Question about Jenn-Air JGD8130 Gas Cooktop
Is 8000 btu.burner enough heat for general use
  • 221 Answers
Hi, 8000 btu is a medium size burner, simmer burners are around 4000 btu, The largest are around 12000.
Posted on Feb 03, 2010
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    Replace viking 12,000 btu valve with a 8,000 btu valve
    Safety factors first, gas comes out of the tube the burner valve is mounted on, so double check all connections first. (Use liquid soap to test) With that being said, although Viking does produce this part anymore, the body of the valve would be the same in turning and interior function. I had to rebuild a valve in the past and still works to this day. So this decision is all yours to make, as a certified service tech and if this was in my home yes I would, but I could not do this for a customer.
    I hope this helps
    Mar 28, 2014 | Cooktops
    Adjust flame
    Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
    Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
    One of the four burners does not work. The light comes on but no heat. Can it be repaired?
    Yes, you have a bad burner, sensor, burner switch, or wiring problem. The most likely is the burner switch. You should get this repaired asap, as this could be shorting out inside, and cause an electrical shock hazard. Unlikely but enough of a possibility that you should fix it soon.
    Jan 29, 2010 | Jenn-Air JED8430 Electric Cooktop
    GE profile performance electric cook top is not producing enough heat in the front burners.
    Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
    Did the burners ever produce enough heat?
    If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
    Typically, a small burner will provide less cooking heat than a large burner.
    Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
    Burners on JP326 electric not heating
    Sounds like breaker tripped so no 220 to unit. Reset breaker. The burner switch you first turned on probably blew out and needs replacing, so don't turn it on again. If all else works ok, then that is it. Unless you are handy you may want to call the repair man.
    Nov 30, 2008 | GE 30 in. JP326 Electric Cooktop
    Cook top
    Sounds like you have cartridge fuses in your house. When only one is blown it can cause interesting results. The clock is probably feeding back through the burner. This lets enough electricity through to run the clock and othe small things but not enough for heat. Have all the cartridge in your house tested. I'll bet either one of the mains or range ones are bad.
    May 28, 2008 | Frigidaire Cooktops
    Jenn-Air JGD8130
    The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
    Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
    Jenn-Air JGD8130 Gas Cooktop Logo
    193 people viewed this question
    Top Jenn-Air Cooktops Experts
    Dan Webster
    Dan Webster
    paulcarew
    Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
