Question about Compaq (252608-001) Motherboard
Prob with compaq motherboard
I m having compaq pc previously it was working fine recently facing error i m not able to install os like windows9x/xp/2000 while installation of win 98 first half installs properly when 10 mins left for the completion getting hanged pc...tried with all other options....replacement of ram,hard disk drive,smps,cmos battery but prob remains same....
Any idea or solution regarding dis kind of problem....
thanks in advance
  • prasadjoshi Feb 19, 2008
    thanks for the assistance
GOT COMPAQ Evo with motherboard MS-6541 2.1version.There is no HDD in the PC box. Which types of HDD will you suggest can work with it?
Posted on Jul 24, 2008
    Novelist:
  • 69 Answers
My name is Vikram Kumar Thumu, I have seen your issue and would like to provide my solution on the issue...
Well, this is an issue that could happen with failure of Hard Disk Drive or Mother board type that you are using..
I think, this is to do with Motherboard specifications, since few Mother boards type or model will not support for Lagecy OS like WINDOWS 95/98.
Hence you to need to check from that point.
I request you to let me know the more information like Computer Model number and S/n and P/n number so that can research on the issue and provide you more information.
if you have any queries please mail at thumuvikram@rediffmail.com, I'll be glad to assist you..
Thank you.
Bye,
Vikram Kumar Thumu.
Posted on Feb 19, 2008
Hi I have been trying to connect Mblaze plug to serve to my Dell laptop but it is giving me error as "cannot access serial port, make sure you have appropriate permission ". Previously,it was...
hello ,
nothign to worry about , you just try to change the usb port , i mean try a different usb port on your laptop it will search for the drivers and it should work , still if you are facing any problems ,goto control panel -add/remove programs uninstall your mblaze software,,then re insert your device it will again install the software and this will definately solve your problem .
Regards.
Jan 06, 2011 | Dell Latitude D600 Notebook
HI i am facing probs whenever i start my laptop;and open any folder on screen;it gives a msg To delete the folder and move to Recycle Bin and it does not goes.I am very frustrated
If the problem appeared recently, then you can use System Restore to restore your OS settings to a previous date (if System restore is activated on your system) when everything was working fine. If problem still persists check for stucked delete button on your keyboard (in case you receive Confirm file delete window's message).
Sep 06, 2010 | Computers & Internet
I am trying install winodws7 on HP Compaq 610 having ATI Radeon Catalyst(Current OS winXP Pro SP2). But in the installation window it is showing the CD/DVD driver missing message. So, googled it and found...
Hie there i have installed and reinstall Win 7 Ultimate on Multiple Compaq 610's without any problem.
i once encountered a prob like this one but was lazy so i removed my Hdd and formatted it elsewhere and Walaa my prob was gone. i didn't have to upgrade or downgrade my bios and am still using the same laptop 2day. Just make sure you DVD rom aint damaged.
good luck
Aug 06, 2010 | HP Compaq 610 T5870 156 WH248UTABA...
Error showing media device is not found using XP , presariov3000
the drivers might need to be a 32x 64x or check with the product sightand look for pruduct support / drivers-downloads check for you model type and re-download drivers and install but before installing remove drivers previously installed. hope this helps
Apr 01, 2010 | HP Compaq Presario v3000z Notebook
PC gets to "Starting Windows.." then suddenly restarts.
you may want to reinstall your operating system i know several people with this issue and it has worked fine just insert the cd of whatever os you choose then boot from it
Dec 24, 2009 | ASUS A8V-VM Motherboard
My account will not load
Yes, many ideas, but all won't help.....
I'v also faced this prob, but in my case the only way was to re-install OS....... I knw it's a bit labourious and time-consuming..... but for u it's the only way......... F8 button configs won't work as it's not ur system prob, it's probably one of ur recently installed softwares which messed ur system up.......
After installation of OS, if u r facing this prob again some time.... I shud reccomend Rollback Rx[jus google it], a superb system restore software installed below OS......
Re-install ur OS, and do the first thing by installing this gr8 thing.......
Jul 05, 2009 | Dell Microsoft Windows XP Home Edition
1801 microcode patch erro
These are very different CPU's, and you should make sure the board accepts the new one. Check the manual.
Oct 26, 2008 | Compaq Evo D500 PC Desktop
Notebook drivers
dear srgunjal.
download the drivers from
www.zyxware.com/articles/2008/04/04/ drivers-for-compaq-presario-c772tu-laptop-for-windows-xp
though the drivers are for c772tu.. but dont worry.. it will work fine for ur model..
PLEASE NOTE:
u may find that the Audio Driver link in the above post is not installing, giving some error...
Dont worry.. install UAA first and then download the fully working audio driver from
http://www.mediafire.com/?9duyqzcxwyh
thats it...
Vote if u find this post is useful..
SUDE
Jul 31, 2008 | Compaq Presario 700 470024-192 Notebook
The installed OS XP'2004 dosent startup!!! PLz Help
hi ,
this is not hardware problem ,this is due to Software corruption .please check your laptop with safe Mode is it working or not .or check it last known best working configuration ....
I think this is Useful for you ....
if not please update me with Full Error code get it you on blue screen....
Jun 07, 2008 | Compaq Evo N610C Notebook
Compaq (252608-001) Motherboard Logo
134 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
