Question about Precor 9.31 Treadmill
I have the Precor 9.31 and it is 4 years old. When I start going fast the power shuts off completley. I am 210 pounds and this happens to me, however my wife is 120 pounds and is not having a problom.
Did you find a fix for your problem? I am having the same issue.
THanks
Posted on May 09, 2011
    President:
  • Precor Master
  • 832 Answers
SOUND LIKE A LUBRICATION ISSUE DEPENDING ON THE MANUFACTURER NOW A DAYS SYN SILICON IS USED ON MOST PHENOLIC DECKS IF NO MAINTENANCE HAS BEEN DONE I WOULD ALSO CHECK THE FOR UNEVEN SURFACE AND THE BELT MAYBE TO WORN AND THE LUBRICATE WILL NOT BE EFFECTIVE , BUT ITS CHEAPER TO TRY LUBE THAN NEW BELT AND DECK. GO TO gymparts.com part# TM001 or call them @ 1-800-496-7278
Posted on Mar 02, 2010
Which gas are refill in 210 whirlpool fridge
Hello Arushdeep Singh,
I have tried to find a "210" whirlpool,..
Sadly only finding some vague references to a
17 cubic foot OLD TIME refrigerator... (?).
The good news: If indeed you are speaking of
an "OLD TIME" unit more than 3o years ago
your gas is Freon R22...
The bad news is that is BANNED and your
choices are varied... interesting and all fairly
expensive.... (hideously expensive).
Sorry that is all I can relate on a MODEL 210.
(Lot of R22 scams going on out there... be careful).
((of course)).
30 pound canisters sell for under $800 US Dollars.
R22 FREON REFRIGERANT 15 oz CAN UNUSED eBay
May 14, 2017 | Whirlpool Refrigerators
WE have a 2.5 year old Jacuzzi J-210 hot tub that plugs into an outside outlet that is a GFI; power has been shutting down; when we tap the plug and reinsert it, the spa power returns. Why is this?
shut power down and replace outlet, GFIC only last so long, and if they have been tripped a lot they wear out, again shut off the power to the outlet before doing any work.
Apr 03, 2017 | Jacuzzi Pool & Spa
Precor 9,31 treadmill tripping internal breaker
You may want to check how many outlets or other items that you have on the breaker. When those treadmills go faster, they draw a lot of amperage. Not much that you can do except for unplugging what you aren't using on that circuit until you are done. If you run an extension cord to another circuit, that draws even more amperage or hire an electrician to install a larger breaker for you.
Jul 10, 2017 | Exercise & Fitness
Hello, Our Precor 9.21si begins slipping after walking or running a few minutes. Seems to be worse the faster you go. After about 1 mile, the house fuse blows. What troubleshooting steps do you thi
This really sounds like the results of long term use without lubrication or wax between the belt and deck. Chances are you will need to replace the running belt and the deck or flip the deck if it has not already been done. The friction builds up between the deck and belt and caused the electronic components to overheat. The machine is shutting down as a precautionary measure. It will do this only so many times before the electronics are zapped. Start with the deck and belt. Hopefully the electronics are okay. With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Repair Parts for 9 21s 9 21si Treadmills Consumer SPORTSMITH net
Feb 03, 2013 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
I have a precor 9.3 treadmill that works until you i start running on it, what is the cause?
1= LUBE the deck belt , this happen because enough friction produce shut down, for to protect the electronic system.
2= LUBE the rollers bearings too
3= measure the input voltage motor, if there are the motor need repair
4= measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block
God bless you
Jul 19, 2012 | Precor 933 Premium Series Treadmill
My Precor 9.35 treadmill keeps shutting off. At first I thought this was due to use or it getting overheated. But, today I turned it on several times and it would shut off as I was walking on it. The...
Is it on an extension cord? Take it off any extension cords and make sure it's on a dedicated 120v circuit. No other items on the circuit. Also, how old is it? Precor made a bunch of the 9.3x series from 2002-2005 with an aluminum tail roller that can cause problems. Check the back roller. Is is silver and non-magnetic? if that's the case, you have an aluminum roller and you need to contact precor. If you're the original owner of the machine, they should warranty the replacement of the parts, if not, you'll have to buy at the very least a running belt and new roller.
Jun 21, 2010 | Precor 935 Premium Series Treadmill
Treadmill works just fine for me. i am 100 pounds, my husband got on and it went out of control and he was trying to regulate it and had to get off. We have tried several times. It works for me not for...
Sounds like the unit needs to be lubricated, Its laboring under his weight thus the foot plant technology that the precor use cannot adjust properly go to Treadmill Doctor.com and you order the lubricant from their.
Apr 27, 2010 | Precor 9.31 Treadmill
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
Not booting up properly
Besure all wires are connected to motherboard properly, and also be sure you LCD Lamp Is Not Going out (although, that shouldnt be happening if its only a year old)
Aug 09, 2006 | Compaq Armada E500 Notebook
Precor 9.31 Treadmill Logo
453 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
