Question about LG 37LC7D 37 in. LCD HDTV
Power goes on , no picture orn sound speakers work no video
  • 148 Answers
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this helped yopu (or not) please rate!, thank you.
Posted on Feb 03, 2010
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
No picture but the red power button blinks each time it blinks there is a thumping noise from speakers and a clicking sound
try checking the fuse area, together with the capacitor & resistor may one of them is faulty. and also check for any bad soldered.
let me know
Oct 31, 2008 | Haier HTF27R11 27" TV
Need to wire up a factory radio plug for 2003 chevy tahoe z71 with bose premium system. need to know what wire gose in what pin in the plug. SOMEONE PLEASE HELP ME!!! PLEASE!!!
Connector Part Information
12110088 (Except UQ7 w/o Y91)
24-Way F Micro-Pack 100 Series (GRY) (Except UQ7 w/o Y91)
15428074 (UQ7 w/o Y91)
24-Way F Micro-Pack 100 Series (GRN) (UQ7 w/o Y91)
Pin
Wire Color
Circuit No.
Function
A1
ORN
1044
Radio Class 2 Serial Data
A2
Not Used
A3
PPL
493
Rear Seat Audio Enable Signal (UQ7 w/o Y91)
A4
RED
1486
FM Composite Signal (UQ7 w/ Y91)
A5-A7
Not Used
A8
TAN
201
Left Front Speaker Output (+) (UQ3/UQ5)
A8
TAN
511
Left Front Low Level Audio Signal (+) (UQ7)
A9
GRY
118
Left Front Speaker Output (-) (UQ3/UQ5)
A9
DK GRN
1947
Left Front Low Level Audio Signal (-) (UQ7)
A10
LT BLU
115
Right Rear Speaker Output (-) (UQ3/UQ5)
A10
BLK
1946
Right Rear Low Level Audio Signal (-) (UQ7)
A11
DK BLU
46
Right Rear Speaker Output (+) (UQ3/UQ5)
A11
DK BLU
546
Right Rear Low Level Audio Signal (+) (UQ7)
A12
BLK/WHT
1851
Ground
B1
ORN
340
Battery Positive Voltage
B2
Not Used
B3
PNK
314
Radio On Signal (UQ7 w/o Y91)
B3
DK GRN
145
Antenna Enable Signal (UQ7 w/ Y91)
B4
BRN/WHT
230
Instrument Panel Lamps Dimming Control (w/ Y91)
B5
BLK/WHT
1851
Ground (w/ Y91)
B6
GRY/BLK
2334
Radio Mute (UQ7 w/o Y91)
B7
Not Used
B8
BRN
199
Left Rear Speaker Output (+) (UQ3/UQ5)
B8
BRN
599
Left Rear Low Level Audio Signal (+) (UQ7)
B9
YEL
116
Left Rear Speaker Output (-) (UQ3/UQ5)
B9
DK GRN/
WHT
1547
Left Rear Low Level Audio Signal (-) (UQ7)
B10
DK GRN
200
Right Front Speaker Output (+) (UQ3/UQ5)
B10
ORN/BLK
1546
Right Front Low Level Audio Signal (-) (UQ7)
B11
LT GRN
117
Right Front Speaker Output (-) (UQ3/UQ5)
B11
LT GRN
512
Right Front Low Level Audio Signal (+) (UQ7)
B12
Not Used
Oct 20, 2015 | Cars & Trucks
I have Sony tv kdl50xbr4 , had sound no picture.the tv had to turn on,off several times to have the picture!any help please
Dont know how much you like to tinker but or if you know someone. A TV has different circuit boards. One for power one for picture, one for sound, one for tuning. Power board works everything, picture board goes to to the tube, sound board connects to the speaker. Probably gettin kinda complicated all else fails have it repaired or upgrade.
Hope you find a solution that works best
Feb 04, 2015 | Sony Televison & Video
1998 buick regal stereo what are the wire color codes
showgif.do?image=73222
12110115
32-Way F Micro-Pack 100 Series (Blue)
Pin
Wire Color
Circuit No.
Function
E1
DK GRN
835
Entertainment and Comfort (E&C) Serial Data Communication
E2-E5
Not Used
E6
DK BLU
1796
Steering Wheel Controls Input
E7-E8
Not Used
E9
LT BLU
1405
Remote CD Changer Common Input
E10
ORN/ BLK
1406
Remote CD Changer Left Channel Input
E11
LT GRN
1407
Remote CD Changer Right Channel Input
E12
BRN
199
Speaker Feed-Left Rear
E13
YEL
116
Speaker Return-Left Rear
E14
DK GRN
117
Speaker Return-Right Front
E15
LT GRN
200
Speaker Feed-Right Front
E16
BLK/ WHT
351
Ground
F1
ORN
640
Fused Battery Feed
F2
YEL
43
Fused (Retained w/KP2) Accessory Power Feed
F3
DK GRN
145
Radio Switched Power
F4
GRY
8
Interior Lamp Dim Switch
F5
YEL
32
Fused Interior Lamp Dim Signal
F6-F10
Not Used
F11
BARE
2011
Remote CD Changer Drain
F12
TAN
201
Speaker Feed-Left Front
F13
GRY
118
Speaker Return-Left Front
F14
LT BLU
115
Speaker Return-Right Rear
F15
DK BLU
46
Speaker Feed-Right Rear
F16
Not Used
Dec 20, 2014 | 1998 Buick Regal
Hi....I need a wiring diagram for the stock amp in my grand am gt...its a 2003
Monsoon System Pinouts
Pin Wire Color Function
E1 LT GRN Right Front Speaker Output (+)
E2 TAN Left Front Speaker Output (+)
E3 GRY Left Front Speaker Output (-)
E4 LT BLU Right Rear Speaker Output (-)
E5 DK BLU Right Rear Speaker Output (+)
E6 BRN Left Rear Speaker Output (+)
E7 YEL Left Rear Speaker Output (-)
E8 BLK Ground
E9 BLK Ground
E10 DK GRN Antenna Relay Coil Supply Voltage
E11 ORN Battery Positive Voltage
E13 BLK Left Front Tweeter Speaker Output (+)
E14 YEL Left Front Tweeter Speaker Output (-)
E15 DK BLU Left Front Midrange Speaker Output (+)
E16 LT BLU Left Front Midrange Speaker Output (-)
F1 DK GRN Right Front Speaker Output (-)
F2 LT GRN Right Front Speaker Tweeter Output (+)
F3 PPL Right Front Speaker Tweeter Output (-)
F4 PPL Left Rear Tweeter Speaker Output (-)
F5 RED Left Rear Tweeter Speaker Output (+)
F6 DK GRN Right Front Midrange Speaker Output (-)
F7 ORN Right Front Midrange Speaker Output (+)
F8 PPL Gain Control Signal
F9 -- Not Used
F10 YEL Right Rear Tweeter Speaker Output (-)
F11 WHT Right Rear Tweeter Speaker Output (+)
F12 -- Not Used
F13 LT BLU/BLK Right Subwoofer Speaker Output (-)
F14 DK GRN Right Subwoofer Speaker Output (+)
F15 DK BLU/WHT Left Subwoofer Speaker Outlet (+)
F16 LT GRN/BLK Left Subwoofer Speaker Outlet (-)
or it is here 3rd one down
http://www.grandamgt.com/forum/forumdisplay.php?f=76
May 08, 2011 | Audio Players & Recorders
The Sound is really low, and sometimes the green light goes off by its self.
this could idicate a problem with the power side, in other words the inbedded transformer which most qaulity speakers do have. Changing it will ensure that the speakers do get enough power which will inturn increase sound quality.
Good luck and let me know of the outcome
Jul 04, 2010 | Logitech LS11 Speaker 2 Speakers
On outside compressor for whole house AC: Critters ate wires. Have Blk & Red power in from breaker. 24vac switched from thermostat. 1 contactor with 24vac coil(original). 1 Capacitor w/ 3 terms...
There should be a wiring diagram on the back of the access panel. If you can't read it, check online for model wiring diagram. Don't guess, you may cause more expensive damage.
Jun 25, 2009 | Heating & Cooling
Dell Monitor comes on but no picture
The monitor isn't getting a signal from the computer, which is why the power indicator goes orange. There are two possibilities:
1) The computer isn't operating correctly. It may not be starting up at all when you turn it on, and you have a "no boot" problem to solve, or
2) The computer is working properly, shows all the signs of normal startup (hard drive activity, Windows startup sound from speakers, etc.). but video isn't reaching the monitor. There may be a problem with the video card (or on the system board if it's integrated video). Or the monitor itself is bad and not detecting the video. You can test this by connectng a known good monitor.
Jan 16, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
LG 37LC7D 37 in. LCD HDTV Logo
580 people viewed this question
Computer Repairing
Computer Repairing
