Question about Brother MFC 210C All-In-One InkJet Printer
"unable to init" message appears on my MFC 210c
First I was getting an "unable to clean" message, then I reset the counter and got a "unable to init" message. any ideas?
    Sniper:
  • 60 Answers
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Posted on Feb 03, 2010
Printer unable to clean
Your "excess toner cartridge/pad" is probably full. The reason it didn't clear when you turned it off is because your printer has a "counter" that didn't get reset during the power cycle. You can manually reset this "counter", which will clear the error and allow you to print. You have to bring the printer into Service Mode and find a counter and reset it, when you reset the correct one, it will clear the error.(sorry I cannot give you definitive instructions on how to do this)
But eventually your "excess toner cartridge/pad" will NEED replacing becasue toner will spill out of it and into the printer. Pretty simple, it's like a big sponge.
Reset the counter and you will print. But replace the excess toner pad soon.
Sep 21, 2009 | Brother MFC 210C All-In-One InkJet Printer
Already purged mfc-210c but the same error
não entendo ingles não poderia mada mensagem em portugues
Jan 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Unable to Clean Message
reset absorbers counter....
or, if you have strange sounds from printer, look for mechanical problems...
Nov 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 420CN
reset absorbers counter... for more info - search the net with keywords "reset absorbers counter + your printer model" )))
Nov 02, 2008 | Brother MFC 210C All-In-One InkJet Printer
[HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
Sep 19, 2008 | Brother MFC 210C All-In-One InkJet Printer
BROTHER MFC210-C "UNABLE TO INIT"
good day! Unable to print 50 means'' the machine does not work due to paper jam or some sensor...mostly unable to print 50 is sensor problem. to clear the problem clean the sensor, and then the mechanical...t
Dec 07, 2017 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C problem
press menu,blue button and up arrow 4 times , what number do you get?
If you spin a error 41 you in for bad news needs head, too expensive. 46 is waste full will need to replace the waste tank inside the printer and reset the counter. plus many more...
Jan 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
MFC-210C displaying "Unable to Print"
press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C
hi this a fateful malfunction only a technician can fix this good luck
Apr 06, 2006 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
522 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
