Replaced my projector bulb but will not power on
I have a polaroid polaview pv235 projector in which i have just replaced the bulb but the unit will not power on and i have no manual. please help
  • 111 Answers
Check to see if you got the lamp cover back on correctly sounds like a safty switch is open
Posted on Feb 03, 2010
How do I adjust for Keystone on polaview 340 projector?
There is a menu accesible also from the buttons and you can change it there.
Jun 04, 2014 | Polaroid Lamp for POLAVIEW 340 Projector
Polarview 211e
Go to:
System Preferences (you can get there by clicking on the Apple Menu in the top left corner) -> Displays -> Detect displays
After you click "Detect Displays" your G3 should automatically send the display image to your projector.
Feb 27, 2008 | Polaroid Polaview 211E Multimedia...
Dell dlp front projector model 2400mp parts
The bulbs are very costly and they have a short life as is. Stop replacing and get a new unit. The repair is not worth the cost and a new unit has a warranty for at least a year.
Feb 27, 2014 | Office Equipment & Supplies
Projector suddenly went unresponsive
open the bulb assembly and check if the bulb has fused / broken into pieces.if not then the ballast unit that powers the bulb is at fault and needs replacement
if the bulb has fused/broken , then probably the bulb that u had replaced 3 months back wasnt genuine!
Jan 18, 2013 | Panasonic PT-AE700U Multimedia Projector
After about ten minutes, it overheats and the lamp shuts off.
check all the fans and filters, make sure all the fans are turning properly and make sure none of the filters are plugged there is usually only 1 but there may be more.
Jan 26, 2011 | Polaroid Polaview 211E Multimedia...
Blue Screen
You may have inadvertently switched your projector to a different input mode, or the mhz refresh rate, etc., Jon.
Feb 15, 2009 | Polaroid Polaview 211E Multimedia...
Polaview 215 hook up to Windows XP to run power point program
hook up the vga to the monitor out on the computer and toggle the f4.
Sep 10, 2008 | Office Equipment & Supplies
RGB not aligned so I get thin red vertical stripes displaced to right of icons
If you are handy with allen wrenches, quality screw drivers, and the like, you might 'try' opening up the can of worms and gently manipulating the red LCD panel (it will be obvious--a magenta color when off), by slightly loosening the holding screws, then moving--ever so slightly, the panel untill the ghost disappears. Do not do this though, untill you mark the present position on the top and bottom of the LCD panel. Take pictures, far and close-ups, as you go so you can reassemble the unit. The typically three LCDs can be located by finding the prism cube, located under the circuit board, and just before the output lens. Be patient, and have fun. I did this with an 'out of wack' throw away, and now it is just as enjoyable as my 'dimmer' HDTV projector. Even side by side, from 8 feet away, when both are making 72" images, the HDTV is barely clearer, Jon.
Mar 31, 2007 | Polaroid Polaview 211E Multimedia...
Vertical control of viewing frame needs adjustment.
Did you try going into MENU --> PICTURE --> SIGNAL MODE, and then pressing > to go through all the signal modes? On mine, most of the signal modes split the screen weirdly as you described, but one of them (in my case XGA3, but I'm not using a Mac) looks right.
Nov 07, 2006 | Polaroid Polaview 211E Multimedia...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
