I have a kenmore elite he3t front loader washing machine that initially gave me a 02 F code then after cleaning the lines out which were not clogged I ran a cycle with apple cider vinegar to clean out the internal lines now I have a code that says ''sud''. What is going on?
  • 39 Answers
You have a pump problem. F02 is a pump error code. Something is probably clogged up in the pump filter. Remove lower front panel, pump is at center bottom. Make sure as much water as possible is removed from basket then unscrew pump filter cover. Remove filter and clean then reinstall. Washing something with too much lint or using a high sudsing detergent can cause SUD or F02 error. If problem continues you might need a new pump.
Posted on Feb 03, 2010
  • 5,911 Answers
"SUD" is a SUDS detect error. This can be an indication of a restriction somewhere in the drainage system, a failed drain pump, you are using too much detergent, or you are using the wrong type of detergent. The following link explains the error in more detail and how to correct:
http://www.fixya.com/support/r3608687-sud_error
You may have some foaming action going on inside the drain pump caused by the vinegar mixing with soap residue in the lines. Allow the washer to sit for 30 minutes, then run a Rinse/Spin cycle with nothing in the washer. You may have to do this several times in order to clear any suds.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
My washing machine gets a sud error often during the cycle. I have cleaned the drain as suggested
Vinegar does a great job of cutting suds and bubbles. I would put it in the detergent, softener, and bleach reservoirs and run a cycle. Then make sure you read the detergent amounts. It's easy to overdo detergent on a front-loader.
Aug 17, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
I have the kennmore elite he3t. Error code f 02 and it will not drain Is there a solution to this problem you know of?
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Jan 03, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
Jun 06, 2010 | Kenmore 44932 Front Load Washer
Kenmore elite he3t steam front loader - 110.4674-2 --- f35
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
We have a Kenmore Elite HE3t front loader washing machine.It has had water remaining in it after a load has finished twice now. I run it spin/drain and it is gone. Haven't had the problem for a few loads...
Hello. You sound like you have one of two problems.
The bottom panel on your washing machine has 3 screws on the bottom part of it that hold it on. You will need to remove these screws and the panel. On the right hand side you will see a plastic pump assembly. Since you have alot of water in the washer, you will need to lean the unit back at about a 45 degree angle so water won't go everywhere. Unscrew the front of the pump using the handle on it. It is either clogged up OR bad. If it is not clogged up, you will need to replace it. Send me the model number and I will get you the part number.
Jul 15, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite error code
possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
142 people viewed this question
Top Washing Machines Experts
