Question about Freezers
FREEZER TEMPERATURE UNSTABLE
TEMP FLUCTUATES -20 +2
LAST TWO DAYS OK -18, IF THIS HAPPENS AGAIN, ANY IDEA'S
  • Gary Davd
    Gary Davd May 11, 2010
    need model Number off the tag inside ref post it and we can see what to do
    Problem Solver:
  • 6 Answers
If assited check air circulation within cabinet.
check condenser if air assited, clear and clean if necessary.
failing that air probe might be dodgey
condenser fan ?
or thermal over load on compressor
Posted on Feb 26, 2008
Whirlpool Freezer WV1800NFW:temperature instable afther reposition the unit.
I am sure you mean Fahrenheit and not celcius. Unit should sustain Temp. F at around minus -20 to -15 F Not much you can do except to assure that your door is closing properly. As long as your food stays frozen, have a beer and enjoy life. Merry Christmas!
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 14, 2017 | Whirlpool Freezers
Why is the temperature fluctuating.
Service engeener always checks the average temperature inside freezer or refrigerator compartment. When you turn on freezer, the compressor starts to circulate gas through the system and the temperature in the freezer is decreasing (go to minus). When inside of the freezer reaches the set temperature the compressor is switched off and temperature will increasing. What will be the difference of inside temperature depends on the type of refrigerator and type of thermostat or sensor and moves to max. 8-9 degrees. With the advent of new "No Frost" refrigerator, this difference was reduced to only a few degrees Celsius, thanks to the fan inside the refrigerator and NTC sensor.
So 29 + 14 = 43; 43/2 = 21.5 which means that your average temperature of -21.5 which is not too much deviation from the set temperature of -18 and I think that is ok.
Dado
Jun 13, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Freezer losing temperature
Hi Julie. I'm Roger. It sounds like the operating thermostat is not working When not in the fast freeze mode. Can you here a click sound from the thermostat when turning the temperature up and down short of fast freeze? We normally charge them to operate at -10 to -20 degrees. The inside temperature will normally only reach a temperature around 18 degrees warmer. The operating thermostat should allow you to regulate its temperature any where from that capability up to where you want it. See if your thermostat makes a clicking sound when adjusted. The warning light comes on because it knows the box temperature is higher than it is set for and is warning you of that. If it uses a printed circuit (PC) board, the click will dot be very loud. listen closely. Let us know how this turns out for you. We have very good refrigeration techs. here. Someone else here may have an idea too.
Jan 23, 2014 | AEG Freezers
Freezer runs for approx. four days with operation normal. Then the temp. panel of front door displays a symbol that looks like a short L followed by a period. Then the temp. gauge and the interior light...
From what I read, the "L." that you see on the control panel indicated that the controls have been locked. According to the manual if you hold down the "alarm reset" button for 3 seconds the "L." will disappear allowing you to control the temperature again. I don't as of yet know what is causing your overall problem though...
Nov 04, 2013 | GE FUF14SVRWW Upright Freezer
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    Freezer defrost cycle
    If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
    If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
    It is probably on the rear near the compressor. Some are under the front behind the dust guard.
    Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
    Temperature swing specification in a chest freezer.
    It depends on the control that your freezer utilizes.
    If your temp control dial has the numbers 0-9 or 1-9, then you have whats commonly known as a coil temp sensor.
    Unlike an air temp contol that measure the air temp inside the freezer and comes on and off with a 3-5° swing, the coil temp sensor runs a little bit different.
    With a coil temp control or sensor, the temp control has a capillary tube and bulb that is inserted into the coil either at on of the ends down a guidetube or just into the center of the radiator type fins. This temp control measures the temperature of the coil, and not the temperature of the air inside the freezer. When the unit runs, the coils typically gets 20° colder than the air temp. And when the control satisfies (shuts off), it will not call for cooling again until the sensing bulb has reached the cut-in point which is typically well above design box temp.
    So, to quickly answer your question, yes it is possible to have a 25° temp swing and not have anything really wrong with the unit. That is how its been designed to operate and that is how it will operate. Your only option (although not recommended) is to replace the coil temp sensor with and air temp control. That will give you more consistent temps.
    Also, when taking temp of a freezer with a coil temp sensor, be sure to temp the product in the freezer and not the air temperature.
    Jan 01, 2010 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
    Temperature drop on freezer
    Sounds like the thermostat is erratic.
    Apr 20, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
    Freezer temperature swings
    the users manual does not cover this particular issue as to the temperature swing. I have seen some thermostats that are the "constant on" type that you are describing. No way of telling from the vague manual. As long as you are not storing ice cream for a long period of time, 0 degrees is usually fine for most home applications. Sorry I can not give you more info.
    Jun 24, 2017 | GE Freezers
    Kenmore Freezer Model 23041
    I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
    Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
    Freezers Logo
    168 people viewed this question
    Top Freezers Experts
    Dennis Boxerman
    Charles T Nevin
    Charles T Nevin
    AJMAL KHAN
    Are you a Freezer Expert? Answer questions, earn points and help others
