop Logo
421 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
