SOURCE: turn signals /hazard lights don't blink
Hi! check first for any blown fuse. INSPECTION 1. Check for a burnt fusible link with an ohmmeter. 2. If a fusible link burns out, there is a short or some other problem in the circuit. Carefully determine the cause and correct it before replacing the fusible link. The fusible link will burn out within 15 seconds if a higher than specified current flows through the circuit.
SOURCE: turn on L blinker and
To fix this will require a new turn signal switch, this seems to be a common problem with these multifunction switches.
SOURCE: blinkers and hazards not working on Jeep GC
HI. the flasher is faulty or damaged. replacing this device will fix your issue.
SOURCE: hazards and blinkers not working
There are separate fuses for the turn signals and blinkers, but you should check both of them just to see if they're good.
You may have a burnt out turn signal bulb as well. I know that this sounds like an obvious answer, but a single bulb can sometimes disable the entire system because of the way that some flashers operate.
You could also have a defective turn signal/hazard light flasher. This is located under the dash board on the driver's side between the steering column and the door. You have to remove the sound insulation/kick panel (the cover on the bottom of the dash board) to reach the flasher (it is easy to remove - I don't think you even need tools).
SOURCE: My blinkers wont work but the hazards work. No fuses burnt out.
That would most likely be the switch itself. Fairly common
Two different circuits. Do all four lamps blink when you turn on the hazards? Does anything light up when you use the signals (dash indicator, front but not rear)?
