Question about Frigidaire FEF336BC Electric Kitchen Range
Control blinking and won't turn off - Frigidaire FEF336BC Electric Kitchen Range
  • 1,531 Answers
Unplug the unit for a few minutes will you check the wiring on the back side of the control panel,and make sure there is no problems with wiring terminal that the main supply comes in.
if there is no change after plugging in the unit then you may need to replaced the control board
Posted on Feb 03, 2010
Won't turn on or charge controler
Look at the blinking light count the number of times it blinks and go to google type in ps3 light blinking error code
Apr 13, 2013 | Computers & Internet
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
Tv won't turn on. Blinking in standby in red. Won't start
This is an indication of protection error and might require attention of a qualified service technician.
Aug 17, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Washer Control Locked blinking and won't washer won't work
Water still in the bottom of the drum. Empty, clean filter and check pump is turning. Once pressure switch is satisfied no water is left it'll allow the door to open, assuming the door interlock is still ok.
May 19, 2012 | Washing Machines
Vsonic flat screen monitor need blink codes
hi do you mean you are asking for the blinking codes on your viewsonic pc monitor?. usually lcd monitor for pc has no blinking codes, if your monitor just only a blinking indicator and won't turn on, you must check first the source from your pc if their is a signal to turn on the monitor. if just blinking only then won't turn on you must check the power supply of the monitor usually the main cause is bulging capacitor. just replace it with the same value and rating thanks for consulting the fixya good luck.
Feb 26, 2012 | Computers & Internet
I just purchased my playstation 3. I can't get the Sony dualshock 3 to work. When I plug it in all the lights on the back are blinking but the controller won't to anything
after you plug in the controller, wait till the light under the 1 becomes steady and all other lights stop blinking. once that has happened your controller should be synced with your console. if this does not happen after waiting several minutes, then you have a faulty controller and i suggest to turn it back in. please rate my solution, good or bad.
May 21, 2011 | Sony Dual Shock 3 Controller for...
Where is the turn signal flasher
Your '06 model bike is does not have the old style turn signal flasher unit in it. It has what is known as a turn signal canceling unit. It's a "black box" located somewhere on the bike. I'm not sure of the location on the Super Glide, maybe under the seat or the panel on the left side of the bike. It's a black box about a half inch thick, and inch wide, and about a 3 inches long with a plug on one end with a mounting screw in the middle. This controls the turn signals. If you have the wrong bulbs in the turn signal units, they won't blink or a bulb out on one side that side won't blink. If none blink. I'd trace the ground of the canceling unit to make sure it's got a good ground.
Good Luck
Steve
Apr 24, 2011 | 2006 Harley Davidson FXDCI Dyna Super...
Frigidaire FEF336BC Electric Kitchen Range Logo
57 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
