Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
We have flashing dots across the screen, the whole screen
  • pamseats Feb 03, 2010
    The dots are white, it looks like a connect the dots into squares game. It happens many times but it is unpredictable. Occasionally it can be a good picture but mostly it is with the dots.
    yes, I will follow up on the recommendations.
  • 10,515 Answers
Is that Red Color? Kindly mention the Color of the Dots? Is that Random?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Feb 03, 2010
  • taran_2005
    taran_2005 Feb 03, 2010
    Thanks for your response!!
    This is a Common Problem with Sony Bravia.You need to Replace DMD Module. The DMD is available for about $150 cost, about $200 retail.The hard part is going to be a shop that will repair and replace only the DMD module, not the entire Optical Engine.Usually most of the Shops would replace Optical Engine which is Really Costly and not Advisable. If unable to Find DMD Module, contact SONY and complain regarding the Optical Engine Problem.You could search on google and check, if there is an Recall for the same.This has been an issue with most of the Sony Sets.I always advise the Customers to Go for Extended Warranty, if Possible as these Parts are not Serviceable and needs Replacement which could cost many bucks.
    Let me know, if needed further assistance.
    Hope i helped you.
    Thanks
I am getting a blue line on my scans when utilizing the feeder
The feeder sends the original across a small piece of glass. The scanner stays in one position as the paper runs across it rather than the scanner moving and paper staying still. The little piece of glass is probably a 1/2 inch by 12 inch glass. just clean that strip of glass. use alcohol. there is probably some whiteout on the glass. It will appear as a dot. When the paper runs across it, the dot is run across the whole page causing the line. if you cant find the strip of glass, run a scan and try to see where the scan light sits while it's running. Clean everywhere where the light sits.
Jan 15, 2011 | Office Equipment & Supplies
Green, blue, and red flickering dots all over screen
you need the main board check at www.shopjimmy.com or www.partstore.com
they have parts for your unit
Aug 18, 2009 | Televison & Video
Columns of tiny red dots fill my screen
sorry to tell you, I do repairs on LCD screens. And the issue your having is with the lcd part of the whole monitor itself, or the image processor is failing. More often than not, its impossible to find a replacement part to change out in this case. And should you take it to a repair shop, it will cost more to diagnose, order part, and labor repais than if you just got a new one. Hope
May 13, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Black dots on printouts
there is probably something on a drum, fuser roller, transfer roller, or primary roller. usually an easy fix for a copier tech, probably not for someone with no experience.
Apr 29, 2009 | Office Equipment & Supplies
Flashing dots
If you can see my comment PLEASE rate it FixYA
support.microsoft.com/kb/907534
Sep 06, 2008 | Microsoft Xbox 360 Console
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Samsung LN-T4065F Dotted lines across screen
tell the idiots where u bought this tv from and demaand a more expensive and better tv on their bill
Mar 02, 2008 | Yamaha DV-S5950 DVD Player
Samsung Le32r51bd
I have been having the same problem. It started as constant white dots obscuring the menu but as you hardly use the menu I left it. Then I had a row of white dots 5 dots high all the way across the screen about two thirds of the way up. This only happened on Ext1 and Ext 2. I tried 3 different Scart and A/V cables in ALL the possible connections in the back and still I got the dots. This has gradually got worse and I now have a screen full of flashing dots. With it being out of Warranty (18 month old) I have been referred to a company to repair it.
Estimated cost £263.37 inc VAT  Diagnosis: Needs a new PCB board Time to fix: 1 week
I shall update once I know more/final cost, on Wednesday.
In future I shall be taking the extended warranty out. :o(
Dec 02, 2007 | Samsung LN-R328W 32 in. HD-Ready LCD...
Little dots all over the screen
Sounds like something might be heating up
you could get a can of freeze from radio shack and spay it on the ic's one at a time till the problem goes away to locate the bad part.
Oct 13, 2007 | Philips 60PP9202 60" Rear Projection...
26", HDTV monitor, Theatre Wide HD, NTSC standard, "Moving DOTS"
YES IT WAS A STATIC FREQUENCY COMING FROM YOUR AC OUTLET TRY TO USE AC FILTER FROM YOUR OUTLET
Apr 24, 2007 | Toshiba 9.6 STN Color LCD Screen Assy...
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
