Question about Peugeot 705BK Wrist Watch
The analog portion of the watch has stopped working. I had a new battery put in but it only lasts a few hours then stops. Can this be fixed?
  • 10,865 Answers
Hello, yes it can be fixed. Here is the link to the company I use and like because they give you a free estimate before they start work:
http://www.watchrepairsusa.com/peugeot/watch-repair
Regards, Joe
Posted on Feb 03, 2010
I have a DKNY NY-1251 but i need the instruction to work it because it not working with new batteries. it was working but keeps on stopping
If it is an analog watch and the second hand moves a few time then stops and sort of twitches then the watch battery (even though new) may be bad. If not the the watch is dead and needs repair.
Jul 04, 2016 | DKNY Watches
Analog on digital watch not working
when a watch has analog hands and has digital portion, 9 times out of 10 it will have 2 batteries inside. A lithium battery and a normal battery. It is possible one died before the other. Usually the lithium (digital portion) lasts longer. Have the battery changed.
Dec 06, 2013 | Watches
I bought this watch 1.5 years back.I have started using that.It worked properly.For the last few months I didn't wear it.Now the watch is not working. So the problem is in the battery ?
On average, I've found that analog wristwatches that use a silver oxide (or alkaline) battery last about a year after a fresh battery has been installed. Digital watches, because they have no moving parts, will typically last longer on a set of batteries if you're not using the alarm or backlight function. Watches that use lithium batteries generally last two years or more between battery changes.
Based on your model watch, I would guess that your battery has run down too far to power the movement. A fresh battery will probably fix your watch. Hint: in the future, if you aren't going to wear your watch for a while, pull the stem out into the "set" position. That will stop the movement and extend the life of your battery. When you want to wear the watch, simply set the time (and date, if you have a date window) and push the stem back in.
Jun 27, 2011 | Armitron Now Collection Crystal Accented...
I have a Timex Ironman T563719J. The digital clock is working, but the analog portion has stopped. Any ideas?
There are two batteries in the watch. One for the digital watch and the other for the analog watch. The battery for the analog side probably needs changing but when the back is opened, you might as well change both batteries.
Jan 18, 2011 | Timex Ironman T56371 Wrist Watch
My first easy reader timex watch beeps every hour
mcdevito75 here, The beeping may mean the battery is weak, even if the watch is new. Look for a small watch repair shop in your area.
Jul 21, 2010 | Timex 27191 Wristwatch
I have a Movado Eliro Men's Black Dial Steel Watch which I received as a gift about three years ago. It stops running whenever I wear it. If I take it off and let it sit for a few hours...it starts...
It sounds like some portion of the circuitry has 'gone thermal.' As a test, set the watch in a sunny place and allow it to get warm; if it again stops, then the quartz oscillator section has become sensitive to minor increases in temperature.
This is not a DIY situation since the major part of the circuit will be on one IC and because of size and proprietary nature of it, it will require a pro to remove and replace it.
As a better watch, it might be worth repairing and I would check the manufacturer's website to see if they offer repairs; some better companies will do this free to protect their reputation.
You can start here:
Movado Service page
Sep 22, 2009 | Movado Eliro 0605377 Wrist Watch
The hour & minute hands on my pulsar nx14-x001 do not move. the second hand quivers, but also does not move. the digital time and other functions are okay. HELP!
Without knowing the model of the watch i would say you need a new battery. It is typical for this style of watch to have two batteries or one lithium battery. In either case the analog movement will drain faster than the digital portion of the watch and will stop working first.
Sep 21, 2009 | Pulsar Watches
I have an analog Fossill logo watch from my company. I notice recently that when I set the watch down flat, it stops. When I pick it up, it works. If I leave it down all night, it will be 8 hours late...
I would check the battery first, but I am going to put the odds on that it is a mechanical problem with the watch. It's not like in the old days when watches had a mainspring, where the power from the coiled metal was strong enough to push out any particals that got in the way of the gears teeth. Now they are all quartz, where any little piece of anything will stop the gears from running. If you haven't had this watch along time send it back via warrenty, if not it needs to be serviced.
Jun 27, 2008 | Fossil Watches
Peugeot 705BK Wrist Watch Logo
16 people viewed this question
Top Peugeot Watches Experts
mike hayward
Wahs Team
Are you a Peugeot Watch Expert? Answer questions, earn points and help others
