Question about Danby DWC2121BLS Wine Cooler
One side of my cooler flashes h1 and is not cooling. what is the cause? I can not set the temperature on this one side. Other side works fine.
DOREEN1
  • 51 Answers
SOURCE: cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Posted on Jan 31, 2008
SOURCE: Jenn Air JCD2389GTW Refrigerator problem
The auto defrost timer was broken, so my refrigerator repairman replaced it. The part is about $60. The bigger expense was the labor getting to the timer, which is in the upper right hand corner of the refrigerator within the plastic casing that houses the temperature control levers. He then had to remove the panels of the freezer and defrost the coils with a blow heater. It took several hours.
Posted on Feb 29, 2008
  • 5 Answers
SOURCE: My Greenway water cooler/heater does not cool the
Hello
My name is Victoria and I work for Greenway Home Products. I am sorry to hear about your troubles with our products. Please feel free to call our customer service line at 1-866-253-0447 or email me directly at vpeer@greenwayhp.com and we will try to rectify any problems that you have with your water dispenser!
Posted on Apr 06, 2010
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
Sorry to break it to y'all, but Everstar went out of business (probably bankrupt). There's nothing filing a lawsuit would do now.
Posted on Apr 21, 2010
  • 23 Answers
SOURCE: I have a Whirlpool Princess series Model#
Check to see if the fan inside the freezer is working... Also check if you have any frost build-up inside the freezer ..Frost buildup is an indication of either a non working defroster and/or a bad fan. Can't diagnose it with limited information.
Regards'
Dectech
Posted on Sep 02, 2010
Frigidaire side by side refrigerator/freezer has h1 flashing on refrig. side
H1 is temperature detected as too warm. Is compressor running? Are evaporator and condenser fans running? Is there frost build up on inside back wall of freezer?
Sep 13, 2017 | Frigidaire Refrigerators
In the cooling mode for zone 1, why won't the temperature stay as set on the cool setting?
If it 2 degree cooler then that's fine .adjust your thermostat 2 degrees higher so you will get the temperature
Feb 16, 2018 | Carrier Heating & Cooling
H 1 flashing Frigidaire side by side
I appreciate your post, Sharon!
From the information you have provided your Frigidaire side by side refrigerator is displaying an "H1" error code. I was unable to locate that error code but I did find the error code "HI" which stands for high temperature inside of your freezer compartment. Check your freezer is it still cooling? If so it may just be a miscommunication within your refrigerator and you can clear that by disconnecting the power cord for roughly ten minutes. If you continue to experience an issue I would recommend having a professional technician out to perform a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Best of luck! -Matt
Mar 24, 2015 | Frigidaire Refrigerators
Just purchased and is not cooling at all
please see this steps and fix it. God bless you
1. Unit not running
Possible Causes Response a. Power cord unplugged
b. No power at all
c. If display lighting, temp setting high
d. If temp setting ok, sensors or control board bad
e. Compressor unit malfunctioning a. Check for power cord plug
b. Check receptacle voltage & fuses
c. Lower temperature setting
d. Call service for replacing sensors or control board
e. Call service for component check
Nov 27, 2013 | EdgeStar CWR361FD - 36 Bottle Built-In...
Fridgeaire error code H1
Hello - Could it possibly be HI? Typically error code HI indicates that the unit has detected high temperature in freezer. Try setting the unit to a lower setting. Generally the factory setting is 0 for the freezer temperature and 37 for the fresh food temperature.
Oct 13, 2012 | Frigidaire FSC23F7DSB Stainless Steel Side...
Wine cooler too cold, compressor keeps running, temperature display is off
Let me first go over how a sealed system actually works that way when I tell you whats wrong you won't think I'm crazy. There are two sides to the freon system, known as the sealed system. The low side, where freon is in a gas form. In this form, freons temperature is at its coldest. Now, the freon can't just sit because movement is required for it to be cold. The high side does this by compressing the gas into a liquid,which pressure causes the temperature to rise, and forcing it through to the low side where it becomes a gas. So, with that said, the more freon in a sealed system the more pressure is applied, causing a higher temperature because less time as a gas. This is how they make wine coolers, walk in fridges, etc cool, not freeze. If you were to remove freon, the temperarture would get colder. Your wine cooler should have enough freon to prevent this from happening, and it doesn't therefor the freon has more time as a gas. Either you have a leak, or you've somehow knocked a freon line loose. It should have a year warranty on it.
May 18, 2012 | Refrigerators
Samsung side by side refrigerator RS265TDRS started making loud propeller like noise on the cooler side half way up. Notice bunch of ice around the lights on the back wall of it. I unplugged the fridge for...
A COUPLE THINGS U SAY FREEZER IS FINE FRIDGE IS NOT? THE FAN NOISE MAY BE DUE TO ICE BUILD UP DUE TO A DEFECTIVE BAD DEFROST TERMINATOR. WHICH EVENTUALLY WILL BUILD ICE UP IN FREEZER AND FRIDGE? HINDER COLD AIR CIRCULATION. ANOTHER THING TO LOOK AT IS UR FREEZER AND FRIDGE THERMISTORS AND UR COLD CONTROL THERMOSTAT. EVEN UR AIR FLOW DAMPER CONTROL VENT AND KNOB SETTINGS? ARE THEY TO FAR OPEN OR CLOSED? ARE U ABLE TO HEAR THE FAN AND COMPRESSOR RUNNING? ANY CLICKING SOUNDS?
Feb 25, 2012 | Samsung RS265TDRS Side by Side...
Whats the correct temperature the fridge should be set at? our milk goes off very quickly and nothing chills.
A refrigerator should be set for a temperature of 37 to 39 degrees F. Refrigerator controls are not usually marked in degrees but have indications for "warmer-cooler". Set the control toward the cooler side and check the temperature. Place a reliable thermometer on a middle shelf to check the temperature. If the refrigerator is not able to maintain a temperature in the 37 to 39 range then the cooling system may need service.
Oct 21, 2009 | Refrigerators
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Cooler wont cool below 48 degrees.
cabinet.
cooling quickly;
hours.
dial.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby DWC2121BLS Wine Cooler Logo
52 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
