Question about Dryers
D5 (blocked coin 1 or coin drop control failure) is displayed yet the dryer is not coin operated
    Novelist:
  • 128 Answers
Try unplugging the dryer and wait 15 minuites and plug it back in. This should reset the computer.
Posted on Feb 03, 2010
I have a Maytag Commercial electric dryer in my home ,brand new sat for 2 yrs,got it to work 3 times,then quit.Computer panel was bad,replaced it,the model # is MDE22PRBYW0 not what's showing above
So then, you have purchased a computer panel that is designed for a "pay" machine., or perhaps for another model than you have.
(In that case, the "d5" would mean something else.)
Please look at "Sears Parts Direct" on your computer and see what they say as to your replacement panel part number.
What I do is then go to e-bay and search the part after I get the correct number.
I surely hope Sears will have the schematic for your machine.
God bless your efforts.
Feb 01, 2016 | Maytag MDE2400AYW Neptune Electric Dryer
Tip
Whirlpool Calypso Dryer Error Code Explanations And Repair
Failure - Code Condition - Check/Repair
PF - Power Failure - If the household power goes off and the control board was in RUN mode or PAUSE mode, the electronic control board will display a power failure error code.
E1 or E2 - Thermistor Failure - The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
  • When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
  • When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
  • 60 degrees F. - 15.3K ohms.
  • 70 degrees F. - 11.9K ohms.
  • 80 degrees F. - 9.2K ohms.
E3 - Touchpad or Software mismatch - Flashes when there is a touch pad or software mismatch.
  • This error code is displayed only in diagnostics mode.
on Jul 19, 2010 | Washing Machines
Speed queen commercial dryer model sdg109wf, the coin compartment is stuck because of compartment was full, after emptying the coin slider doesn't come out so we cant use the dryer. what is the...
Oh your bringing me back to the early days of my appliance repair career when i only serviced coin operated washers and dryers. Not in the coin box but the cover on top where you would get access to the timer is a bolt that holds the coin slide to the coin box asm. remove that bolt(if i remeber from 25 years ago its a 5/16th inch hex head and brass colored) and the coin slide will come out and then gotta kinda genlty presuade it in with a hammer so the coin will drop through or pull on the handle ya would push, to free it up and remove stuck coin
Aug 20, 2011 | Dryers
How can I adjust the run time per $1 on my maytag coin operated dryer. I would like it to run about 15 minutes per $1. Now is runs about 45 minutes on one $1.
Download this manual:
http://www.fowlercompanies.com/servicemanuals%5CMDG16SERVICE.PDF
The mechanism adjustments start on page 20. Note that the maximum number of slider cycles is 3. If you have a PD coin drop model the Max you can get is $0.75 per load I would have to assume that a different coin op mechanism may have to be used or one that will accept 2 coins per cycle for 2 cycles. On non PD models you can adjust the slots for as many as 4 coins per glide / slider cycle.
Thanks for choosing FixYa.
Kelly
Oct 20, 2010 | Dryers
E-1 CODE
Hello there
This code can sometimes be the e-1 or sometimes the e-2 here is the descrioption of what it means
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
80 degrees F. - 9.2K ohms.Dryer thermistor assembly
Jul 27, 2010 | Whirlpool GEW9200L Electric Dryer
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error code d5 on front load neptune washer
d5 is a door lock error code,more than likely a bad door latch it's an easy repair,here is a link to the Neptune repair manual this the Mah 3000 but they all come apart the same way the only real difference was in the control panel and the door latch in yours uses a solenoid to lock instead of a wax motor
http://www.applianceblog.com/manuals/MaytagNeptunenew.pdf
Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Commercial dryer coin op programming
Below is Maytag's commercial laundry website where you should be able to acquire the information requested.
http://www.maytagcommerciallaundry.com/content.jsp?pageName=CustServ
Jun 16, 2009 | Maytag MDE16PD Electric Dryer
Dryer stops soon afetr cycle starts, E1 appears
ensure lint trap is clean and venting is not restricted or blocked.
Feb 10, 2009 | Whirlpool GEW9200L Electric Dryer
I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
May 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
97 people viewed this question
Top Dryers Experts
