Question about Horizon Exercise & Fitness
I have lubed the belt and it will not restart is there somekind
Of a restart or more lube needed ?
  • 1 more comment
  • rodneyduke Feb 03, 2010
    This is a Horizon t81 tredmill. It stop and the display said lube belt. I lubed the belt and pluged the unit back up the display did not change the unit did not restart or change at all.. Do's this unit have a restart??
    The unit has been lube very well. Is there some tipe of a reset switch for the t81
  • rodneyduke Feb 08, 2010
    Sorry just got back in town need help with this. I have tried to reset as in your last reply. The unit display is showing LUBE BELT and it did not respond to the reset it did not look to need a reset. I have lubed the belt well. It was working great the day it stopped and displayed lube belt. Is there some other help if needed my Cell # 501-207-1739 NOTE: reset button was not popped out
  • 10,515 Answers
Kindly mention the Make and Model of the Treadmill?
Also, explain the Problem in Detail. Is the Treadmill working before you lubed the Belt?
Is the Speed Slow or It was Dead earlier as well? Is the Power entering the Machine? Is there any Output? Have you Tested the Motor?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 03, 2010
  • 1 more comment
  • taran_2005
    taran_2005 Feb 03, 2010
    Thanks for your response!!
    Are you sure you have Cleaned and Lubed the Deck properly.Read the below instructions :-
    http://www.treadmilldoctor.com/Walking-B...
    http://www.treadmilldoctor.com/Lubricant...
    Make sure Walking Belt needs Lubrication. Make sure Motor drive belt is Tight. Also, try Lubricating underneath the Walking Belt.
    Hope i helped you.
    Thanks
  • taran_2005
    Usually the Best way of Soft Reset is to Keep the Machine Unplugged for Few Minutes, say 30-60 minutes and then Turn it ON. It would usually Reset it.
    Regarding Hard Reset, each machine have it's own Hard Reset procedure. You could refer to the Manual which do have this information :-
    http://www.horizonfitness.com/uploadedFi...
    You need to have Acrobat Reader to View this.
    Generic Procedure to Reset Treadmill :-
    Step 1 Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
    Step 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    Step 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    Step 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
    Refer to this Complete Troubleshooting Guide
    http://www.treadmilldoctor.com/Troublesh...
    Let me know, if needed further assistance.
    Hope i helped you.
  • taran_2005
    taran_2005 Feb 08, 2010
    You need to Call a tech to Repair this as this seems to be a more big problem than we initially thought. You could tried yo keep it Unplug Once again for few minutes, Calibrate it once again and see, if that could help the issue.
    Hope i helped you.
    Thanks
Where does one lube the belt on this treadmill?
Belt is the surface you walk/run on.lift it up in the Centre and spray lube on the board belt runs on
Jan 08, 2015 | Exercise & Fitness
Rear Roller need lubrication.
see the video attached and proceed according, this is a matter very easy to lube the rollers bearing. Use the extension plastic coming the LUBE and put a little oil for lube the rollers bearint. Use WD-40 NOt use for LUBE deck belt, this 100% LUBE SILICONE special.
God bless you
Nov 26, 2012 | Exercise & Fitness
Says to lube belt .did that but when the safety key is inserted still saying lube belt
You must LUBE the deck belt, every week, otherwise you will have a WORN deck belt and replace with the rollers bearing. Now LUBE with 100% silicones lube.
2) lube THE Rolleler bearings too.
RUN the software calibration for easy diagnose, and troubleshooting
God bless you
Nov 17, 2012 | Exercise & Fitness
I hear a frction noice on the belt and the base while runing
1) LUBE the DECK BELT, you have probably a deck worn, by lack of maintenance propely.
2) LUBE the rollers bearing too, very weel
3) test the belt of drive motor, +test the bearing for lube , need repair too, to due the noise, each motor must be LUBE every 12 months aprox depend of use.
4) if you can not do that, call some tech repair.
God bless you
Jul 16, 2012 | Proform 380 Treadmill Walking Belt
I replaced the belt on the Proform 530x and it still sticks. I have also tried to silicone spray the deck,. Help ?
You must LUBE very well the deck belt. 2) adjus the roller bearing and LUBE very well 3) Motor can be LUBE follow the instruction manual for LUBE. 4) Adjust the deck belt see the diagram.
sincerely. God bless you.
Apr 23, 2012 | Proform 530 Treadmill Walking Belt
What is meant when it shows "lube belt"?
You need to apply lube between the walking belt and the black deck surface. Most manufacturers use silicone lube. We sell a lube kit for our treadmills that includes an applicator and a bottle of liquid silicone.for around $20.
Feb 09, 2011 | Horizon Fitness Horizon T103 Treadmill ...
Belt is slipping and squeaking when walked upon what type of lubricant should be used
Sounds like the motor belt is slipping. Make sure the belt from the motor to front roller pulley is tight.Once you have that adjusted lube and adjust the walk belt. The squeaking is usually from the motor belt. Many treadmills(Proform, Nordictrack for example) use Silicone lube (lube n walk, or silicone With teflon from Lowes works good) Call the manufacturer to make sure it uses a silicone lube.
Nov 23, 2010 | Cadence Exercise & Fitness
Lube Belt displays on digital display how to reset or where to lube the belt.
The message "LUBE" or "LUBE BELT" scrolls across the console display window. The treadmill will not operate while the message is displayed.
Reset the console by pressing the STOP and SPEED “+” or “^” for five seconds.
Jul 28, 2010 | Horizon Exercise & Fitness
HOW DO I LUBE MY HORIZON T81 TREADMILL
Your lube goes between the walking belt and the deck( the board under the belt). Apply lube as close to the center of the belt as possible then walk at a slow speed to spread lube evenly.
Jul 14, 2009 | Exercise & Fitness
Exercise & Fitness Logo
53 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
