Question about Kenmore Elite HE5t Washer
F35 elite washer model 110.4778 - Kenmore Elite HE5t Washer
  • 92 Answers
Pressure switch needs replaced the small part with the black tube running to it.located top right after you remove top panel
Posted on Feb 04, 2010
Jimster
  • 240 Answers
SOURCE: What is the capaity of 2005 Kenmore Elite Washer and Dryer, models 110?
Starting in early 2002, the capacity sizes were changed around a little bit. A normal sized washer now all have the same sized tubs (pretty much) in the 110 series (Whirlpool Manufactured) washers. The capacity is now rated somewhat by the agitator action the washer comes with. Depending on the type of agitator you have, will determine the capacity. King size capacity means you have a pretty good capacity (size wise) than others. You have normal capacity, large capacity, super capacity, king capacity, and I even think they have canyon (yes canyon) capacity. Capacity sizes dont really mean to much though. In order for you clothes to get clean, the must have room in the tub to move. The must be able to float up, then get pulled down by agitator action. That should determine the size of what goes in the washer. Always use same type clothing when doing laundry (i.e. towels with towels, sheets with sheets, etc, this will keep the load balanced better). Watch what you load, comforters are ok (per manufactures ok) but I do not tlike the idea unless its a front loader, and only by itself. Let me know if this helps you out any.
Posted on Jun 01, 2008
SOURCE: My Kenmore Elite HE5t washer flashes SUD
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
Posted on Jul 04, 2010
blueextc3221
  • 15935 Answers
SOURCE: model: wfw9500tw01 f35 error
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Elite he5t steam washer gets F35 error code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Posted on Sep 26, 2010
craig6773
  • 116 Answers
SOURCE: We keep getting an f35
First of all, be sure you are using only HE detergant. Your drain filter is likely clogged and needs cleaned. On the front lower panel of the washer, remove the screws and panel. You will see a drain filter (about the size of a tennis ball). Before removing the drain filter you are going to need to hand bail the water out of your drum or all the water will run out when you remove the drain filter. Slid a plastic trash back up under the drain filter to help contain whatever water you could not bail out by hand. Remove the drain filter and clean it thoroughly. Replace the drain filter, replace the lower front panel and run a rinse and spin cycle. If sudsing error continues and you are using HE detergant, you may need to lower the amount of detergant you are using. However, 9 times out of 10, it is just the clogged drain filter.
Posted on Nov 26, 2010
Kenmore elite front load washer model 46752701 after replacing pressure control switch i still get f35 code
Most common cause for the F35 error code: Using non-HE detergent. Detergent slime builds up in the hose, eventually getting into the analog pressure switch and killing it. Make sure you flush out as much soap as possible and make sure to use HE soap or it can keep occurring, also some vinger can calm down the suds
Oct 26, 2013 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
Hi After a year of using my Kenmore Elite HE5T washing machine, Model #110 47789701, serial #CSW2733428 I am getting an error F35 and Sub. Could you please let me know how to fix it? Thanks Barb
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | Kenmore Elite HE5t Washer
Error code F35
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer. I am not aware of other uses of the F35 code on the various models. If you intend to diagnose and repair this problem yourself, I recommend resubmitting your question with the full model number of your Kenmore washer so that we can verify this technical information using your model number.
Jun 08, 2010 | Kenmore HE2 Plus Front Load Washer
Code F35 on Kenmore Elite HE5t front loader washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#$
Apr 09, 2010 | Kenmore Elite 45986 Front Load Washer
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
Sud/F35
if your using more than 2 tbl spoons of HE detergent, you WILL have the same problem with your new washer." sud "stands for TOO MUCH SOAP
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
411 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
