Question about Dremel Variable - Speed Multipro Rotary Tool 395
I can't get the head to open to take out the bit
How do i open the head od the dremel model 395 i'm stumped
  • theilerc May 28, 2008
    It won't even turn a half turn
  • barbarik Jun 09, 2008
    These instructions were wonderful for clarity, instruction and information however mine seems to be stuck. Would it be a bad idea to use a bigger wrench or should I find someone with stronger hand muscles? (Hate that whole damsel in distress routine.)
  • 33 Answers
Unplug it, then while pushing in the little silver button near the head use a wrench on the hex nut and turn counter clockwise about a 1/2 turn. Push the bit in, then pull it out (that releases the little fingers that hold it).
The silver button locks the head so it won't spin while you are changing bits. Always be sure it is released before plugging in or turning on the power.
Posted on Feb 19, 2008
    Problem Solver:
  • 7 Answers
I've had this happen. Unscrew the collet nut and the collet and attachment will come out with it. You will see the attachment pushed all the way through the collet. Once the push the attachment flush with the collet, it will come out. I have pushed the collet down on a table to force the attachment up or have gotten creative with pliers.
Posted on Aug 03, 2008
I found a dremel at a yard sale model 395,I have never used one,and this didn;t come with instructions,how do you insert the tips
Posted on Jul 19, 2008
I need instructions as this has been borrowed
most if not all dremels use only 1/8 inch shafted bits ,tools
Oct 30, 2015 | Dremel Multipro Model 395 Type 5 Variable...
I need someone to tell me how to remove the entire attachment bit from the tool
dremel have a collet adaptor available to allow interchange of bits. They are available from dremel or hardware stores.
Feb 07, 2013 | Dremel Variable - Speed Multipro Rotary...
Dremel will not turn on?
IF you don't release the bit lock, it won't run.
Aug 01, 2010 | Dremel 395 Variable Speed Multipro Rotary...
The motor on my dremel 395 works but the bit doesn't turn
there is a coupling between the motor and the spindle that has probably cracked or stripped out. I suggest going to Dremel.com and getting an original replacement part for this. They are not hard to install.
Sep 02, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel Model 395 Type 3 Plastic Drive Shaft Connection broke into pieces. Replacement needed.
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
Apr 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Variable Speed Does Not Work - Model 395
It probably can be replaced. For info on this tool call 1-800-437-3635 (Dremel) and speak with customer service about a replacement part. Hope this helps
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Changing dremel heads
I have exactly the same unit a 395. The kit comes w/ a wrench to unscrew the nut holding whatever you have locked in. If you can't find the wrench then I suggest you get an adjustable wrench and lock it into the flat side of the nut. There is a place where it will lock in so that you can tighten or loosen the nut. Some of the 395's come as a kit w/ all the different attachments, accessories, heads and tools. If it came with a plastic case the wrench is usually slotted running parallel just in front of the handle. You will see it when you open the case and take a top view look at the handle. It is sometime hard to see but it's just there. Good luck.
Aug 05, 2008 | Dremel Variable - Speed Multipro Rotary...
Switch
Definitely not Home Depot. Try googling 'dremel model 395 switch', you'll probably come up with something. If not, there's always dremel themselves. This is a current model so there shouldn't be any real problem getting parts.
Sorry, don't know about installation, but I can tell you most of these dremels are real easy to fix in general, not complicated at all.
Jul 20, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
478 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
