Question about All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater
All pro heater turns on but won't light and shuts off after about 15 seconds
  • 77 Answers
It's supposed to shut off if it doesn't light off. Take the top off, and while staying away from the fan turn unit on and observe if there is fuel coming from the nozzle and spark at the ignitor. No fuel could be a plugged filter in the pick up tube. Unscrew the nut on the line coming from the fuel tank, the filter is in the top of the line. There is also a filter on the back of the nozzle accessed by removing nozzle and unscrewing it from the fuel tube. if there is a good fuel spray, but no spark, probably the high voltage transformer is bad. Most heater brands use the same transformer so take the old one with you to a heater dealer and have it checked/replaced.
Posted on Feb 03, 2010
  • mechanicix Dec 22, 2010
    I have a problem if you can answer it, I have a 60,000 but reddi heater its getting fuel and the glow plug heats up, but still wont fire and shuts down.
I have reddy pro 170 i plug it in , the fan & igniter comes on for 10 to 15 seconds then shuts off ,blew through fuel line and nozzle still same result, i do see fuel mist coming out nozzle ,i dont k
You must make sure the mist is not to close to the igniter . If it is it wont be misty enough to ignite. And make sure its in the path of the mist. If its new return it to the store.
Feb 07, 2015 | Reddy Heater Pro-Tough Kerosene/Diesel...
Fan shuts off after about 15 seconds of heat..
it don't come on at all when u turn the heater on
Dec 26, 2013 | Honeywell Heating & Cooling
I have an all-pro 200t torpedo heater. It works perfect with no fumes at all then it just turns off and there's a light that flashes next to the light it says flame. It seems that the heater won't...
IT MAY BE THAT THE FLAME SENSOR NEEDS TO BE EITHER CLEANED OR REPLACED, OR PERHAPS USE A COMPRESSOR TO BLOW THROUGH THE HEATER AS THIS MAY DISLODGE DEBRIS THAT MAY BE CLOGGING AIR FLOW CAUSING IT TO OVERHEAT THE THERMOCOUPLE THUS SHUTTING THE GAS VALVE OFF AS A SAFETY FEATURE OF UNIT.
Dec 24, 2012 | Heating & Cooling
OUR GARAGE HEATER RUNS FOR 10-15 SECONDS AND SHUTS DOWN
larrynsuepel,
All these type heaters (Reddy, All Pro and Master heat) were made by DESA international.
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains this common problem, where to get the repair parts and how to do the repair.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 25, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy pro155 runs for 3 to 5 seconds
Reply with the correct model number. "Pro 155" designates a series. We need to know whether you have a heater with a spark plug or a heater with an ignitor (glowbar).
Feb 01, 2009 | Reddy R155D Utility Heater
All pro 115k
This sounds like you will need to replace the thermostat!
That should fix this common problem!
Dec 20, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
All-Pro Kerosene Garage Shop Heaters - All Pro PK115T Forced Air Kerosene Space Heater Logo
2,101 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
