Question about Toshiba 2860 Copier
Toshiba 2860 Plain paper copier
After recently moving the copier, when powered-up the "replace toner" light comes on, and stays on. The toner container that was in the machine was full, but replaced anyway while trying to get the copier to work. Installing a new cartridge had no effect, and copying will not resume.
Thank you,
Chuck Young
  • 1 more comment
  • bebbley Feb 19, 2008
    Thank you canonman1 for your suggestion. I did fail to mention that I replaced the waste toner container at the same time that I changed the toner. The problem persist in spite of.
  • Anonymous Sep 09, 2008
    toshiba2860 does not copy am a technician tried to troubleshoot but have no good results all other functions working well and toner was replaced!
  • comment
    comment Nov 19, 2008
    Copier indicates that it needs toner, but toner is full, Excess toner jar is fine. From time to time it has worked, after off and on many times, but now hasn't worked in a week.
Make sure print is face up on the feeder and face down on the glass - mixing these two up would lead to "blank" copies.
Posted on Sep 17, 2008
Am technician working on toshiba 2860 does not copy sends out plain paper changed toner but no results heaters are working light on top shows its copying!
Posted on Sep 09, 2008
  • 86 Answers
It maybe the waste toner container is full try emptying it
Posted on Feb 19, 2008
Toner dumping straight into toner bag
use original toner OR reset toner indication
Sep 12, 2012 | Toshiba 2860 Copier
Toshiba 2860.. auto doc feeder keeps jamming.. seems like one side is feeing and other had side isnt or something similar. Any ideasa?
In any doc feeder, the initial two feed rollers and one paper separator pad/roller handle most of the paper transportation. So usually if you have misfeeds, and the paper is not crumpling up, you have a problem with worn or dirty feed rollers. However, if the paper is getting crumpled up, you most likely have a physical obstruction blocking the paper path. My recommendation for when this happens is to take a thick piece of card stock and manually feed it through the paper path on the doc feeder, this usually acts to unclog any jammed paper bits or debris.
-David.
Oct 30, 2010 | Toshiba 2860 Copier
How do i clean my Toshiba 2860 copier? When i print it comes out very dark and it gets just a little lighter with each copy. i emptied the used toner and cleaned the 2 corona wires. Is there anything else...
Your user manual should list a "Clean Drum" command on the menu of the printer. If you don't, you can purchase laser jet cleaning sheets at any office supply store.
May 15, 2010 | Toshiba 2860 Copier
Date of manufacture toshiba 2860
1997.
OPC drum life estimate 80.000 copies,Toner 7.500 copies,Developer replace every 80.000 copies.
Oct 07, 2009 | Toshiba 2860 Copier
Toshiba 2860-changed Toner cartridge-black line on edge of copy
Hi there
send a print / copy through the machine stop the machine via the main switch before toe paper has come out remove the drum unit
you should now be able to see part of your print on the drum if you can also see the black line check for obstructions in the light path if these seem fine the chances are the dev or cleaner blade seals have spung a leak ( time to replace the drum cartridge
Regards Al "alstech"
May 26, 2009 | Toshiba 2860 Copier
Light copies
prob because its low on toner-----I'm not even a tech but that would seem to the obvious answer
Apr 27, 2008 | Toshiba 2860 Copier
446 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
