Question about HP OfficeJet 7310 All-In-One InkJet Printer
Disable color printing
How can I get my HP 7310xi all-in-one to print only in black and white when I don't want the color. Thanks!
    President:
  • 2,351 Answers
For your HP 7310xi you have an icon by your clock. Right click on it once & a window will open click Launch/Show. Open printer settings. Another windows will open. Click on the color tab. Under Color Options click to pring in grayscale. The HP will print in balck & white untill you uncheck print in grayscale.
Posted on Feb 19, 2008
    Genius:
  • 2,985 Answers
May be it cannot - there are so many models out there you will have to consult the manual- which is in PDF format on the software disk
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
Is there any way to disable the color cartridge in my HP 930c? I want to print only in black.
Under your printer preferences there is a way to print gray scale. SO even if your image is in color, it will print black and white. Every printer interface is different, but when you go to print, there's usually a properties or setting button that will bring you to another page from the initial print menu. here is where you would choose gray scale.
If you try for black with only a color cartridge, it'll come out a dark green or blue color. Or on some cases, it will tell you it's out of black and you can't print. Most HP printers need at both cartridges in the printer for it to print.
Jan 18, 2011 | HP DeskJet 930c InkJet Printer
My HP 3052 won't print color. Prints in black and white fine but no color! Thanks
The LaserJet 3052 is a Black and White only model. It does not PRINT in color. It will SCAN in color.
Jun 21, 2010 | LaserJet 3052 All-In-One Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
I just got a hp photosmart c4480 printer and it makes black and white copies, but I can't figure out how to print in black and white like when I am on a web site.
OK, Whe you select Print from the File Menu and the Print window opens, selct the Color tab.
There should be an option to Print in Grayscale. Check the box beside it and click OK at the bottom. Then back at the Print window, click Print.
(Note: If this option is not on the Color tab, or you do not have a color tab, look on the Advanced tab for the same thing.)
Need additional help...use the Comment link.
Thanks for using Fixya.
Apr 22, 2009 | HP Photosmart C4480 All-In-One InkJet...
Dell 5110cn Color printing only printing in black and white
check in the printer properties and make sure on the color page that "print in grayscale" is not selected. This option will make the prints all in black (grayscale)....
Dec 31, 2008 | Dell 5110cn Laser Printer
HP5600
You would need to go to your control panel, then printers, then right click on the HP5610 and then properties. Once there, you would need to look for the color setup screen. You should be able to choose something similar to: "print colors in black & white only". That is the only thing you can possibly change to force black & white printing. However, not every printer has this feature.
Jun 20, 2008 | HP Officejet 5610 All-In-One InkJet...
HP 5610 Will not print Color documents, only Black and White
Chances are that your print driver is set to print in black and white while the copier side is automatically detecting that your original is in color. To have the printer print in color: Select file print, select your printer and hit preferences. Select the Paper/Quality tab and switch from Black and White to Color.
Henry
Apr 28, 2008 | HP Officejet 5610 All-In-One InkJet...
Only prints in black and white
before you print go to the print properties or preferences, in there see if you find a setting that says black/white or color. select color then print.
you may or may not have this option. the older HP ink-jets defaulted to Black/white and you had to manualy select color from the current document you where printing.
Dec 05, 2007 | HP OfficeJet 6110xi All-In-One Thermal...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
1,141 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
