Question about SanDisk Sansa e260 MP3 Player
My SANSA e260 froze up. I can't shut it off. Has a blank screen was trying to charge it.
  • 593 Answers
Make sure the player is fully charged. 1. Connect the player to your computer. 2. Make sure the computer detects the player. NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary. To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery hooked to your computer, which I see you have done but did you change modes MSC to MTP . next delete the song it keeps hanging on and re-copy it back on to the player from a different folder or re-rip it from the CD and copy it into a new folder then re-copy to the player.
Posted on Feb 03, 2010
I think my sansa e260 just died
Is it unlocked? I thought my sansa died a few times, bit it turned out that it was just locked.
Sep 28, 2009 | SanDisk Sansa e260 MP3 Player
IT's froze again, Arrrrrrrrrgh!
Try resetting it: To reset sansa: holding menu for 15-20 seconds. or Or-To reset the sansa = Hold down power button for 20 seconds.
Aug 15, 2007 | SanDisk Sansa e260 MP3 Player
Froze
Try prerssing all the buttons on the Sansa's face at the same time holding it down for a few seconds until the screen shuts down then turn it on again. This should work
Sep 26, 2008 | SanDisk Sansa e260 MP3 Player
The screen is turning white when I change song
You could possibly try recovery mode?
or formatting it and starting over, see if that helps
easy way to format
1.Shutdown player
2.Hold Rec button
3.Turn player on
4.Plug your player into the PC
5.Go to My computer
6.Find a Icon named 16Mb Format
7.Open that and make a new text file
8.Name it sansa.fmt
9.unplug player and it will say Formatting.....
10.when its finished it will reset , or shut off, when its done turn it on and see if that helps
May 08, 2008 | SanDisk Sansa e260 MP3 Player
Sansa cant be detected by computer
i had the same problem with mine and my computer didn't detected it so try plugging it in and out a few time it might work.but if that doesn't work go on settings and change the usb setting
Apr 06, 2008 | SanDisk Sansa e260 MP3 Player
Sreen froze on refreshing data
direct us to the drivers needed to install unit on pc thanks sansa e260
Feb 13, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 problems : Music files freezes the sansa and restarts it.
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Dec 05, 2007 | SanDisk Sansa e260 MP3 Player
Frozen in refresh database
download some firmwire from http://sandisk.com/Retail/Default.aspx?CatID=1376
Black screen no scroll light ????
I suggest that you hold down the power button for 15 seconds. It will reset it.
Feb 07, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
