Question about Viking 30" Professional Select Built-in Electric Single Oven - VESO130
Smoking viking gas oven
Hi, I have a Viking oven and stove. The oven has a filter that leads to a short pipe to the back vent. Something from there was smoking severely when my wife cooked at 475 deg the other day. I took it apart, and there was a lot of charcoal in the filter pan. I think it was a mouse storage area, but does Viking keep charcoal in these pans to help absorb grease, or are they supposed to be empty? I can't wait to get my hands on that mouse!
  • 832 Answers
SOURCE: Viking double ovens. Can both ovens be cleaned at
Unplug your oven, and clean both at once., Yes, you can.
Posted on Sep 26, 2009
SOURCE: how long to run self clean on viking professional
The "Self Clean" will run for quite a while up to 4 hours I believe, during this time, the stove heats up to about 900 degrees!! and during this time the Door is automatically closed via special locks. It will allow you to open once it is finished, it should "Signal" this event.
Posted on Feb 11, 2010
heatman101
  • 43501 Answers
SOURCE: oven not properly heating
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Posted on May 07, 2010
  • 122 Answers
SOURCE: have a viking professional oven and it takes too
A weak oven ignitor will cause this problem. even though it eventually lights the temp has dropped considerably so you don't get consistent temp. turn the oven on and listen for the burner to light. should light within about 2 minutes. if not replace oven ignitor(s)
Posted on May 20, 2010
  • 195 Answers
SOURCE: My Viking DESO 101 oven wont turn off
Yes then controler has gone bad for the oven , you can locate the part on line and have it shipped right to your house or give me the model and serial number and make and i will locate it for you later today
Posted on Dec 08, 2011
I'm looking at a used Viking double wall oven in gas-Viking Vgd0271SS.. Does anyone know anything about it?
This is a high end wall oven. Common break downs are oven ignitors, all ovens fo that though. Life span for an igniter is 5 to 10 years. Viking is rare to have problems..
Dec 07, 2014 | Ovens
My Viking oven will not lite, the igniter glows, but it will not lite. I have to turn on the 4 stove top burners and then it will lite. Also, when the oven reaches temperature and the therastat shuts it...
That sounds like you have too high of gas pressure which keeps the oven gas valve from opening...turning on the burners lowers the gas pressure enough to allow the gas valve to open. this is a saftey feature on many gas valves.
To stop that you will need to install a gas pressure regulator which will hold back the gas pressure so the valve can open.
Here is a tip that I wrote about regulators and them failing on the low side, but it will give you and idea what I am talking about and what you need to install in the line to your range.
http://www.fixya.com/support/r5849793-propane_lp_or_natural_gas_regulator
heatman101
Apr 22, 2011 | Viking 27" Professional Select Built-in...
On my viking oven i get a FO on the panel. The oven wont cut on.
hi
f0 error is either an E.C.R. (electronic range control) or that it is the keypad and it would probly be about 300 buuucks to fix
Jan 09, 2011 | Viking VGS0166 Stainless Steel Gas Single...
Viking gas oven will not heat up
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 10, 2010 | Viking Ovens
How long to run self clean on viking professional
Feb 11, 2010 | Viking 27" Professional Select Built-in...
Wehre is model number located on viking oven?
It is usually on the stove at the bottom of the oven door. you might have to remove it to read it properly
Sep 18, 2009 | Viking Ovens
Top burners on our Viking work fine, however the
Hi, There is a good chance the ignitor is bad. Even if it glows, it could be weak enough that it will not open the gas valve. It is very a common problem with the gas stoves.
I would change the ignitor.
Vic
Jun 27, 2009 | Ovens
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Viking 30" Professional Select Built-in Electric Single Oven - VESO130 Logo
101 people viewed this question
Top Viking Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
