Question about Kenmore Elite 45986 Front Load Washer
Can you use regular detergent with front loader washers??
  • 39 Answers
All manufactures suggest using a high efficiecy detergent. They are specially formulated to keep the suds level low and work well with the low water levels of a front loader. Boxes are marked with an HE on them letting you know they are for high effiency machines. Regular detergents were designed for washers that use many gallons of water.
Posted on Feb 03, 2010
  • 5,911 Answers
No. ALL front loader washers built for consumers that are rated as high efficiency require HE detergent because of the small amount of water and electricity they use. This small amount of water, coupled with a wash tub that does not agitate continously, followed by a high speed final spin of 1200 rpms or higher, all equate to an overall energy savings as compared to a conventional top loader.
Regular detergent is formulated to be used in a wash tub with a 35 gallon capacity. So, if you use that same detergent in a wash tub that uses 5 to 7 gallons of water (such as yours), you are in effect putting about 5 times the concentration in the washer. This can lead to soap scum build up which causes odors, soap deposits that remain in your clothing and can cause skin irritation, "SUDS" errors that stop the wash program due to too much suds in the wash tub, and premature wear on the drain pump motor and seals. In fact, most front loaders will have a disclaimer added in the owner';s manual that explains this. Most manufacturers will also void the warranty if it is discovered you are using improper detergent. Use HE detergent and pay attention to the label. Some of them are double (2X) and triple (3X) concentrated. I hope this helps you.
5 Suggested Answers
  • 96 Answers
SOURCE: my front loader washer
Which model machine do you have?
Posted on Mar 04, 2008
jsrock516
  • 5911 Answers
SOURCE: How much detergent that is not HE can I use?
It is strongly recommended that you DO NOT use regular detergent in an HE washer. The regular detergent is formulated for a wash tub capacity of 35 gallons. A High Efficiency washer, such as yours, only uses 5 to 7 gallons of water per load. You can potentially cause premature failure of the gaskets and seals, as well as drain pump problems by using a higher concentration of detergent. In addition, you may end up with residual soap left retained in your clothing which can cause skin irritation. So...if you do the math, you would have to use about 1/5th the amount of soap you would normally use. However, if this is a new washer, you will void the manufacturers warranty if it discovered that you purposely used improper detergent. There is a disclaimer in the Owner/Operators Manual that should explain this. I hope you find this information helpful.
Posted on Nov 14, 2008
  • 82 Answers
SOURCE: Water runs from out the detergent dispenser on my front loader
Try pulling the drawer out again and look in the hole. Look on the bottom for detergent or softener piled up and allowing the water to come out the door or anything clogging the tube in the back of the hole. Look on the top, there are a bunch of little holes, make sure none of these are clogged, clean with a toothbrush and sewing pin if clogged. Take the drawer completely apart and clean thoroughly, check for any cracks. If nothing is found here Take the lid off with the 3 screws in the back and push the lid toward the back of washer and lift off. Run the washer and check for the leaks with a flashlight. DO NOT TOUCH ANYTHING ELECTRICAL. As there is a shock hazard with the lid off.
Thank you
Posted on Jan 23, 2010
bob_computer
  • 3153 Answers
SOURCE: what is the proper soap
These types of washing machine require HE (high efficiency) detergent and it is available from most supermarkets, costco, wallmart and many other stores.
Just lokok for "HE" on the front.
Detergent brand names may vary but "HE" remains.
DO NOT use regular detergent as this can and does cause many issues on these washing machines some may even require an engineer to call and fix them.
These are by far one of the best washing machine types saving both energy and time for a much better clean.
Bob
Posted on Sep 13, 2010
Why do you have to use H.E. detergent in front load washers?
not as much suds as regular detergent and double the strenth,front load washers use less water than top loaders,if you use to much detergent the machine will keep filling and draining to try to get the suds out.also you should only be using 1/4 cup of H.E. detergent or you can damage the spider gear in the washer,you'll know if it breaks you'll hear the tub banging all around loudly when it's in final spin,the spider gear is made out of soft metal and the extra detergent eats at the metal
Apr 09, 2011 | LG Washing Machines
Tip
Getting Rid of Front Loader Mildew and Odor
This advice is for that awful mildew smell associated with front loader style washing machines.
Place the washer on the hottest setting you have with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
USE HE DETERGENT ONLY. Using regular detergent, or improper amounts of detergent can contribute to the build up of soap scum in which dirt can collect. Regular detergent is formulated to be used in a conventional wash tub with capacity of about 35 gallons. A high efficiency front loader only uses 5 to 7 gallons of water. So, if you use regular detergent in a front loader, you are, in affect, using about 5 times the concentration of detergent needed. This can cause oversudsing, premature wear on the pump motor and parts, premature wear on rubber seals, odor from sticky soap residue and skin irritations caused by soap residue left in clothing. Using improper detergent will also void the manufacturer's warranty. Make sure you READ all detergent labels some HE detergent is double (2X) and triple (3X) concentrated.
on Apr 05, 2010 | Washing Machines
If someone uses wrong washing power and puts front loader washing power in a top loader can that do or cause any sort problems
That's no big deal. It won't harm a top load washer. Just try to use the proper stuff next time.
However, you should never use regular top load laundry detergent (non HE) in a front loading machine though, because that can quickly cause problems.
http://www.myefficientplanet.com/tag/too-much-foam-wrong-detergent-front-loader-washing-machine/
Good luck.
Mar 05, 2011 | Fisher and Paykel GWL11 Top Load Washer
What is the proper soap detergent needed for front loader samsung washer and dryers?and where to purchase?
Bob
Sep 13, 2010 | Samsung WF337AA Front Load Washer
When in wash it dosent remove all soap powder from clothes
I don't know how you are administering the soap powder to the machine..but for one, its recommended that you use detergent thats made exclusively for the front loader washer, usually says "he" on the front of the LIQUID detergent, they recommend that you use liquid detergent on top of that, BUT if you have to use regular powder detergent it must be put inside the tub and NOT the pull out detergent drawer. The reason why they want you to use liquid is because the powder detergent is not concentrated and when you use it, it lathers up alot and its harder for the front loader machine to clean out the clothes and I was told that they (sales agents) have heard of soap suds and bubble floods coming from the machine due to either using the powder detergent or using too much. Hope that this helps!!
May 15, 2010 | Zanussi ZJ1217 Front Load Washer
Do Frigidaire Front Load Washers require H&E detergents?
The answer is YES. Nearly all front loader washers built for consumers are rated as high efficiency because of the small amount of water and electricity they use. This small amount of water, coupled with a wash tub that does not agitate continously, followed by a high speed final spin of 1200 rpms or higher, all equate to an overall energy savings as compared to a conventional top loader. Regular detergent is formulated to be used in a wash tub with a 35 gallon capacity. So, if you use that same detergent in a wash tub that uses 5 to 7 gallons of water (such as yours), you are in effect putting about 5 times the concentration in the washer. This can lead to soap scum build up which causes odors, soap deposits that remain in your clothing and can cause skin irritation, "SUDS" errors that stop the wash program due to too much suds in the wash tub, and premature wear on the drain pump motor and seals. In fact, most front loaders will have a disclaimer added in the owner';s manual that explains this. Most manufacturers will also void the warranty if it is discovered you are using improper detergent. Use HE detergent and pay attention to the label. Some of them are double (2X) and triple (3X) concentrated. I hope this helps you.
Nov 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Allergic to detergent for front loaders
I have always used regular Tide powder in mine and my kids use Tide liquid in it. You just need to use about half as much. My man is a motor head so he gets DIRTY and I have three teens so I wash a lot of very dirty clothes. My clothes get very clean and I have never purchased the "special" Detergent.
I have had my Duet for three years.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Nov 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LAUNDRY DETERGENT
Greetings MOMMA2,
Typically it is recommended to use only HE (High Efficiency) in your front loading units. The difference between HE soaps and normal detergents is that they are low sudsing soaps. HE Machines need low sudsing detergents and if regular detergent is used, the excess suds could lead to washer problems. Unfortunately just using a smaller amount of regular detergent does not fix the issue. Only the use of HE detergent assures the proper performance of your unit.
Due to this, it is NOT recommended using Dreft in HE machines.
One recommendation out there is to look for 2x Ultra Tide HE Free, which is made without dyes or perfumes.
Thank you,
Dorothy
Go Ahead. Use Us.
May 24, 2008 | LG WM-2277HW Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
97 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
