Recovery when trying to recover with discs...system states cd-rom read error
  • Ezaan Atif Jan 01, 2009
    Hello, I insert the CD in the CD-Rom and the installing is start and then the READ ERROR please tell me solution
    THANKING YOU
  • Anonymous Feb 16, 2009
    it says files missing
    Novelist:
  • 142 Answers
This is a READ error known as a CYCLIC REDUNDANCY READ ERROR.
If the CD ROM is not able to read from the disc .. it gives u this error
This can come due to many reasons
1. OLD CD ROM - not able to read data properly
2. CD with lot of scratches
3. CD not written properly: Data not burn properly on CD at the time of its make.
Solution: Try to insert a new CD in it and then check whether it works or not
or get a CD LENS CLEANER DISC which will remove any kind of small debris on the lens on the CD ROM and then it will work.
This would surely help
Posted on Feb 19, 2008
One day my acer laptop aspire 5742z came up with disk read error please restart... I didn't have a disk in the drive but I restarted it anyway ... It kept coming back to that same screen. I restarted...
Hi koga9783...
How to reinstall the Operating system on your computer
Select models of Acer laptops, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
1.Restart the computer.
2.When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
3.If you are prompted with a Microsoft Windows boot screen, press the Enter key.
4.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form..
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
2.When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
3.Press the CD-ROM drive eject button and insert the disc labeled System CD.
4.Close the CD-ROM tray.
5.Refer to on screen instructions to select either CDROM or USB CDROM.
6.The computer will boot from the Acer Recovery Media
7.When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
8.After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Please take time to rate me
Sep 21, 2011 | Computers & Internet
Tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
on Oct 13, 2011 | HP Computers & Internet
My acer laptop aspire 5742z came up with error reading disk error when I had no disk then I restarted it and it went to the acer start up window then 5 seconds later it turned off then on and it follows in...
Hi koga9783...
Try this solution to your problem.
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Sep 21, 2011 | Acer Computers & Internet
How do i do a system rebuild on a acer travelmate 2410 series 2413NWMLi , the <alt> <f10> does not bring anything up
If your computer does not have a hidden partition for OS recovery, a recovery CD will be required in order to recover the Operating System using Acer Recovery Media.
Order the Recovery Media from Acer https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Aug 17, 2011 | Acer TravelMate 2300 Notebook
Aspire one kav 60 would not boot how to recover it or restore it???
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Aug 15, 2011 | Acer Aspire One PC Notebook
Hi i cant get my recovery cd to work but i have used it befor. i have changed the boot bios like it says on cd sleeve to 1 cd rom. 2 hard drive. 3 floppy although it hasnt got a floppy drive, i put...
if u want to get recover ur system with the help of recovery cd then first of all if u have done first boot device cdrom on bios setup then restart ur system . while booting the system u have to continue press the 'enter' to boot from cd rome then ur system will boot with cd rom then u can get recovery.
Jan 15, 2011 | Computers & Internet
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
Jan 13, 2011 | Compaq Presario 5000 PC Desktop
Recovery disc problems
the cd recovery you have need connect to hard disk by some files system when u change new hard miss these files so cannot do it. only u recover by use ghost from image
Jan 19, 2010 | HP Pavilion DV6700T Notebook PC
Toshiba Satellite M35X-S163 Can't Be Recovered
This happens. Recovery/reinstallations sometimes takes many attempts. Only, you have to clean the CDs. Clean them with a soft cloth in + signs and not circular as one would think, CDs being circular. So, clean then top to bottom and right to left and vice versa.
Nov 26, 2009 | Computers & Internet
Trying to run recovery disc on computer and cd rom isn't reading
I see this as one of 2 possible failures.
  1. Optical drive failing. Take out the Hard drive, see if the recovery disk, or another bootable disk will boot. If no change, replace the optical drive.
  2. Hard Drive failing. If the system will boot to a CD with the HDD out or if replacing the optical drive has no change, then the HDD is the next logical failure point.
Apr 02, 2009 | Compaq Computers & Internet
Computers & Internet Logo
448 people viewed this question
David Payne
David Payne
