Question about Northstar Electric Wet Steam & Hot Water Pressure Washer 2000 Psi, 1.5 Gpm, 120 Volt
Smokes bad when burner kicks on
Every time we use it when the burner ignites to heat water white smoke comes out the top really bad. it really stinks up our shop.
  • 106 Answers
Hey mate,
What brand of burner are you running? I am a Karcher Tech but they all work on the same principle,
Your burner is getting to much diesel/kero, most have little flow swicthes on them to tell them to pump fuel or spark when there is water present in the burner coil, if this switch is faulty or getting a faulse reading then it will tell the unit to pump fuel when it is not needed and this will cause very excessive smoke for the first few mins when the burner kicks in...
If you have the excessive smoke continuously(even after 10 mins of continous use then it is probable that your fuel pump/system is running to rich, these units need regular servicing and adjustments as fuel nozzles/components wear,
There is alot of precise adjustments and checks on these units and i would reccommend getting it checked by a qualified tech, as when there is heated fuel and spark these units can be dangerous!
Hope this helps
Regards
Brad
Posted on Feb 05, 2010
  • Sean Towers
    Sean Towers Oct 31, 2013
    to add to your list of solutions could be your a few other things, your nozzel spray, incorrect voltage and here is a big one. every time your burner is turned on it sprays fuel, and hense gets on your insulation and that can build up. so what is a cheap way to start out is to pull your core. and redo the insulation, which is pretty cheap. i have done it in just a few short hours!
  • Stephen Cowley
    Stephen Cowley Jan 07, 2014
    Sean - would you be able to walk me through how to pull the core and change the insulation? Or could you direct me to some resources that do that?
What does the white smoke coming out of the top of the flu on my oil boiler mean
White smoke means steam and that would be caused by a leak in the heat exchanger coil of water in the fuel.
May 02, 2015 | Biasi B-6 Oil Boiler w/ Riello Burner -...
White smoke coming from tale pipe
Be sure that smoke isn't steam . It makes a difference. If it smokes all the time the piston rings are worn out. If it smokes only after idling then stops soon after accelerating then the valve stem seals are worn out. If it turns out that that white smoke is really steam then the engine is burning water. A bad head gasket is usually the culprit.
Sep 24, 2014 | Cars & Trucks
What does white smoke mean?
With a petrol engine, water/coolant is being burnt due to blown head gasket.
Jun 17, 2014 | 2001 Nissan Altima
Engine concern
Smoke (blue or black) or steam (white)? White smoke is really steam that is caused by water leaking onto hot surface. Could be leaking from hose running to heater coil under dash, or something else. Check radiator water level to make sure water level is ok. Blue smoke is oil burning. This could be dangerous, caused by similar scenario of oil leaking on a hot surface (from a gasket leak, etc), or exhaust fumes. Black smoke means something is actually burning and could indicate fire. Black or blue some could fill vehicle cabin with toxic fumes, even if you don't smell anything bad.
Jan 02, 2014 | 1995 Isuzu Trooper
I have a Laars Max Boiler 75, 90K with white smoke out chimney
Hello
Yes,more then likely its moisture from the high effenicey system of the boiler.
I have a laars boiler at work and some mornings when its cold out it looks like there is a fire, which is really only steam.
As long as your not shutting down on low water failure or loosing pressure and holding temp.This is normal.
Hope this helps.
Jan 26, 2010 | Heating & Cooling
Just bought a used karcher hds 500ci every now & again lots of smoke belches out burner is this a bad sign ? also cant seem to get the chemicals to pick up any tips
you burner assy needs to be cleaned , spark electrodes properly gapped and the fuel pump pressure set , the chemical pick up often gets clogged , and the chemical valve ( pump side becomes jammed ( a small ball bearing jams in the seat )
also clean out the diesel tank and clean or replace the fuel filter , if the smokes is white thats caused by water in the fuel , black smoke is too much fuel going to the burner assy or your ignition electrodes not igniting it
Nov 15, 2009 | Garden
2001 Volvo s40 oil leaking in turbo, smokes white smoke and turbo not kicking in. I have a new head, timing belt waterpump, oxygen sens. valve job, cam pulley all changed. It is still smoking and no turbo....
Water in combustion chamber makes white smoke--suspect that the head gasket is leaking water into the chamber. If oil leaking around turbo, it may have a bad bearing and bad oil seal. Check waste gate valve and control.
Aug 01, 2009 | 2001 Volvo S40
White Smoke coming out of bonnet & exhaust,stinks of burning oil 1989 dodge dynasty is blowing out white smoke now, and it does smell like burning oil, i owned a 1988 dodge dynasty and it did the same...
Sounds typical of head gasket failure.
With this you get oil into cylinders / water into cylinders, burning oil, loosing water - but no leaks. "boiling" of radiator and overflows.
Check your coolant and oil levels - they will be low.
Get a few quotes for a head gasket replacement - and timing belt change, as it has to come off when you do this anyway & no sense putting an old one on - they often snap if retensioned.
If this solves your problem, please take a moment to rate as Fixya! thanks.
Jun 22, 2008 | 1989 Dodge Dynasty
oxygen sensor
oil leak at back of block thats spirting on hot engine block
bad oil rings in block
valves bad
head or head gasket worn and cracked check the oil if chocolate brown then this would be it
a/c preasure line busted or a/c locked up
water line busted on hot engine or small water leak
bad emmission components
these are the things i can think of off the top of my that could give this reaction in vehicle since im not there in person to see vehicle this will have to be what i think
Jun 16, 2008 | 1990 Ford Escort
Northstar Electric Wet Steam & Hot Water Pressure Washer 2000 Psi, 1.5 Gpm, 120 Volt Logo
764 people viewed this question
Top Northstar Garden Experts
John Trevino
JOHN LAPIER
Are you a Northstar Garden Expert? Answer questions, earn points and help others
