Question about Monarch 9416 (Part M09416-TT04) Printer
Monarch 9416 Printer Flashers Red when sending the job to the printers
3 Suggested Answers
  • 113 Answers
SOURCE: I have a Monarch Paxar 9416 Printer and can't get
Sounds like you might either be using the wrong size supplies (wrong length compared to the data going to the printer), or you might not have the correct indexing set on the printer. If you choose a blackmark setting for the index (black mark on the back of the liner so that the printer can detect when to stop), but your printer is set to die cut (no black marks on the liner, only spaces between your labels), then the printer can become confused on where to stop. The same goes for the visa versa of these marks.
Lastly, if you are using a ribbon, or are supposed to use a ribbon, you might find that the printer isn't working because of a ribbon fault.
Just in case neither of these help, what software are you using to make the printer print? Maybe I can help further.
Posted on Jun 25, 2010
  • 113 Answers
SOURCE: MONARCH 9416 300DPI PRINTER
Seagull would likely have to provide the real help here, but it sounds like your Seagull drivers are not using the correct supply setting. If the supplies have a black mark on the back of the liner, then set your driver up as black mark. If they ONLY have a small gap between the labels, then set it up as die cut. If it has a die cut and a black mark, set them up as black mark.
It is also possible that your sensor is dirty, damaged, or covered up so that the printer cannot see the supplies. If you're not using Monarch/Paxar/Avery Dennison supplies, then the index mark (die cut or black mark) may not be to the printer's specification and it just doesn't know when to start and stop on a label.
I am using Monarch 9416 , not able to insert ink roll properly
Check out this link to download/view the user/quick reference manual for the 9416 printer. It explains (with diagrams) how to properly load supplies in this printer.
http://www.monarch.averydennison.com/support/Monarch-9416.asp#util
Sep 15, 2011 | Monarch 9416 (Part M09416-TT04) Printer
I don't have the printer drivers. I have lost the original CD and I need to install the printer on another PC
Go to this website and download the driver from Niceware.
http://monarch-printers.com/Download-Area.php
If link does not work copy and past to browser.
Good Luck.
Please rate if it works.
Thanks,
Apr 19, 2011 | Monarch Paxar 9416 Printer
I have a Monarch Paxar 9416 Printer and can't get it to align correctly to print. It comes out 3/4 of the way and errors out. It won't do the last advance to align correctly.
Apr 19, 2010 | Monarch Paxar 9416 Printer
Jul 24, 2009 | Monarch 9416 (Part M09416-TT04) Printer
9403 monarch printer/hooked to lantronix print server
If the printer doesn't react when you send a print job to it (either prints, or displays an error code on the display) and just sits there doing nothing, it generally means the print job didn't get to the printer. Check your communication settings. The printer comm settings must match the settings in your software. The default comm settings on the printer are:
Baud : 9600
word length: 8
stop bits: 1
parity: none
flow control: dtr
Apr 27, 2009 | Monarch 9403 Thermal Label Printer
My Monarch 9416 203 DPI prints offline
You did not say whether this printer is the same as your others, if it is not then you will have to get the correct software driver for this particular printer.
Jan 08, 2009 | Monarch 9416 (Part M09416-TT04) Printer
Just print one and stop working monarch 9416
Isolate : disconnect from the computer, turn it off - press and hold the paper feed button while turning it on releasing only once the unit starts printing.
if it passes without error, replace the cable or try another port if it's USB.
Nov 20, 2008 | Monarch 9416 (Part M09416-TT04) Printer
Nothing is printed out (paper rolls, but nothing on it!!
plz try by reinstalling the drivers then check the ink status
Jul 03, 2008 | Monarch 9416 (Part M09416-TT04) Printer
Nothing printed on the paper
plz try by reinstalling the drives for the printer, check the ink status
Monarch 9416 (Part M09416-TT04) Printer Logo
47 people viewed this question
Top Monarch Office Equipment & Supplies Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
David Payne
David Payne
ka4iup
ka4iup
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
