Question about Toshiba Televison & Video
I have a toshiba ct 9939 remote. the buttons have lost sensitivity. how do i open the remote to clean the contacts?
  • 1 more comment
  • sain356 Feb 03, 2010
    Thank you for your prompt and thoughtful response. I had the same thought, but when checking in the battery compartment (2 AA batteries), there is absolutely no evidence of any screws. I can not figure out how to get to the circuit board.
  • Anonymous Mar 15, 2014
    Some buttons have stopped working. I need to know how to open the remote to clean the contacts
  • Anonymous Mar 19, 2014
    I want to prise the case open to clean the contacts - any ideas?
  • 148 Answers
Check for and remove any screw(s) in the battery compartment. Then try gently prying the two sections apart. When seperated remember where the rubber buttons (buttons are usually one single, rubber like, pad) were seated (most the buttons will only fit one way, or you will remember where they were located just by looking at it). on the remaining cicuitboard in the other half of the casing, you will see numurous black dots, these are what the rubber buttons push to make the connection that will execute the command you are trying to give your tv. With a q-tip, slightly moist (no cleaning agents!), gently brush these black dots a few times. Gently rinse the rubber (buttons) pad under luke warm water ( no cleaning agents!) taking detail to the underside. A slight cleaning will be plenty to improve the functioning of the remote. Make sure to let the parts COMPLETELY DRY before installing them back in the remote!
If this helped you (or not ), please rate, thank you!
Posted on Feb 03, 2010
Control
1) tight the springs contacts batteries with pliers, for better contacts.
2) clean the contacts batteries.
3) open the remote control and clean the Keypads from oxide, dust, and special spray contacts or alcohol.
4) Reset the code again, and try it. if the problem persist, go to the repair shop TV for fix it.
God bless you
Jun 20, 2012 | Toshiba Rem48tvb Remote Control
THE POWER ON/OFF BUTTON DOES'T WORK
hi,
your remotes power on button have some problem. may be its carbon tracking may faulty. just open the remote. take out its board. clan the carbon contact side with a cloth. also clean the underside of the on/off button. re-fix it and test again.
ok
Dec 21, 2010 | Toshiba CT-90157 Remote Control
You have to press the buttons extremely hard
Hi:
This is due to poor contacts inside the remote, if the remote is old then the contact pads may be worn, if it is fairly new then you may of wasted something on the remote and the contacts needs cleaning.. If you open the remote and remove the main board and the keypad clean the tracings on the remote with some achohol also the keypad also..
Nov 09, 2010 | Toshiba CT-90159 Remote Control
My remote control is a model CT-90233. Several of
your remote is old and needs to be cleaned and rebuttoned(you can do this yourself) open up the battery panel and look for small screws to take of the case. you need to dust it out with compressed air. and reline the buttons. when you push down on the power button it probbaly is not making complete contact with the button, take a small thing and poke the power button without the buttons on. see if that works. if it turns on right away with direct pressure to the power switch then you just need to make sure your buttons are making complete contact. if that dont work then your circuit is screwed. you need a new remote or a new tv.
Feb 16, 2010 | Toshiba 32A30 32" TV
Programing my toshiba ct-90157 remote to a sanyo dvd player
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 11, 2009 | Toshiba CT-90157 Remote Control
I can't program my Toshiba TV to the CT 91507 remote
change battrries and select our old remote control codes
Jan 19, 2009 | Toshiba CT-90157 Remote Control
Toshiba Remote CT-877 problem
I contacted Toshiba. Take out the batteries. Press every button on the remote. But the batteries back in. The remote will work because you just reset it.
Jan 10, 2008 | Jensen SC-340A Remote Control
Toshiba ct-90233
Here is a link to your manual:
http://remotes.com/remotes/documents/Toshiba/CT-90233.pdf
Oct 02, 2007 | Toshiba CT-90157 Remote Control
Toshia CT-90157 remote is not working!
Here is the product information for your remote: MODEL: CT90157 PN: 23306517 MODEL: CT-90157 PN: 23306517 23306495 this remote has the pic size button Originally supplied with models: 32A33, 32A43, 32AF43, 32AF44, 35A44, 35AF44, 36A43, 36AF43, TOSHIBA Used with models: 13A21, 13A21C, 14AF43, 19A21, 20A42, 20A43, 20A44, 20AF43, 20AS21, 24AF43, 24AX61, 27A43, 27A61, 27A62, 27AF43, 27AF44, 27AX61, 27AX61C What is the correct model# for your set?
Sep 22, 2007 | Toshiba CT-90157 Remote Control
Televison & Video Logo
745 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
