Question about Vizio P2 42 in. HD-Ready Plasma Television
Getting power to a vizio 42 but can get turned on. it is a 2008 model
  • 148 Answers
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this helped you some (or not ), please rate!, thank you.
Posted on Feb 03, 2010
Have Vizio TV, powers on, but blank screen, no backlight
Its probably damaged the board that powers the backlight in the surge. Repairs on this depending on the size of the TV might out way the cost of replacement. I
Dec 05, 2013 | Televison & Video
My Vizio E420VL would not power on.
It is possible you have a faulty main board. The main board is in charge of sending a signal to the power supply to "turn" on the set. So assuming your replacement power supply is a working board, I'd lean towards the main board. I would recommend getting a professional diagnoses to be sure.
Nov 24, 2012 | Vizio E420VL 42 in. HD-Ready LCD TV
Need to know part for vizio gv42lf model for 200/2008 no sound and no picture. I can't remember if they told me main inverter box or main board with part number 3432?
Well you need to do some troubleshooting first. No pictures/No sound can be caused by failed 12v/24v power supply section due to bad caps, or it is not getting the PS_ON signal from the main board, or the inverter boards have shorted circuits that cause the 12v/24v power supply to be in the safety shutdown mode.
Learn more here:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Dec 13, 2010 | Vizio GV42L 42 in. LCD Television
I have a vizio 42 plasma model #vp422hdtv10a when i try to turn on the unit it makes 2 click sound like it is turning on but nothing happen. i open up the unit to look for popped capacitors but i see non...
I am having the same problem with my 42" vizio tv. When plugged in the standby light is on and when turned on the light switches from orange to white, however there is no sound and no picture. I am hoping to find what is wrong with it so i can get it fixed. Or atleast by the correct parts! I have only had my tv about 2 years
Aug 28, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Would power on and off when I would try to turn it
I removed all the screws from the back cover. Upon visual inspection of the power supply board, model # PSPU-J707A, I found electrolytic capacitors C233 and C234 to have bulging tops. Both caps are 10V 3300uf. I'm going to replace them and post the results.
Sep 30, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 42" lcd powers up with sound only - no picture
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on it to the factory if it is still under warranty.
May 28, 2009 | Vizio VU42L 42 in. LCD TV
Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
Mar 11, 2009 | Vizio L32 32 in. LCD HDTV
42 Vizio LCD Tv-
Replace the power supply will fix the problem. Is the Vizio LED light on?
Jan 19, 2009 | Vizio GV42L 42 in. LCD Television
Vizio 42 inch Lcd tv
You need an Vizio authorized TV repair guy to check out the problem for you.
Solutiondoct
Oct 12, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P42 dark haze when turned on
This is an ongoing issue with the Vizio 42" series. The SMPS power supply has been a problem in all the Vizio models since day 1. We repair these sets and I do not recommend them at all, they are very unreliable. The SMPS power unit is board replacement only at this time and very expensive. Joe Weibel Custom Electronics Memphis, TN 38133 (customelectronics.org)
Jan 07, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
582 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
