Question about GPS
Hi Guys, I am in need of a GPS antenna module to mate up with my Eagle AccuNav 11(2) GPS. Original unit was called EGP-1 or EGC-1 but nothing available. Even the module specs. would be helpful in order to have one made up. Any advice?? Cheers....Bryan.
  • 1 more comment
  • Bryan Sear Feb 06, 2010
    Thanks Mate but I don't have a GPS 45. I have an Eagle AccuNav 11!
    Can anyone else come up with a solution??
    Cheers....Bryan.
  • Bryan Sear Feb 15, 2010
    Thanks Pabloloco. Checked out the site but most of the external or patch antennas require an internal antenna which my unit doesn't have.
    Cheers....Bryan
  • 2,335 Answers
No luck finding you an antenna module in a box to purchase, but I do know where you can get some technical information if you are so inclined to get your AccuNav II running again instead of replacing it.
This page has some good technical links, including pinout diagrams and homebrew external antennae.
I hope that helps.
Posted on Feb 07, 2010
  • 1,284 Answers
Hi, you can make up the antenna your self by reading this below....
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} What is the GPS 40/38/12XL internal antenna?
It is a "patch" antenna design. The same antenna is also used on the optional
remote antennas GA 27 (GPS 40) and GA 26 (GPS 45) except that the remote
antennas are amplified.
How is the GPS 45/90/89/II antenna internally constructed?
Thanks to a friend whose GPS 45 antenna case split open, we
were able to examine the antenna construction. It is a quad-helix circular
polarized antenna. It basically looks like a double sided flexible circuit
board rolled into about a 1/2 inch diameter cylinder. It has 4 spiral
elements that look like the stripes on a candy cane. It is definitely a
a passive (non-amplified) antenna. However, it does work very well.
Several people have reported that when the plastic protective antenna case
is removed, it doesn't work as well due to detuning the antenna.
Someone has X-rayed their GPS 45 antenna and scanned the image.
Look at the files grm45ant.gif and grm45ant.inf on Peter Bennett's www/ftp
site.
Replacement antennas cost $100 from Garmin which is a little expensive in
my opinion.
http://www.abnormal.com/~thogard/gps/g45faq.txt
Posted on Feb 03, 2010
Eagle 462c will not power up
I called Lowrance and since Eagle has been discontinued, they no longer service them. However, they will offer to upgrade to Lowrance. I ended up getting a HDS-5 for $480.00. Not a bad deal since my Eagle was toast.
Sep 29, 2011 | Eagle Fishelite 642c Color Fishfinder Gps...
I hit menu and it comes up but i hit it again for main menu and it just goes back to screen i have no main showing
Reboot procedure from from Eagle tech support:
1. Turn unit off
2. Press and hold pages key
3. Press and hold power key at same time
4. Unit will power up. Wen map appears, release both keys.
5. Press exit 3 times
6. Press the menu key twice and it should now access the main menu
May 30, 2011 | Eagle Fishelite 642c Color Fishfinder Gps...
Machine does not acquire its GPS position. If it does it can take up to 45 mins to achive. Can I put an external antenna on it? The unit is used in an open boat, so has clear access to the sky, so should...
your antenna is probably original and obsolete see if you have a RayStar 120, if so, it is junk. The RayStar 125 is plug and play for you and sells around 300. Your GPS is a self contained receiver, that means it uses 12 V and output computer language. If you have no power to the seatalk antenna, you get nothing. If it is intermittent as you describe, 90% chanace it is the antenna, (mushroom or puck). 847-746-0100
Dec 28, 2009 | Eagle Seacharter 502c Df Igps T/M, Hst...
No maps on garmin nuvie 200
You will have to send it to Garmin with the original receipt and see if they'll reload the maps the unit came with. There may be a charge for this.
Jun 04, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
No backing light
Eagle only gives out a 1 year warranty on their products, so as far as I know you wont be able to get it fixed for free, but I would email them and see what they say.
Jan 15, 2009 | Eagle Fishelite 642c Color Fishfinder Gps...
Manuals
http://www.retrevo.com/s/Eagle-320-GPS-review-manual/id/517bh945/t/1-2/
Hit the Icon "GET MANUAL"
Nov 01, 2008 | Eagle FishElite 320 GPS Receiver
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Marine GPS
change the antenna with new
Jan 12, 2008 | Eagle IntelliMap 500C GPS Receiver
GPS Logo
127 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
