Question about LG WM-2277HW Front Load Washer
I have a lg front load there is still water in the washer and it is flashing OE
  • 1,531 Answers
This is a drain pump fault code.the firstthing to do is use a wet dry shop vac and attach it to the end of the drain hose and remove all the water.
once the water has been removed you need to check the hose that are attched to the drain pump and look for anything that will dtop or block the pump.if you do not find anything inthe pum[ make sure you check the hose that runs from the bottom of the tub to the drsin pump its selft
Posted on Feb 03, 2010
What does OE mean when it's flashing?
Check PDF page 4 & 17 of this LG WM2277 Owners Manual
And check here other comments: lg-fl-washer-2277-oe-error
Hope helps.
Sep 02, 2011 | LG WM2050C Front Load Washer
My tromm LG front load washer is flashing OE, what is it.
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Jul 19, 2011 | LG Washing Machines
My washer has stopped it still has water and soap in it OE is flashing on the screen
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
Apr 05, 2011 | LG WM2277H Front Load Washer
My lg washer will not spin out it keeps flashing OE no matter what i do
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Sep 02, 2010 | LG WM-1832C Front Load Washer
LG front load washer OE error. cleaned filter need
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
Jan 02, 2010 | LG WM-2277HW Front Load Washer
When washing clothes my machine says oe and still has water in it
the OE flashing code means there is a drainage problem.
check hoses for Crimping or Clogging.
Hope that helped
Please Rate Me
George
Apr 29, 2009 | LG WM-2277HW Front Load Washer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
Error Message/OE
sounds like too much water is coming into machine.check water valve,and water sensor.it is bringing in too much water or not enough.
Mar 06, 2009 | LG WM1814CW Front Load Washer
My front load Tromm LG washer flashes OE message, won't drain or finish wash. Door does open
oe is an error code for pump problem disconnect power cord open small door on lower front of cabinet pull little tube out and plug from tube and drain water in to bucket after water is drained unscrew cap of pump to clear out any obstructions reinstall the cap and plug and give a test run
Dec 20, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
163 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
