Question about Emerson LC320EM8 32 in. LCD TV
Trying to hook playstation 3 and tv says format not supported
  • 111 Answers
Hook up ps3 with green blue and red jacks componet use red and white for audio
Posted on Feb 03, 2010
3 Suggested Answers
imadejoolaff
  • 27 Answers
SOURCE: PS3 dont work
Go through setup on your PS3 with a normal AV cable and un-check the higher resolution boxes (1080p and down) one at a time, unless you know specifically what resolutions your television supports. After un-checking, plug in the HDMI cable and see if it fixes it. Basically, you need to set the PS3 to a supported format for your television.
Posted on Jan 31, 2009
AJIN G
  • 6694 Answers
SOURCE: well everytime we hook up
hi,
the playstation 3 outputs full HD VIDEO (1080p) , if your tv is not a full HD one then you cant see the video. Do one thing connect the PlayStation 3 to any full hd tv and go to it video setting. Down scale the video to 1080i. All HD ready tvs supports only resolution up to 1080i. only full HD tvs supports 1080p. Down scale the video to 1080i surely you will get video.
ok
Posted on Feb 15, 2011
Well everytime we hook up the HDMI for the playstation 3 to the tv it says invalid format how do i fix this
You must make sure your playstation and your TV set are both set for the same video format (1080p, 1080i, 720p, etc.).
You can either go through all your HDTV formats until it synchs up (give each a good 20 seconds or so before moving on), or you can open the display menu for your PS/3 using a different video connection to your set (i.e. composite), setting both to match, then switching them to HDMI.
Feb 15, 2011 | Televison & Video
Does the Playstation 3 support 3D DVD"S. I just bought a Sony 3D capable tv and hooked everything up and the PS-3 says it doesn" support 3D format.
With the new 3.50 update that Sony released it unlocked the ability for the PS3 to play 3D blu rays. Are you sure you have updated to 3.50 as you will need to do this before playing any 3D blu rays. I am sure if you update to this version you will find everything will be fine.
Hope this helps
Dec 04, 2010 | Sony Playstation 3 (PS3) Console
When i connect my ps3 to the tv it says format not supported
Hi. Hook up your PS3 to you TV with the HDMI cable. Now, when you turn on your PS3, hold the power button on the PS3 for 5 seconds. It will reset the PS3 video options and recognize the HDMI connection. It will then search for the correct resolution settings on the TV. Press (X) to confirm. And that's it. You should be set. If not, then the TV is acting rather strange.
Sep 12, 2010 | Sony Playstation 3 (PS3) Console
When I turn my PS3 on the screen said format not supported.
plug you ps3 into another tv and lower the resolution
then hook it back up to the other tv. you have the resolution set too high and the tv wont take the signal correctly
Jun 12, 2010 | Sony Playstation 3 (PS3) Console
Format not supported
Are you trying to connect this with red white and yellow rca cables or hdmi? if you turn off the ps3 and hold down the power button it will reset itself to the factory settings for the tv out put.make sure ou have rca connected firs.
May 17, 2010 | Sony Playstation 3 (PS3) Console
Ok so basically i'm at a friend's house and we try to hook up the playstation 3 to his hd tv and it just says invalid format
Make sure that the TV is set to the proper " Channel "
With some HD TVs, you have to switch between different types of input depending on what you want to access.
Oct 17, 2009 | Sony PlayStation 3 40GB System
I tried to play timeshift it says something about video output doesn't support it. what's that?
What format is your tv? SD, PAL NTSC HD 720 1080i 1080p, 50Hz?? Check the back of the game box to see what formats are supported.
Apr 01, 2009 | Sony Playstation 3 (PS3) Console
Invalid format??
change the display settings to 1080i or 720p- his tv likely does not support 1080p.
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 hook up
If there is no picture on the TV screen: Back to top
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
If that does not help try contacting sony at
1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Best of Luck,
-Rel
Apr 20, 2008 | Sony Playstation 3 (PS3) Console
Denon AVR 4306 receiver not connecting up 1080p with playstation 3
HELLO, I DID A LITTLE RESEARCH FOR YOU AND FOUND IN YOUR MANUAL ON PG 103 IT STATES "RES OF 1080P ARE NOT HANDLED"
Jan 21, 2007 | Denon AVR-4306 Receiver
Emerson LC320EM8 32 in. LCD TV Logo
170 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
