Question about HP Officejet 4315 All-in-One Printer
How do i change my unit back to printer its in fax mode
  • 3 Answers
Go in control panel...printers..and highlight your printer....you should see the status as ready after you do that
Posted on Feb 03, 2010
Fax is stuck on manual mode. how can I change. When I try to change modes, is says that DR mode in in use.
I had this problem too, I just fixed it! DR = DISTINCTIVE RING, this means you have it turned on. To turn it off go to menu, fax, miscellaneous, distinctive and select OFF. Now go to back to initial setup and select your mode!
Mar 03, 2010 | Brother MFC-440CN InkJet Printer
Tip
How to test, and setup the Fax machine on HP multifunctional printers.
Hi.
Please follow the instructions below to install and test the fax on an HP multifunctional unit.
1 - before connecting the printer install the software in the CD provided with the printer on the computer. The fax unit will also work in stand alone mode, but without installing the software you will not be able to control the unit from the connected computer.
2 - Have ready a phone cable. Ensure that the phone cable that you want to use has only two connectors:
3 - Connect one end of the telephone cord to the telephone jack andthen connect the other end of the cord to the socket labeled 1-Line on the back of the HP fax printer.
4 - The multifunction HP is now ready to send and receive Fax.
To send a basic fax:
1. Load your originals.
2. Enter the fax number by using the dial button on keypad.
3. Press START FAX Black.If the device detects an original loaded inthe automatic document feeder, it will send the document to the numberyou entered
If the Fax is not sending, then check that the original is loaded properly, then run the fax test following procedure below:
  1. press Setup
  2. select Tools
  3. select Run fax test
  4. press OK
Or:
  1. Load the original into the input tray.
  2. Press the Setup button (the one with a wrench) on the unit control panel.
  3. Press right arrow, select Tools, then press OK.
  4. On the Tools menu, press the right arrow to select Run Fax Test, and then press OK. The fax diagnostic test prints.
  5. Review the report.
If the test does not return ALL PASS , then setup the fax manually.
Change the HP fax settings
  1. Disconnect the telephone cord from the single-line telephone and then plug it into the port marked 1-Line at the back of the HP product.
  2. Press the Setup button (the one with a wrench) on the product control panel.
  3. Press the right arrow to select Basic Fax Setup or Advanced Fax Setup, then press the right arrow again to change settings to the settings listed in the table below.
After verifying Fax settings, try again sending a fax.
If still no luck, try calling the HP number listed on your user manual. In that case there may be a fault.
Also ensure that you do not have a VOIP phone rather than a landline phone, in that case setup will be completely different.
You can find driver software and manuals using the link below:
HP SUPPORT.
Regards.
on Feb 26, 2010 | Office Equipment & Supplies
How to change date on this pinter
{MENU} i {#}{1}{0}{1} i {SET} M:|01/D:01/Y:07 TIME: 12:00AM 2 Enter the current month/date/year/hour/minute by selecting 2 digits for each. Example: August 10, 2007 10:15 PM (12 hour clock format) 1. Press {0}{8} {1}{0} {0}{7} {1}{0} {1}{5}. M:|08/D:10/Y:07 TIME: 10:15AM 2. Press {*} repeatedly to select “PM”. 3 {SET} 4 Press {MENU} to exit. Note: L The other party’s fax machine will print the date and time on the top of each page you send according to your unit’s date and time setting. L After setting the date and time, if the unit is in the copy mode, change it to the fax mode by pressing {FAX}. You can check your unit’s date and time setting on the display. To correct a mistake Press {<} or {>} to move the cursor to the incorrect number, and make the correction.
Feb 18, 2010 | Panasonic KX-MB781 All-In-One Laser...
How do i change from fax back to printer?
Find The Fax button and click it
then its normal :)
-JON AKA MAYOROFSWORD/SPRAYERZ.
Aug 11, 2009 | HP Officejet 4315 All-in-One Printer
Fax tones heard during tel conversatio
Kindly check your incomming line connected in Line In port of machine . And change your receive mode as TEL/FAX .
Again the same will happen the probelm related to its Line Interface Unit. Change it and check, your problem must be solve.
Jul 19, 2009 | Samsung SCX-4828FN All-In-One Laser...
HP Officejet 4500 keeps defaulting to fax mode
check the setting like menu look in there somewhere
Jun 05, 2009 | Office Equipment & Supplies
Change from fax mode to printer mode
There is a scan mode, but not a print mode. If this is what you mean. You may have a stuck fax button or operation panel.
Feb 11, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Check printer ##331 CANON FAXPHONE B95
HI your problem in fixing unit change it and your problem will be solved
Oct 31, 2008 | Canon FAX-L350 Plain Paper Laser
Lexmark x5150 all-in-one inkjet printer. trying to get the fax to work. i have dsl.
You may have to experiment to get the fax to work on DSL. Try these suggestions: press MENU, then scroll to:PRINT REPORTS. Scroll to HELP LIST and press SET BUTTON. Press START button to print HELP LIST. On the HELP LIST printout, locate the FAX MENU. Using a cell phone, call your fax and see if the fax answers. If not, try changing the following settings (change one setting, then call the fax with the cell and see if it answers, Make sure you set each changed setting back to what it was, until you find the right one.) try changing: RING DELAY, F/T RING TIME, EASY RECEIVE, OVERSEAS MODE. Also on the HELP LIST, find the INITIAL SETUP MENU. Select RECEIVE MODE, and try each option, again calling the fax with your cell until it answers.After you get the fax to answer calls from your cell, try sending and receiving with another fax, or use Brothers AUTOMATIC FAX-BACK SYSTEM, which will automatically send your fax a test printout when you call it. Just call 1-800-521-2846 from your fax machine, IT MAY BE ALREADY PROGRAMMED INTO YOUR MACHINES AUTO DIAL LIST, AUTO DIAL NUMBER 001..
Aug 16, 2008 | Lexmark Office Equipment & Supplies
"Receiving Sleep" on Brother Fax 4100
you might have to change the settings for the switching time into stand-by. plz have a look into the manual which describes these settings (zero seconds are possible)
Jan 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
145 people viewed this question
Seeker5211
Seeker5211
