I have SRS 900 MHz hybrid wireless headphones. The amount of time they stay charged is slowly decreasing and today, when I put the headphones on the charger, they don't show they are charging. Help! Tricia
  • 221 Answers
Hi, your owners manual is found here: http://service.us.panasonic.com/OPERMANPDF/RPWF930.PDF
Page 6 refers to the batteries, page 14 shows where the batteries are installed. These look like size AA nickel-metal hydride (2). Take them to store like Radio Shack or look online for replacements. There is a customer service number, 1-800-211-7262. Best of luck.
Posted on Feb 03, 2010
My husband three away my transmitter to my Centrios 900 MHZ DIGITAL HYBRID WIRELESS OUTDOOR SPEAKERS. #4015004
So many of these things are made generic and have limited production run. The OEM is not traceable. I
would recommend getting the whole set.
Jun 05, 2017 | Centrios Audio Players & Recorders
Hi. I just purchased the insignia digital wireless headphones for my boyfriend and the headphones won't charge properly. It says to put the on the dock station and the red light will stay on(up to 4 hours)...
If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
Dec 30, 2014 | Audio Players & Recorders
Sennheiser Wireless Headphone picks up unwanted transmissions
This headset uses a 900 MHz frequency for connection from the headset to the base.
You will always incur lots of interference in a busy office using that frequency band. Any antennas on the roof or close by?
Amateur radio users?
The other thing, you might have a faulty power supply or "dirty power" coming into the unit. You can try and isolate in a current regulating power bar and see if that helps.
Else, consider changing technologies and moving to, say a DECT band.
Avoid, 2.4 and 5 GHz bands as they are in the wireless devices range and likely will incur equal amounts of interference.
Jan 08, 2014 | Sennheiser RS 120 Consumer Headphones
I need to know how to connect my 900 MHz Digital Hybrid Wireless Headphones Model No. CT411
See if there is any audio output connections on the front or rear, they will be round connectors one red one white otherwise known as Phone or RCA. You may then require a small adaptor to change the two connectors to on 3.5mm jack plug, you can buy these from any electronics shops.
Nov 21, 2011 | Audio Players & Recorders
I just received for my birthday, a RCA 900 MHz headphones. Followed the instructions but cannot get it to work. I tried to install it on a Hitasha TV. Can you help me?
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the RCAheadphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) RCA pilot lamp should flicker in parallel to voice coming from TV
  • RCA headphone should have 2 different rotary adjustment on it..one "Volume" and the second "Frequency" adjustment
  • while TV talking , adjust slowly the "frequency rotary dial" to catch the headphone transmitter coming from RCA headphone base,when you catch it you will hear the voice of TV,(sometimes fine adjustment makes it better ) than adjust volume properly..
  • .After this pls do not touch Frequency dial any more..Just Turn it on ,and Volume adjustment ..Thats it..
  • After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs work independently from the TV's master volume control..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | RCA Audio Players & Recorders
25 farad cap slowly losing its charg if the car sits for to long
Cap is hooked up wrong, should shut off after a certain amount of time and reactivate with the ignition hot wire. If it's draining your battery continuously then you should look at the wiring.
Dec 24, 2009 | Power Acoustik Pcnc3.0f 5 Farad Digital...
SRS light blinking then staying on?
A flashing/steady-on SRS light indicates a problem with the SR system. Because the system contains an explosive, it is best serviced by a Saab trained and certified tech; you can be seriously hurt working on it yourself. SRS system problems can be diagnosed and fixed, and the light reset, by the dealer or trained workshop tech.
Pulling the bulb from the warning lights on the panel treats the symptom, without curing the cause - you've still got whatever fault triggered it in the first place! Definitely not recommended for a safety feature. (You wouldn't just pull the bulb if your ABS light stayed on, would you? Wouldn't you want to know why?)
The best source of info on this car is the "Bentley Bible" aka the Saab 900 Official Service Manual, costs about $40 from Amazon!
16 valve manual: http://www.amazon.com/Saab-900-Valve-Service-Manual/dp/0837603137
8 valve manual :http://www.amazon.com/Eight-Official-Service-Manual-1981-1988/dp/0837603102
Get the appropriate manual for your car and enjoy the Saab!
Hope this info helps; if it does, please give a "thumbs up"
Thanks
Saabreur
May 06, 2009 | 1991 Saab 900
SRS light stays on
I have 2002 Odyssey( 59000 miles without warranty). Several months ago the SRS light stayed on after I started the car. Some people said the dealers usually charge $ 80 to 95 to reset the light. Today I sent the car to dealer. After checking the car, they told me the car is under warranty, the parts and repairing are free.
Jun 16, 2008 | 2002 Honda Odyssey
 Grubhead
Grubhead
