Question about Blanco Axia Silgranit Anthracite 6S Drop In Kitchen Sink Kitchen
I need a repair kit for a cracked silgranit sink
I need a repair kit for a silgranit sink that has a small crack in the flange....is there anything available out there? Or any solution?
  • 10,865 Answers
Hello., Yes definitely. Go to any home depot or hardware store and have one of the clerks show you the assortment of adhesives that will work on your problem. The fast drying clear resins and the one minute clear epoxy both work great.
Posted on Feb 03, 2010
Can i fix a nick in my large glass window from a small stone? no crack, just a nick
http://www.glasweld.com/glass-repair-protection/flat-glass-repair/
this website should help to find kits on repairing glass, from scratches to cracks
Jan 15, 2013 | Building Materials
When installing do you silicone each piece for example the faucet , the soap dispenser ,the sprayer , and the tap
Hi seawitch678,
If you have a granite or stone countertop/sink, use silicone as plumber's putty will stain the stone. Plumber's putty is petroleum based so it will not adhere to stone. Normally you should use what the manufacturer recommends and where they recommend. When installing a faucet, put either around the base of any piece that goes through the countertop.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jul 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
Just installed a vessel sink and it leaks between the vessel and under sink.
Use silicone to seal the flange and teflon tape on the threads that the drain flange screws onto. make sure that the sink isn't cracked. make sure that you have a washer under the rubber gasket that seals the bottom of the sink and tighten the nut against the washer snuggly.
Mar 23, 2011 | Vessel Home
Cracked porcelan
Try www.find-a-fix.com or just use any good quality porcelain repair kit. This kit may have a exact color match for you. take care and good luck.
Mar 08, 2011 | Kohler Bath Sink Undermount saree ...
We purchased a Silgranit sink and the recommended stopper-strainer (model no. 441098). Our plumber says that this unit is designed to fit through the sink bowl and attach to a waste disposal system (ie....
SILGRANIT II COORDINATED SINK WASTE DISPOSER STOPPER & STRAINER UNIT Fits disposer with 3-3/8" inside diameter only. It should just snap into the insinkerator sink flange.
Jan 17, 2011 | Blanco Sink Waste Strainer / Stopper...
My sink has a crack. can this be filled & sanded
Yes. Porcelain sinks can be fixed. Your local home improvement store will have it. It comes as a kit. easy to use and takes about 24 hours to cure.
Dec 25, 2010 | Blanco Axia Silgranit Anthracite 6S Drop...
Fitting tap to a Blanco Silgranit sink
The sink has scored holes across the back and comes with specific directions on how to pop out the extra holes. The sink comes with one hole already available. Follow the directions. Great sinks.
Jun 14, 2010 | Home
Something fell in the bathroom sink and there is a small hole in it.it is cream enamel and i want to fix it
Go to either home depot or lowes back in the plumbing section there are repair kits for chips and cracks.
Mar 05, 2009 | Home
Blanco Axia Silgranit Anthracite 6S Drop In Kitchen Sink Kitchen Logo
3,328 people viewed this question
Top Blanco Home Experts
J.D. Browning
J.D. Browning
uggachucka
Level 1 Expert
VsaToronto
Level 1 Expert
Are you a Blanco Home Expert? Answer questions, earn points and help others
