Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover Steam Vac Model F5826-900
Water comes out ok but the vacuum has no suction. Instead it is blowing air instead of pulling up the water.
  • Anonymous Mar 31, 2014
    Is there suppose to be something to cover the top
    hole for the blow action?
  • 126 Answers
When you put the lid on the recovery tank, you have to be sure that the front of the lid is properly engaged into the two tabs on the top of the tank. With the lid installed, if you can lift the front of the lid off the tank with two fingers, then the lid is not on correctly. Also, make sure the square duct that goes into the front of the tank is in place. You have to remove this duct to install the hose for doing furniture but must replace it to go back to the floor function. By the way, the "blowing air" you refer to is normal. This is exhaust air from the motor and it is used to propel the solution onto the carpet.
Posted on Feb 19, 2008
Why does my hoover steam vac only blow out
Hey there! The cleaner blowing out air instead of sucking is an indication that the unit is not sealed off properly. Follow these brief steps to restore suction to your cleaner.
1. Remove the clean water tank.
2. Recline the handle and let the cleaner lay flat.
3. Remove the dirty water tank lid.
4. Reposition the front panel located on the outside of the tank in the center. It should be flush to the tank, even straight across and pushed down as far as it will go.
5. Assemble the dirty water tank lid back on from the front to the back. The lid should not lift up from the front.
Give it a try! The cleaner should now have suction. Hope this helps!
Jun 02, 2014 | Hoover SteamVac F5914-900 SpinScrub...
My hoover steam vac will not **** up the water on the carper.
the lid on the tank is not on properly or the duct/block that fits in the front of tank is missing..
May 05, 2010 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Iam trying to use the upolhstery piece. Iam squeezing the button and no cleaner is coming out. Iam using by hoover steam vac deluxe spin.
Confirm that the hose is correctly connected to the clean water supply. If so, then remove it and, with the trigger operated on the hose, try to blow into the water feed connector. If you cannot pass air, the feed tube in the hose is clogged and must be cleaned (either by running faucet water into the brush end (with trigger pulled) or by using compressed air....
Nov 22, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Every time i push the steam vac forward it dispenses water
you are having the same problem i am and so far the best solution i have found is i need a new clean tank just got my steamvac today bought it cheap so not complaining much the other solution i found was to only have the cleaning solution tank in for as long as i need it if i put the cleaning solution on the floor then take out the clean tank the dirt tank still sucks up the water
Godbless and Goodluck ...by the way just in case you dont have it here is the manual for your model
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Jun 08, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction - air blowing OUT from tube
Is the air blowing out of the pick-up tube or out of the exhaust tube on the unit? I am assuming the pick-up tube. The installer has hooked your system up to the exhaust tube on the unit. Hook up to the intake on the unit instead.
May 27, 2009 | Hoover L2310 GUV Central System Vacuum
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Dispenses Water Only
try replacing the air filter and the water heater.
Jul 28, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
347 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
