Question about Philips Magnavox 51MP392H Rear Projection Television
I was cleaning the lens to the red gun. there was a bubble on taking it apart the coolant spilled out so i changed the coolant now the tv flashes red on the power button how do i fix it
  • dollsexy57 Feb 03, 2010
    half of it by the red we bought crt coolant from mcm electronics and put in thru the plug yes we did have it unplug
  • dollsexy57 Feb 04, 2010
    blinks 9x and has a 3 second pause in between each set of blinks
  • Philips Master
  • 5,138 Answers
Take some rubbing alcohol and where the coolant fuild spilled out on chassis clean real good, you can feel it with your fringers its a oily feel. let dry then try TV again.
Posted on Feb 04, 2010
  • 4,889 Answers
How many times does it blink in between each pause? This is diagnostic code that helps us figure out what the problem is. Please provide this info so that we can continue troubleshooting.
Sai.
Posted on Feb 03, 2010
  • 1,476 Answers
When the coolant spilled out did it get on the rest of the circuitry? How did you refill and seal the coolant tank and what did you use for coolant? I would need answers to these questions to be able to help you further. Did you unplug the set yet?
hardrocko
  • Kim Yearick
    Kim Yearick Feb 07, 2010
    Phillips is new to posting error codes on their sets.I encourage all manufacturers to do this but they need to supply the techs with what the codes mean. Sony and several others have done that and it is very helpful. I do not know what the blinks mean. I have searched the internet and cannot find an answer to the question. I would concentrate on the board which had the liquid spilled on it. It probably is the most likely area to have a short or a bad component. Look for resistors that have discolored. If you have the skills it may pay to check the power supply for correct voltages. Perhaps you have lost one of the voltages, or more. Check this out and get back to me.
    hardrocko
I took the back of the tv off and the blue lamp is not bright like the red and green. Could this be a coolant problem or lamp. I have the PT5492S Akai rear projection TV.
The blue is usually dimmer than the other two lens; what I would suggest is try to look into the lens with the set on; BE CAREFUL AND NOT TOUCH ANYTHING INSIDE THE SET.
If the red and green show a picture but the blue looks like a floodlight you have bad Glycol in the blue tube (common in these sets).
If all have a normal picture remember to wipe the lens clean at the top; do not try to take the lens etc apart.
Before you rate this information let me know what you find.
SD TECH
Aug 15, 2011 | Akai PT5492S 54" Rear Projection...
I have a phillips 55pw9363 my picture is hazy. It does not change when I adjust the brightness.
Tv pictures and screen brightness are dulls and have a halo glow to it wright?Yes.The tv CRTS TUBES guns have a chemical call CRTS TUBES coolants are contaminated require changing.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a chemical coolant kit to replace it.Kit also came with a tutoring DVD disc showing u how to replace the CRTS TUBES guns coolant chemical.
Apr 03, 2011 | Philips 55PW9363 55" Rear Projection...
I have a Hitachi projection color tv and I cannot get the color adjusted good especially the red. Can you help me?
U know how to solders?Ur convergence it dead,need it replaced parts,by buy convergence kit.Tries Tv repair World.com,Tvrepairkits.com.
Dec 20, 2009 | Hitachi 43UWX10B 43" Rear Projection...
I have a philips HD rear projection TV 60 in. inside there are six adjustment knobs. Three are color the other three are for brightness contrast and hue. Which is which Left to right
If yours is a rear projection TV the adjustment knobs on the focus block inside are screen (red, green, blue) and focus (red, green, blue). The ones you are referring to as color are the screen controls and they adjust the intensity of the color from each tube. The other set adjust the focus of each color. They are also not intended to be adjusted by the user. Unless major components have been changed these controls should not need adjustment. That is why they are inside the TV.
Dec 05, 2009 | Philips 60PP9352 60" Rear Projection...
TV appears blurry, and when using the remote to solve remote and buttons on tv are not allowing to re adjust colors for a clear pictue
Read Each Step Completely - Make Sure 3 Color Guns Are Off And Cool -
1. Remove Rear Dust Cover 2. Remove the Front Speaker Cover May be Held In By Plastic Pins and or Anchors on the Bottom Note" - Remove The Plastic Cover Just Above Speaker Cover Maybe 2 Piece. Remove The Screws Holding Top Of Speaker Cover. Then Pull Toward You the Bottom Maybe Anchored So Lift Up. 4.Once Speaker Cover Removed, May Have Screws Just Below Center Plastic Cover Remove Them, Now Remove Center Cover Between Speakers -NOTE" Do Not Touch, Move Any Color Convergence KNOBS" - Lift Front Screen UP - Towards Roof - It Has 3 Flex Grab Anchors On Top And 2 Pins One On Each Side Of TV Frame. - NOTE" Lay Screen On Floor It Is Plexi Glass So It Will Brake If Bent Or Drop Hammer On. NOTE"- May Have To Remove plastic Cover Frame positioned Around Front Screen And Then Remove Screws. 5. I Use Windex Glass Cleaner And Either Cotton Balls Or White Tube Sock On Color Gun Lens Covers And Clean Mirror Like The One In Bath Room. 6. Take White Sheet Or Bead Spread And Anchor On top Of TV With Weights, Stretch Around Each Side Of TV Use Chairs To Anchor On Each Side Of TV. Place Dust Cover Or Heavy Card Board Where Plexi Glass Was Positioned. 7. Turn On TV - go To Rear and Now You Can Adjust Colors Brightness And Low Light - High Light - Horizontal - Ect....While Looking at Picture. 8. Install In REVERSE - Order Just Wipe Color Guns Lens Last. Note" - If you have Wet/Dry Vac or Fan Or Blow Dryer Take A 2 - to - 3 Inch Paint Brush And While Brushing Circuit Boards Any Dust For That Matter Blow Dust Off And Out Even Brush Speaker Cover"...ECT...Do This Before Any Cleaning 9. Just A Thought If You Ever Want to Change Color Gun Cooling Oil - Wrap All Circuit Boards With plastic Bags And then I use Bath Towol And Paper Towols To Catch As Much Spill As I Can And Then Spray With Windex To Make Dry While Blowing Air Onto Spill - Also I have Found Clear Mineral Oil Like Johnson Baby Oil To Work As Well If Not Better Then Glycol Oil. I Get For $2.50 For 20 Oz Bottle.
Nov 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Every thing on the tv is mostly blue
Nov 20, 2009 | Hitachi 51G500 51" Rear Projection...
I just got a 92 Toshiba and the red was a little off on the left side. So I took the screen off and tried moving the red lens and this liquid came out and now my tv wont turn on. Can anyone help me get my...
YOU HAVE TWO PROBLEM NOW,YOUR FRIST PROBLEM WAS A CONVERGENCE.PROBLEM,CORRECTION SHOULD HAVE BEEN CORRECTED.ON YOUR CONVERGENCEBOARD.NOW YOU WILL NEED TO ORDER A BOTTLE OF COOLENT ,TO REPLACED THE COOLENT THET YOU SPILLED WHILE TRYING TO ADJEST YOUR RED GUN.AND MOST LIKELY YOU SPILLED IT ON YOUR MAIN BOARD AND CREATED A SHORT.
Oct 13, 2009 | Toshiba 50H82 50" Rear Projection...
94 Volvo 850 turbo still running hot
Do the air purge test below.
The fins/turbine on water pump can be totally worn out.
When the car is completely cool,check the electric fan(s) for smooth rotation.
Clean/check/change the thermo sensor,contact and wire.
Excavate air pocket in coolant system / check for head gasket leak
This test will kill two birds with one stone.
MAKE SURE THE COOLANT SYSTEM and ENGINE IS COLD!
RAN THIS TEST IN A WELL VENTILATED AREA ONLY!
You will spill some coolant during this air pocket purge test.......BE KIND TO THE ENVIRONMENT and ANIMAL please clean up after the test!
Put the front end on a pair of ramp or park your car on a VERY STEEP HILL (radiator facing top of the hill) .
Top of the coolant reserve tank
Let it ran for 10-15 minutes.
Monitor for air pockets escaping from coolant reserve tank.
Small amount of bubbles is OK at 1-5 minute mark
After the thermostat open up (after 195 F warm up) at
5-12 minute mark or after high idle you should see less bubbles.
If you do not see any in rush of bubbles then your thermostat may be partially stuck or rusted badly inside the thermostat hosing.
Give the thermostat host few gentle taps.
If you see larger bubbles surfacing after 15 minutes then should do a hydrocarbon (HC) dye test to test for potential head gasket leak.
Let engine cold down and top off coolant reserve tank.
Start monitor for coolant lost
A coolant flush is require every 2 years or 24,000 miles.
I recommend the thermostat that has a relief pop-let to reduce the change of burst radiator and coolant hoses.
Make sure you get a new thermostat gasket,black RTV and fresh coolant for the job.
Please post more information by clicking the comment link on the top right corner.
DON'T FORGET to RATE ME if my tip is helpful to you!
Sep 15, 2009 | 1986 Volvo 740
Problem with Panasonic 47'' HD Projection TV MN: PT47WX53G
You can get a bottle of replacement CRT coolant at the following link. But the spilled coolant will need to be thoroughly cleaned use denatured alcohol and let dry thoroughly as the coolant is corrosive and will destroy the solder, Components and traces of all items affected if not thoroughly cleaned.Heres where to get the coolant for the CRTs.
http://servicemanuals.vstore.ca/index.php/cName/prjection-tube-coolant/osCsid/a71095f09804ab9fe52939c4fa517cfa
Jul 23, 2009 | Televison & Video
Fluid Mold
yes it more than likely is related to the spill.
this model is famous for fluid leaks. each projector1.gif tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
this depends on how bad the damage is in the tv. in most cases we can reseal the tube and clean up the fluid 400-600.
Once you
take the tube out you will see where it leaked. The problem is that the
frame on the CRT that the heavy screws with springs are mounted on (that
hold the lens coupled to the CRT) is weak and they can bend. We have seen
several that have leaked after the customer moved the set. You can only
tighten them down so much because the frame bends. It is just stamped metal
and not welded at the corners to support the bend.
We remove the CRT, clean it all up, add a very small amount of RTV sealer to
the gasket, reassemble, let the RTV cure thoroughly and refill with coolant.
The extra sealer should prevent future leaks. Haven't had a recall yet.
Mits says replace the CRT...too costly.
You msut check the yokes carefully as well. If any coolant gets into them
you can end up with shorts there and a mess.
Clean the boards carefully and repair any corrosion damage. The coolant is
ethylene glycol and glycerine which is water soluable.
Feb 08, 2008 | Televison & Video
Philips Magnavox 51MP392H Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
