Question about Rolex Mens Super President, 18kt YG
My men's presidential date just is very difficult to wind. I try to wear it often, but it quits. The winding mechanism is so stiff that I can only partially wind it. It does move easily in the oposite direction. The watch is vinatage - around 1970. I did have it appraised and authenticated and the seller cleaned/serviced the watch prior to the sale.
    President:
  • 2,501 Answers
If it has only recently gone stiff then it sound like a trip to the dealer for repair.
It may sound daft but all the Rolex I have examined are self winders. Is yours? (you can often hear the self winding mechanism by placing the watch close to your ear and rocking it gently).
Could it be that you need to pull out the crown to wind it?
Posted on Feb 03, 2010
Winder for automatic watch
When you wind it manually (forward or clockwise) it winds the mainspring. Only need to watch it 5 or 6 times if it's completely stopped you wearing it will do the rest. If you going to get a automatic winder get one that will wind in both directions. It will give a few revolutions clockwise and then we'll go reverse counterclockwise.
Hope this answers your questions thank you.
Jun 06, 2015 | Bulova Mens Marine Star - 98B209 Watches -...
The Stuhrling classic cuvette works by the movement of your wrist or winding. It is difficult to find the right space to wind, change the date or time as they are all so close together. Does anyone have...
Just set the time and date and wear it, your movement should be enough to keep it running, or give it a good shake. Automatic watch winders are also available to buy
Sep 26, 2013 | Watches
The tissot visodate watch is automatic not battery driven.
I would not wind the watch manually. I also have a Tissot. If you cannot wear it often enough to keep it going, you can purchase a watch box that is made for self-winding watches which will turn the watch periodically in order to keep it wound.
Oct 19, 2012 | Tissot Visodate Automatic Leather Mens...
Date does not set will rotate to next day before it should?
I am not quite sure of your problem but mechanical watches can be 12 hours out and still give the correct time but when it is indicating (say) 9 o'clock, it means 9 a.m. when it is 9 p.m.
If this is the problem you have, then wind the watch forward 12 hours and it will change overnight instead of at noon.
I hope this helps.
Aug 21, 2011 | H3 Tactical H3.15222 Blue Shadow 1 Watch...
Just a quick question On my Omega Double eagle, I went to mexico for the week left my watch at home and when I return I gave it a shake to start the movement being it is a chroncile watch and for some...
A mechanical watch will tend to stop in the same place if an internal gear is slightly unbalanced and/or there's a spot of grease/dirt that makes that particular point on a gear slightly more difficult to pass. I've often seen watches with day/date indicators stop just around midnight, as it takes more energy to advance those dials than just move the hour and minute hands.
Try winding your watch with the crown as opposed to shaking it to wind it via the automatic rotor. Actual winding will bring your mainspring up to full power much faster than a whole lot of winding via automatic rotor. See if this changes the behavior of the watch. If it doesn't, you probably need to have a watchmaker take a look at the watch. He or she will probably recommend cleaning the movement to clear any dirt that might be causing the problem.
May 08, 2011 | Omega Constellation Double Eagle Gold &...
How do you get started to wind a BMW watch. There is no resistance when I wind the crown. There does nt seem to be any plastic or anything in the way. I ve set the date successfully. Its a BMW Chrono...
mcdevito75 here, BMW watch, nice watch, Actually there are 2 ways to start winding an automatic or self wind watch. Since you feel no resistance in the winder (crown) which if you did, would mean the automatic mechanism is attached by gear to the mainspring and winding the crown (stem) would start the winding process. Without any resistance winding the crown, your automatic mechanism is free-lance as a way of saying, in your watch which simply means your BMW watch winds solely on wrist / arm motion. First, make sure you hear the automatic mechanism moveing inside the watch when you move the watch in almost any direction, now simply hold the watch in your hand and with a rocking motion, say from 12--to 6 rock your hand back and forth for about 30 seconds. You can also make circular motions with the watch in your hand for 30 seconds, any motion that will cause the automatic movement in your watch to move will, start the winding process. After you see you watch has started, simply wear your watch to keep it wound.
Jul 31, 2010 | Bulova Watch
Watch winding is not holding
Two words: Wind it! When any self-winding (automatic) watch runs down from not wearing it you have to manually wind it to get it going again. Once you've done that the movement of your wrist will cause the self-winding rotor mechanism to keep it running as long as you are reasonably active and wear it everyday. Just wind it about 40 turns and you'll be good to go. Oris is a great watch company and you should enjoy it for many years.
Apr 16, 2010 | ORIS Watch TT3 Day Date 63575887067MB
My watch ticks for 10 to 15 seconds then then stops then i shake it and it continues then stops again what could it be
You have an self winding watch and to wind is up fully using the self winding mechanism you need to shake it for some time.
I think it is likely that you can winding it manually using the crown. You may have to pull the crown out to find the manual winding position.
The crown may be locked in and if it doesn't pull out , try turning it anticlockwise then pull it out.
You should have some instructions with your watch, if you haven't contact your supplier and ask for a copy.
If you wish to find your nearest retailer, go to "Brietling.com" for a store locator.
Feb 19, 2010 | Breitling NEW BREITLING BENTLEY 6.75 MENS...
Hi - took it off for 36 hrs - never had an issue - oyster submariner not moving now ... thanks for your help
This is a mechanical auto-wind watch. It self winds when worn. But if taken off for a couple of days it will have stopped and won't start running again unless it is wound.
Put it on and wear it for a few minutes. This will wind it enough to start it running again. Then set the time and wear it and you'll be fine.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Oct 27, 2009 | Rolex Day-Date President 118238 Wristwatch
The user guide is wrong
I have a Theorema Parago Automatic through not wearing it regularly it sometimes stops. Winding it wouldn't solve the problem and I couldn't find a solution either on the Theorema site or online so through a series of self help efforts the following is the solution for this watch 1 Set the watch to the correct time date day etc. 2 Wind the watch using the side winder for about 40 revolutions in clockwise rotation 3 Hold the watch in your right and strike it firmly into the stiff palm of your left hand. This gives the winding mechanism a shark shock and kicks it back into life.The watch then works away without a problem.
Nov 17, 2008 | Ebel Tarawa Automatic 9127J40/5435136...
Rolex Mens Super President, 18kt YG Logo
192 people viewed this question
Top Rolex Watches Experts
Samyfam
Samyfam
Are you a Rolex Watch Expert? Answer questions, earn points and help others
