Question about Plumbing
I need to know the carb adjustments for a Husky 65. I need to know how far each screw should be turned out on the carb to get it to run so that I can fine tune the saw.
  • 2,926 Answers
Start with 1.5 turns on the low speed screw and 1.5 turns on the high speed screw. You can fine tune from this setting.
Posted on Feb 03, 2010
Testimonial: "Thank you for your quick response. One question which screw is which? One screw is smaller than the other for fine tuning?"
    President:
  • 2,220 Answers
Workshop Manual for my a Husky 357XP/359 says (willing to wager yours is similar):
The Husky workshop manual on Appendix A (USA) says "H" 3/4 turn CCW from lightly seated. "L" 1.5 turns CCW from lightly seated.
Page 36 (every other nation on earth) 1 turn CCW from lightly seated for both the "H & L" needles.
There is no recommended initial "T" setting. (from manual) "The idling speed is correctly set when the engine runs smoothly in all positions and there is a clear margin to the speed at which the chain starts to move".
These are initial settings and the saw needs to be adjusted for performance. Start with a clean air filter and a fresh fuel mix @ 50:1 per Husky (1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil).
This explains performance carburetor adjustment better than I can:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
Testimonial: "Awesome great help"
Chainsaw chain keeps running
This is a carb adjustment issue and needs to be rectified before using it again, the L jet on the carb is set too lean, if you cannot correct yourself i would suggest taking it to the local chainsaw shop.
Jan 19, 2014 | Husky Garden
I have a No.359 Won't stay running, I put new fuel,spark plug,carb-kit? Also, do you need a special tool to adjust carb?
The carb screws have anti tamper sleeves on ( one red one white ) to adjust the screws you need to draw the caps back, you can do this with a small self tapping screw, screw it into the centre of the cap, when it hits the adjuster underneath the cap will draw back as you carry on screwing it in, only pull the cap back far enough ( approx half way ) you can then remove the screw and insert a 2mm flat blade screw driver through the centre of the cap, the adjuster underneath will now turn, the reason not to take the can right off is because the screws are only 2mm across, and it is near impossible to adjust the saw whilst it is running.
Oct 08, 2011 | Husqvarna Chain Saw 20" Bar
I have a husky 3750 generator about 2 yrs old. It is ony running on choke. As soon as you remove choke, it stops. I have changed oil and gas, clean the spark plug and check the air filter. Any ideas?
The fuel filter is probably partially clogged or the adjustment screw for the fuel mixture on the carb has backed off due to vibration. Try turning in the screw in 1/8 th of a turn at a time every time you start it.
Screws always loosen due to vibration so you only have to adjust in to fix it.
Regards
TickMagnet
Aug 15, 2011 | Briggs 3500W Port Generator
I have a series 51 husky saw. it starts and runs normally until it gets up to operating temps. then it stalls out and either refuses to restart or just won't restart until it cools down again....
sounds like air fuel mixture screws are out of adjustment..start with the on marked (L)..this is the low speed(idle) adjustment...turn it in all the way just until it stops..but be gentle..then you wnat to turn it out 1 1/2 turns as a starting point..start the engine and adjust it until you get a smooth idle...next, with the saw running, pull the trigger and you should have a smooth response from slow to fast...you can adjust the (H) screw until you get good high speed operation...if these adjustments don't fix the problem thenm yoou may need to have the carb rebuilt( a carb kit is usually only 15-30 dollars)
May 09, 2011 | Husqvarna Garden
I have a 1982 Kawasaki KZ1100D1 Spectre and have problems with it red-lining upon starting. It was running fine and idleing @ 1500rpm and I thought it was a little high so I adjusted the Idle screw and...
If you had to adjust with a screw driver you are probably altering the air bleed or mixture control and not the idle speed as a rough guide turn the screws fully in but do it gently as winding them in hard will damage the carbs and then undo the screw one and a half turns this should bring the carb back
into range
the idle adjustment is a finger adjustment knob in the center of the carbs(fuel tank lifted or removed to gain access) the problem with too high idle can be du to air leaks through the inlet rubbers leaking or being perished check for gaps bettween mating faces of carb rubbers to cylnder head
Feb 10, 2011 | 1984 kawasaki KE 125
Husky 125B blower, new right out of the box. starts, runs about 30 sec, bogs and quits. I'm guessing likely needs carb adjustment, but set screws are not regular slotted screws. Looks like it requires a...
My name is Dane and I am going to assist you in solving your problem.
You will need to adjust the high speed setting on your Carburetor jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however, yes you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carburetors are factory set lean so they can pass emission standards. Since you just bought yours, a local husky dealer should adjust the mixture for free. I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I
Dec 09, 2010 | Husqvarna 28cc Hand Held Blower HVH 125B
Member Discussion on Husqvarna 240e Chainsaw Idle Adjustment I have a new 240e and cannot keep it running. It will start, after many pulls, and one of two things happens. After running for 30...
Its not an idle screw adjustment issue, it is a mixture screw adjustment issue, unfortunatly there is a special tool to adjust the mixture screws, pt no. 530035560 ( available from Hysqvarna dealers ) once you have this tool you can make an adjustment to the L screw on the carb, undo ( anti clock wise ) this screw ten minutes on a clock face ,this will richen the muxture, and should make it more stable on idle.
Oct 07, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
1995 FLSTF 80CI Carburator bike not passing emissions
If you're talking about simply adjusting the idle mixture screw, you need to turn the screw inwards to lean it out. But, if you can get to the idle mixture screw, your carb has been modified as this screw has a "anti-tamper" plug covering the screw. The mixture screw is on the back side of the float bowl facing upwards.
More than likely, it sounds as if someone has rejetted the carb. That year model CV carb came with a a #42 slow jet in the carb. The modification to make them run better was to go to a #45 slow jet. This was in the original Keihen 40mm CV type carb. You can try to adjust the mixture screw and see if that allows you to pass. If it doesn't, repost and let us know. Maybe we can help you rejet your carb. Good Luck!
Jan 26, 2010 | Harley Davidson FLSTF - FLSTFI Fat Boy...
Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Jul 18, 2009 | Husqvarna Forest & Garden No.967012396 345...
Honda 1300c backfire through carb at wide open throttle. I have open up the exhust and rejetted the carb . the bike will run fine up to mid throttle or 65 mph but if you accellerate hard or go to wide open...
Try balancing ans syncronising the carbs.
BALANCE THE CARBS
Turn the throttle screw on the LEFT carb one half turn inward. Now start the engine and get it warmed up. With the engine running, remove the RIGHT spark plug wire. Adjust the idle speed on the left carb to the point where the engine just can't quite stay running and dies. Now put the loose spark plug wire back into place.
Now turn the throttle screw on the RIGHT carb one half turn inward. Restart and rev the engine. Next, remove the LEFT spark plug wire. Adjust the idle speed on the right carb to the point where the engine just can't quite stay running and dies. Now put the loose spark plug wire back into place.
Turn the idle screw on each carb EXACTLY ONE QUARTER turn outward and restart the engine. The engine will be probably be idling very fast. Adjust both the idle screws equally from this point to get to the desired idle speed.
SYNCHRONIZE THE CARBS
Remove the air filter and rubber fittings to allow you to see into the throat of both carbs. You may need a mirror to see inside. You need to be able to see the slides go up and down when you twist the throttle. Now turn the fitting where the cable goes into each carb such that there is just a bit of slack in the cable, 1/16" is plenty. Lock ONE of the cable adjusters down tight. All further adjustments will be made on the other carb.
With the motor turned off twist the throttle very slowly while looking at the slides. Both slides need to begin lifting at the exact same moment. If the slides don't raise at the exact same time then slowly twist the throttle until the locked adjuster slide just barely starts to move. Hold the throttle still and turn the adjuster on the other carb so that the slide on that carb just barely starts to move also. Now recheck the slide movement timing. Do this process until the slides on both carbs begin to raise at the EXACT same moment. Lock down the loose adjuster and re-check the slides.
Please rate this solution. Thanks!
Mar 30, 2009 | 2004 Honda VTX 1300
Plumbing Logo
117 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
