Question about Garmin GPSMAP 545s GPS Receiver
I need an Eagle EGP-1 or EGC-1 antenna module to mate up with my Eagle AccuNav 11 GPS. If none around does somebody have the specs. so I can have one made up. Cheers....Bryan
Eagle 462c will not power up
I called Lowrance and since Eagle has been discontinued, they no longer service them. However, they will offer to upgrade to Lowrance. I ended up getting a HDS-5 for $480.00. Not a bad deal since my Eagle was toast.
Sep 29, 2011 | Eagle Fishelite 642c Color Fishfinder Gps...
DX 2547 Only transmitting at 1 watt and swinging backwards on the power on high side from 4 watts to 1 watt.
Check the SWR reading on your antenna. If you have the wrong adjustment here, it is like having the wrong antenna, or none at all. You will need a SWR Meter, and somebody who knows what he/she is doing to help you.
Mar 25, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
Machine does not acquire its GPS position. If it does it can take up to 45 mins to achive. Can I put an external antenna on it? The unit is used in an open boat, so has clear access to the sky, so should...
your antenna is probably original and obsolete see if you have a RayStar 120, if so, it is junk. The RayStar 125 is plug and play for you and sells around 300. Your GPS is a self contained receiver, that means it uses 12 V and output computer language. If you have no power to the seatalk antenna, you get nothing. If it is intermittent as you describe, 90% chanace it is the antenna, (mushroom or puck). 847-746-0100
Dec 28, 2009 | Eagle Seacharter 502c Df Igps T/M, Hst...
Fish finder manual
hello there:
here is a link that will help you get the manual u need ok?
best regards micha
Eagle 250 DS - FishEasy GPS safe.gif Learn more about the Eagle FishEasy 250 DS before you decide to buy. Download User Guide and Manual ... fish finder EAGLE FISHEASY 250DS. www.bestfishfinder. ...
www.retrevo.com/s/Eagle-250-DS-GPS-review-manual/id/23493bh848/t/1-2 - 69k - Cached el
Aug 27, 2009 | Eagle Fisheasy 250ds Fishfinder
No backing light
Eagle only gives out a 1 year warranty on their products, so as far as I know you wont be able to get it fixed for free, but I would email them and see what they say.
Jan 15, 2009 | Eagle Fishelite 642c Color Fishfinder Gps...
Manuals
http://www.retrevo.com/s/Eagle-320-GPS-review-manual/id/517bh945/t/1-2/
Hit the Icon "GET MANUAL"
Nov 01, 2008 | Eagle FishElite 320 GPS Receiver
GPS module not responding
check the power connections to the antenna
Aug 23, 2008 | Lowrance LMS-330C GPS Receiver
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Marine GPS
change the antenna with new
Jan 12, 2008 | Eagle IntelliMap 500C GPS Receiver
Garmin GPSMAP 545s GPS Receiver Logo
75 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
