Question about Electrolux Dishwashers
Washer works for a short time then blacks out my electricity due leakage
  • 51 Answers
The heating element needs replacing, this will solve the problem of tripping the power supply.
appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 03, 2010
Black horizontal stripes
Black horizontal lines ( page is held Portrait ) ,
where print is affected the print image fails to show behind Line effect but shows in between-
the drum surface has been damaged ( likely wear and tear) and can no longer maintain an even layer of electrons due to leakage/short
solution:
replace the toner cartridge which houses the drum.
Mar 16, 2014 | HP LaserJet 2300 Printer
Making coffee this morning and I was frothing the milk and the system just shut down.
More than likely your internal components has failed, particularly it sounds like the power supply portion of the circuit. This is due to faulty part or short circuit due to leakage or stress on electrical components. More than likely even if you are "tech savvy" coffee pot are usually difficult to repair depending on the type. The circuit boards are printed and the microprocessor (the brain) more than likely is a glob of black epoxy coupled with micro parts you can barely see. To stop my rambling I would say replace it, or take it back to store for replacement, find another exact coffee pot that is damage but internal electrical components remain in tac, or just trash it and buy another...Good Luck
Jan 27, 2013 | Coffee Makers & Espresso Machines
Have 100 amana ptacpthat the evap.is only sweating out about 2 inches from the bottom
Short of gas due to leakage. Check the pumping pressure in discharge side of compressor. If it's more than 250psi, it's confirmed there is leak. Check the unit if there is any oil tracing. Remove all gas and pressurize by nitrogen upto 300 psi and find the leakage with soapwater. Arrest the leak, vacuum and do gas charging.
Aug 18, 2012 | Amana PTC093B50AJ Electric Heat Air...
My Samsung HdTv will not come back on. Only a small red light next to the power button is blinking. First it was blinking six times then five now six again. Model TXR3079 or 8WHKXXAA. Samsung hdtv...
Hello, You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, If you need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where. power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement. Hope this will help to solve the problem
Aug 27, 2011 | Samsung Televison & Video
Hi I have a 32LG3000 TV and it is showing a flashing red light and will not turn on. I have pulled the plug out etc but no luck. Can you advice? Marion
You need to check the output voltages of the power supply to see which one goes off. It may be due to short circuits some where, if otherwise, power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care to solve the problem....
Aug 08, 2011 | LG 26LX2D 26 in. LCD HDTV
Kenmore microwave model 721.80409400 is noisy while operating like a loud 60 cycle HUM or BUZZ otherwise works OK
Sorry to read about your problem, I hope this helps you out.
you may have a magnetron issue, or these other issues
  1. Shorted HV diode, magnetron.
  2. Burnt carbonized food in or above oven chamber.
  3. Shorted winding in HV transformer.
  4. Frayed insulation on HV wiring.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore 80402 Microwave Oven
Maytag model GS2126PADW is tripping the ELCB. It will run for about one hour before tripping. After tripping, it trips the ELCB every time it is turned on. However if left off for an hour or so it can be...
The ELCB ( Electrical Leakage Circuit Breaker) is designed to detect any leakage of electrical current.
When the current leakage occurs, the ELCB then trips the electricity supply within a fraction of a second of the leakage being detected, before the magnitude of the current reaches a lethal level.
Therefore any possibility of serious injuries due to electric shock to persons who are in contact with the electrical appliance at that particular moment is minimized. Have a licensed Electrician check out your outlet and an Appliance Technician check your refrigerator if outlet proves okay.
Dec 05, 2010 | Maytag Refrigerators
The front load washer is less than 4 years old and has been leaking from the front door since we purchased it. Rust has appeared in front of the door and now has rust on the side due to leaks. I am afraid...
And so you should be. Anyone who continues to use an appliance around uncontained water is inviting electrocution..
I cant begin to fathom out Why??????????
Oct 20, 2009 | Kenmore 43042 Front Load Washer
Washer is working but is fusing partway thru a washing cycle?, if i put another fuse in it workes for a good time then fuses? vtyman
I had similar problem due to heating element furring up and shorting against side! New element fitted by engineer now OK - It also uses much more electricity with this problem. The old element looked like it was bent so could more easily have shirted out!
Jul 20, 2009 | Hotpoint First Edition FEW12 Front Load...
W640T2 (CIRCIUT BOARD)
I am a technician for Asko in Australia.The blackness on the motor control unit(circuit board) is probably carbon dust from the carbon brushes in electric motor.Likely problem is motor brushes have totally worn the armiture in motor or the MCU needs replacing due to earth leakage or short.Purchasing the parts from Asko should be no problem, but if you purchase and install electrical componenents only to find problem unresolved, you can't return installed parts for a refund. Also the breather hose from the detergent dispensor to outer tank can leak from tank connection when spinning load , and result in water running down outer tank and onto the electric motor causing circuit breaker to trip.....possibly damaging motor too. Goodluck!!
Sep 13, 2008 | Asko W6461 Front Load Washer
Dishwashers Logo
51 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
