Question about Konica Minolta magicolor 2430 DL Laser Printer
Just installed printer and drivers via a network connection for Vista 32bit. I did this per the instructions Provided by Konica at ftp://ftp.minolta-qms.com/pub/crc/out_going/manuals/misc/km_vista_instruct.pdf Now my computer "sees" the printer but I can't print a anything. When I try to print a document Printer status shows "printing" for a few minutes; then changes to "Error - Printing" but no error codes or other useful information is displayed. May be an IP address problem? When I set the printer up I entered the IP address 10.20.220.22 as instructed in the Konica documentation. However when I printed the Printer Configuration Sheet (I did this from the control menu on the printer itself) it shows the IP of the printer to be something differents. Any ideas?
  • bobbygee2002 Feb 03, 2010
    The printer is connected to a four port Netgear router. I tried changing the printer's IP Address from the one given in the installation instruction to the one the printer's configuration sheet said was the IP of the printer.
    This did not fix the problem.
    Note: The configuration sheet also listed a subnet mask, a MAC Address, and other stuff that I don't have a clue what they are and are not changeable parameters in printer setup.
    I don't know what to do with the instructions you provide "The first 3 octet of the Printer should be the same as the router's. So
    the setup should be router->printer then router->computer. Can you give me a more detailed example?
    I used the Add Printer Wizard as directed in Konica's km_vista_instruct.pdf document referenced in the original email.
    Subsequent to my first email I tried changing the IP address from 10.20.220.22 to the IP given on the Printer Configuration Sheet which I printed from the printer itself. This did not sovle the problem.
    Master:
  • 149 Answers
Chances are that the port in the printer's properties is addressed to the wrong IP address. Go to Printers & Faxes. Right-click on that Konica-Minolta printer. Select Properties, & then select the Ports tab. Either add a new Standard TCP/IP port with the correct IP address as a Minolta Network Printer (Not as a Generic Network Card) or edit the port that is in use to reflect the proper IP Address.
Posted on Jun 04, 2010
  • 838 Answers
Hi welcome to Fixya.
How did you set the printer up, Is it Add printer wizard or other way.
Please clarify.
Thanks
Posted on Feb 03, 2010
  • Mohd. Tareq
    Mohd. Tareq Feb 03, 2010
    Dear if your printer is directly connected to router your provided IP address is wrong.
    Please do the following.
    First of all go to Start Menu in your PC. Select Run> Type CMD. Now type ipconfig, check what is default gateway address, It's may be192.168.x.x [.x.x stands for unknown numeric digits, which varied by router e.g. in DLink it's 192.168.1.1 or in Simens it's 192.168.254.254] Default Gateway Address means the IP Address to access the Routers Configuration Page and it is the physical/permanent address for router. So for all other connections to the router will start after this number[e.g. 192.168.1.2 or 192.168.254.255 etc] which are limited upto 150 IP's/connections.
    If the printer is directly connected to router, Open the router configuration page. Check in DHCP Clients....What is your Printer IP is showing....Try to access the printer with that IP. Set it as permanent IP for that printer. Now follow as you found on Km_vista_Instruct manual. But in place of 10.20.220.22 type in 192.168.x.x whatever IP you set for printer. and subnet mask will be 255.255.255.0...Now follow the rest of manual.I think you got my answer.
    If the Printer is directly connected to the PC. simply install the printer driver by Found New Hardware Wizard [If pop-ups] or Run the driver CD only and Install the driver. It will work surely without any issue.
    Again if the Printer connected to a PC , And you want to use it on another PC without Plug In/Out, Just go to the PC where the printer is connected. Open the folder Printers & Faxes > right click on the Printer name that you want to share/use on another PC> Just select the option Sharing and click Share the printer also put a sharing name so that you can find the printer easily on network.
    Remember in Vista First you may require to Printer Sharing:On in Network setting [Go to Control Panel>Network and Sharing Center > check in Sharing and Discovery > Put the Printer Sharing:On] Save all the setting in the PC that you connected with printer.
    Now go to the client PC . Open Printers , click on Add a printer >choose 2nd option Add a network, wireless or Bluetooth printer. Then there will be a list showing the name of printers. If your shared printer name is there select it from the list> Click Next > Click Finish. Again if the printer is not in the list click on The printer that I want isn't listed > choose 2nd option and type in the IP address of that PC where the printer is connected directly[e.g. \\192.168.1.3\Konica_minolta\ or e.g. \\192.168.x.x.\printer's sharing name\] Click Next if your sharing name is correct with IP. you are done.
    The one Konica Minolta instructed is for print server type.
    Let me know please if you want that also.
    Thanks
    Novelist:
  • 153 Answers
I presume that the IP Address in the instruction is just an example IP Address. I don't know if your printer is connected to a router or to a Hub or Switch, but your printer's IP Address should depend on the device that provides the IP Address and the example is router. The first 3 octet of the Printer should be the same as the router's. So the setup should be router->printer then router->computer.
I have "windows vista 32bit
you will need to install the driver for your printer for it to work.....you would have been provided with a cd with the drivers to start with.use that cd and install the driver
Apr 19, 2011 | Office Equipment & Supplies
Is there a driver that will work with windows 7?
Go to "download drivers" site and type in Driver for Konica Minolta PagePro 1350W printer and look for its drivers. Download the driver for your printer.
Jun 08, 2010 | Konica Minolta PagePro 1350W Laser Printer
Printer Sharing for 32os and 64os
I am not sure I follow. If you are attempting to share a printer over a home network between computers with different OSes, perhaps you could try this:
If the printer works already with Win7(32bit), go to the Vista computer and try the following:
Go to Control Panel. Choose printer. Then choose Add Printer. Choose Add a local printer. Click on Create a new port. The default in the drop down box is Local Port. Do not change that. Click Next.
A dialogue box will appear asking for you to enter a port name. Type in the \\computer name\printer name
Dec 05, 2009 | Computers & Internet
Computer can's see Print Server in Add Printer Wizard The WGPS606 installation -- part 1 -- seemed to go fine. It sees our wireless network, we assigned it an IP address, it sees the printer connected to...
Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
Regards gaz
Sep 28, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Install lexmark x4650 with provided CD,it wont print or connect w
Make sure the software you are trying to use is Vista compliant and even more so that you are not using a 64bit version of vista because a 32bit application will have issues running in that environment.
Jun 23, 2009 | Intel Anypoint Network Adapter
Installing AR-Sharp 5316E on Vista OS
According to sharp information the 5316e is not supported by Vista, the 5316n version is ( N for networking). They would require different drivers because they are different in the way they print. However, here is a link for a vista driver for the "E" version. This is for 32bit vista and not 64bit.
http://esupport.sharp.at/html/driver/DataOutputDetail.php?TemplateLang=en&ID=3758
You are more than likely going to be connecting to the copier with a USB cable. Install the software first and plug in the USB cable.
Hope this helps.
Apr 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have a 9320 One Touch Scanner and can not find the drivers for Vista. This is creating much frustration as I had purchased the scanner new and can not use it. If possible please point me on where to...
System Requirements PC Microsoft Windows 98 SE, 2000 Professional, ME, XP:
Pentium Equivalent Processor or Higher
64MB of RAM (128 MB Recommended for Windows XP)
200 MB of Available Hard Disk Space
CD-ROM Drive
USB Port
Color Monitor
I do believe the scanner does not support windows vista as of yet.
Printer / Scanner
HP Deskjet 6940 (via Network, auto driver) (32-bit)
HP Laserjet 5L (32bit)
hp color LaserJet 2550L (32-bit)
HP Officejet 4200 (32-bit)
HP PSC 1401 All-In-One Printer (32-bit)
Lexmark 240N (Native Driver x64).
Microtek Scanmaker 3600 (32-bit)
Samsung ML-2010 monochrome laser printer (32-bit)
Epson R220 (32 bit)
Brother HL 1030 works after adding a printer manualy and installing as a brother 1430 (32bit)
Dell Photo AIO Printer 964 (32-bit)
HP Laserjet 4plus (32bit)(64bit) with HP Jet Direct as LPR on Standard TCPIP Port
HP DeskJet 845c (32 bit)
(supported printers/scanners)
Apr 20, 2008 | Office Equipment & Supplies
Pagepro 1350w install/print problem, vista document stuck in queue,error
Go to control panel, printers, right click the pagepro and select properties. Click the ports tab and make sure that the port is set to a USB port. This did it for me.
Mar 17, 2008 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta Di1610 can't print
hello
is it conect via net or parall port?
have you try to detect the printer by its ip ?
(ping)
pini
Feb 14, 2008 | Konica Minolta Di1610 Copier
Unable to use printer over network with Server 2003 64Bit
Probably the best and easiest solution for your problem would be to buy an EDIMAX USB-Ethernet print server, or something equivalent. I have several of these running on the network at work. They're easy to setup and they work great.
Nov 11, 2007 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta magicolor 2430 DL Laser Printer Logo
374 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
