Question about Kenmore 72982 Gas Dryer
KENMORE 11077732795 SERIES 70 DRYER COMES ON BY ITSELF. COULD IT BE TIMER?
  • 1,531 Answers
It could be a faulty timer i would also look at the door switch.how ever changing the timer is the best thing to do at this point
Posted on Feb 03, 2010
Kemore 70 series electric dryer not heating up
Might be the heater or a heater limit or the timer itself. It also could be the wall outlet or circuit breaker. It most likely is the heater itself though. Repair videos and manual on kenmore dryers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2012 | Kenmore Dryers
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Kenmore Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Have a kenmore series 70 dryer. Won't shut off
Yes it deffinetley sounds like you may have a timer issue, if your timer stops and the dryer is running, or if the timer keeps going around and around this will be the problem, however there are thermostats inside the dryer and if you have it set on a HEAT and not a TIMED setting the thermostats won't advance the timer because they havent been set.Hope this helps
Thanks.
Nov 22, 2009 | Kenmore Dryers
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
My Kenmore dryer (model # 11077732795) would not shut off or heat up. I replaced the timer and thermal fuse. The dryer now heats up and the timer moves but never shuts off. Any suggestions.
Just inside the drum on the front panel is a metal sensor strip that detects a change in capacitance as the clothes get dryer. When no more dampness is read the motor is energised by the moisture sensing board. Get the goop off the sensor strips so they can send a dry message.
Mar 01, 2009 | Kenmore 62602 Electric Dryer
Kenmore 72982 Gas Dryer Logo
137 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
