Question about Amana 3.2 cu. ft. Top-Load Washer
How do you change the drain hose on an amana washing michine
Howdoes the existing drain hose come off the back of the amana washer??
  • 10,865 Answers
Hello. The existing drain hose is a friction fit held in place with a wire clamp. Use a pair of channel locks or pliers to slide the wire clamp about 6 inches up the hose and then work it off of the fitting it is attached to. If it has been there for a long time you will find it useful to warm up the drain hose with a hair blow dryer. Regards, Joe
PS - kindly rate my answer. thank you.
Posted on Feb 03, 2010
My amana front load washer, model NFW7200TW won't drain it gets down to 8 min of cycle and stop and display nd code. Check pump, fine also I can open washer door when it get stuck in this mode
remove the drain hose from back to see if there is any foreign object stuck in there , if washer faults out on code its common for door to unlock
Aug 16, 2016 | Amana Washing Machines
I washed a rubber backed rug in my Amana NFW7200TW front load washer, wasn't thinking. now washer will not drain, is there a filter filt that could be clogged?
yes you have blocked the drainage system sorry i am not sure if there is a filter on this mach. disconnect mach and take the drain hose and try puttind it into a basin failing that carefully tilit machine back and disconnect the hose from the base of the mach to the pumpthis will allow mach to drain but you will still have to clean out the pump hope this helps .
May 09, 2014 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
My Amana Washer wont lock
Here's a video darrell r waggoner suggested as a solution to your problem from YouTube:
Drain Hose (Pump to Back Panel) Replacement (part #W10358149) - Whirlpool/Kenmore Washer Repair
Feb 24, 2013 | Amana 3.2 cu. ft. Top-Load Washer
I need to replace drain hose on an amana top loading washer. Is it easy to take off or is it connected to the drain pump? It is connected near the top of the washer. there is plastic around the whole where...
The connection for the drain hose is always directly to the pump outlet
You need to loosen off the top connection after removing the screws in the back panel
The panel will then slide over the hose (The plastic is there to stop it chafing )
The hose is held onto the pump with a clip , on some it is a screw type on others what is called a Cordbin clip which you need a pair of grips to remove or proper Corbin Pliers
Dump the hose into a bucket and tip the machine either forward or backward to get the maximum water out of it before you undoe the clips
Nov 29, 2009 | Amana Washing Machines
New Amana dishwasher leaving (dried) food particles on the dishes/not cleaning well
CHECH YOUR DRAIN HOSE. IT SHOULD HAVE A HIGH POINT SO THE DRAIN CAN DORK PROPERLY. THE HOSE COULD BE TOO LOW UNDER THE SINK AND DRAINING BACK INTO YOUR DISH WASHER. OR YOUR GARBAGE DISPOSAL HOLE CAN BE CLOGGED
Oct 28, 2009 | Amana 24 in. ADB1500AWS Stainless Steel...
Amana washer machine will not hold water. The drain hose is fine. What esle could be wrong?
The drain hose could be stuck too far down the drain pipe allowing it to siphon the water out.Also if it seals too tight into the drain pipe it will siphon the water out.
Sep 07, 2009 | Amana NAV5805A Top Load Washer
Can't remove front panel on Amana washer
access through the back panel about 10 screws. Its likely the drain pump or one of its hoses.
Aug 23, 2009 | Amana ALW480DA Top Load Washer
Amana top load washer fills with water and will not stop filling
Hi...
You need to check this
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
Good luck !!!
Regards
PCmania
Jul 07, 2009 | Amana Washing Machines
How can I change the drain hose?
Hi, The lower front panel comes off and then you can see the drain hose attached to the pump. Part # 40053901 @ $19.95 for the long drain hose. I hope this helps. If I can assist you further, please let me know. You can find this hose on my web site www.whirlpoolpartssurplus.com
Vic
May 19, 2009 | Amana NAV3330AW Top Load Washer
Amana 3.2 cu. ft. Top-Load Washer Logo
181 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
