Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
We the multi-functional mixer attachments but now unable to get shredder to attach correctly
  • 5,603 Answers
Remove the shaft an cutter first and install the outside case of the shredder. Tighten thumb screw. You may have to lift up on a lever that runs in a groove in the shaft to remove the shaft.
Next install the shaft with cutter attached. Lube the shaft with tiny bit of mineral oil or food safe grease. Lift the lever mentioned above and rotate till the shaft seats and then drop the lever and make sure it is engaged.
Posted on Feb 03, 2010
How do I install the shredder?
You need to access the accessory attachment point, it's behind the silver KitchenAid logo on the front of the mixer. You'll need to unscrew a set screw (black knob at the very front of the mixer head), newer mixers have a hinged cover, on older mixers, it just pulls out. Unscrew the set screw a bit and fold up or remove the cover.
Now you will see a hole with a hollow square shaft inside, this is where the various optional items attach to the mixer.
Specifically for the shredder, you will need to attach a slicing drum to the drive shaft provided with the shredder, insert it through the drum, and raise the little bar in the rear of the slicer assembly.
Insert the whole assembly into the front of the mixer so that the square drive shaft shaft fits into the square hollow in the mixer, then lower the little bar to lock into place.
Dec 31, 2015 | KitchenAid kitchen aid"" classic stand"
Do I need to remove the kitchen aid rotor slicer/shredder shaft after each use?
I do, because if you don't, it can rust into place and become very difficult to remove from the attachments. (I'm guessing you mean from the slicer attachment, not the mixer itself, of course it should be removed from the mixer after use)
Nov 24, 2015 | KitchenAid mixer 4176067 attachment shaft
Will kitchen aid attachments such as grinder or shredder work on my cooks sm 248 mixer
contact the manufacturer and see what attachments will work on your machine
If they are not the same brand as your machine , I doubt that they will
Apr 14, 2015 | Food Mixers
I can attach the immersion blender attachment but it does not turn on. The machine works fine with the mini-chopper attachment or the beaters. How can I fix this?
Hi
Make sure you use the pulse function of the power switch. Only this position (forward, away from you) will activate the immersion blender, and then at full speed only.
Feb 09, 2011 | Braun M880 MultiMix Hand Mixer
I a viking professional 1000w mixer - i can't get the attachements to attach to the planetary. someone gave me this, so i'm thinking there is a part missing, although i'm unable to locate anything from...
Contact Viking customer support at vikingrange.com and describe your problem. They can get you the correct part quickly. I looked on their web site for an exploded diagram, but didn't see one. They'll help you with this and I'm sure that the costs associated with repairing your mixer will be minimal.
Best regards, --W/D--
Jan 30, 2011 | Viking VSM700 Stand Mixer
Clicking noice in gears
A clicking noise is not indicative of a major motor issue with a Kitchenaid stand mixer. If the noise worsens or is accompanied with other symptoms, or if you are incredibly concerned with the development of clicking, I would suggest contacting Kitchenaid Customer Service.
Their toll-free telephone number is 1-800-541-6390.
Apr 04, 2009 | KitchenAid KP2671 Professional 6 Series...
I need instructions to use my new kitchen aid attachment
Hi. Basically all you really need to know is to start the machine at a slow speed, begin shredding, increase speed to a point where the machine is not labouring. Next time you use that attachment, set it for that speed. Different attachments and the foods they process load different stresses on the mixer. Always use a speed that is one step above/below the labouring sounds. Kitchenaid doesn't see fit to publish these instructions online as they do their other manuals. Another missed opportunity by Kitchenaid. You might want to check out the kitchenaid forum. one of these people just might have it in digital form. Good luck! ricardok45
If this solution has assisted you, please rate it. ricardok45
Mar 19, 2009 | KitchenAid Food Mixers
Want to appraise my Hamilton Beach Model E 1936 Mixer 15 speeds
e bay is allways a good place to start . but from what i have seen unless its a real "cream puff" 25.00 -50.00 is all your going to get .... you might just keep it right now ..... prices are real low ,people are not buying ANYTHING .........good luck
Jan 14, 2009 | Food Mixers
I bought the slicer and shredder set for the KitchenAid stand mixer, no instructions were in the box. What speed do I use the attachments on?
Your attachment speed will depend on what it is you're slicing or shredding. Begin at speed setting two and work up to the speed where the motor begins to labour, then reduce the speed by one notch. Always start too slow, then move up. If you find this solution usefull, please rate it. Good luck. ricardok45
Dec 05, 2008 | Hobart A200 Stand Mixer
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
88 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
