Heat pump makes a lot of noise at start-up a slow start kit dident help, and a compressor blanket helped some..this is a new unit..where is the quiet and so on the sales paper said it would or the no hassle warenty? all I seam to get are excusses...I seen others work just fine..
  • 149 Answers
IS, UNIT NEAR WINDOW I ALWAYS POSITION THEM AWAY FROM LIVING SPACES. THE PROPER LOCATION IS JUST AS IMPORTANT AS INSTALLATION SOME THINGS INSTALLERS DONT PAY MUCH ATTENTION TO WITH TODAYS SCROLL- SCREW COMPRESSORS NOISE CAN BE A PROBLEM A GOOD INSTALLER WOULD TAKE CARE OF THIS AT NO COST TO HOMEOWNER, THE CHEAPEST PRICE ISNT ALWAYS THE BEST CHOICE.
Posted on Feb 03, 2010
3 ton heat pump with piston in air handler. After unit shuts down it makes loud fluid flow noise for about 2 minutes
adding a tvx will not help. the sound you here is the pressure equalizing and that has got to happen for the compressor to start again the next time. A tvx will give you a higher efficiency because it can adjust to changing temperature conditions. Only way i know to quiet the noise is to try to insulate the lines better.
Sep 14, 2014 | Goodman GSH130301 Heat Pump, 3 Ton, 13...
New Ruud 16 seer central air and heat pump - very noisy
A few things to check
1) Is the unit mounted on metal brackets attatched to
the house, is so I would probably put rubber pads
between the unit and the brackets to absorb the
vibration.
2) Same is tru if sitting on a concrete or plastic pad.
3) Some units come with the compressor that has
an insulated jacket around it, this is also for noise
reduction.
4) The fact that you replaced an older unit with a newer one could also mean that you have a bigger blower.
5) Which leads to the unit not performing because
it may have not been set up properly.
6) Take the door off the unit, make sure power is turned off. Usually on the left hand side of the indoor
unit it will list the temperature rise that this unit
requires. I`m guessing between 25-45 deg.
7) This is the temp. difference you would measure
on the return air near the furnace. Then Take a
temp. measurement in the Supply duct near the
indoor unit.
8) If its not within the range the furnace requires,
he needs to come back and adjust the fan speed
Jan 09, 2010 | Ruud Matching Split Air Conditioner
Goodman Model # GPG15709041AA Gas pack just
depending on the brand and if he had to recharge and pulled oil oiut of compressor it can cause comp to be load. goodman is also a lower end unit and you pay for what you get. it is a very reliable unit howvere
Aug 17, 2009 | Goodman CKL60AR60 Air Conditioner
Fan started making noise
I have one of these, and every so often, the fan would start making a loud clicking noise. I discovered that if I shut the fridge off for a while and left the door open to defrost it, it'd work fine again for a while before the noise came back. Apparently, some ice was building up between the metal heat-sink and the fan, causing the fan blades to scrape against the ice/frost build-up and make the "tick, tick tick" noise.
There is no compressor in the Avanti EC15W-2 mini fridge. It uses a simple Peltier junction device to transfer heat from the inside of the fridge to the outside/rear of the unit. So it should never get very loud at all, unless one of the two fans in it is acting up in some way.
Aug 15, 2009 | Avanti EC15W-2 Compact Refrigerator
My new Kenmore window unit 76081 makes loud rattle
If it does not make the noise when the fan is ruunin you may ahve abroken sping in the compressor. Make sure you Window unit is level. If not the compressor will knock on the inside. Rusty
Jun 12, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Loud noise
It is probably a rotary compressor unit.
They tend to make a start up noise.
Some technicians advocate adding a booster starting device to help the compressor start more quickly, thereby reducing startup noise.
Mar 12, 2009 | Heating & Cooling
Noisey compressor
Does it make the noise all of the time or just periodically? Does the outdoor fan run when it is making the noise. If the fan isn't running and the compressor is noisy at that time likely it is in defrost mode which is normal.
Jan 17, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman Heat Pump GSH 130601 5 ton unit - Compressor seized
Tell them you want a whole new outside system or a new compressor . Around here, the compressor change out should be around 5--$800.00 and the unit change out , around $400.00! OKLAHOMA.
Aug 02, 2008 | Goodman CLQ36AR49 Air Conditioner
Promlems with a new air conditioning
hello my name is david lets see if i can help first of all the cheapest way to go would be to buy some rubber pads to place under the unit if that doesnt help they sell air conditioners with a blanket around the compressor to reduce the noise they are a little more expensive but worth it thanks for letting me help you
Jun 14, 2008 | Hyundai Electronics (880065000081) Air...
Goodman Condenser - Heat - Buzzing Noise every 60 seconds
It could be your compressor trying to start but not being able to do so. It shouldnt happen that often but in cold temp the overload protector may cycle that quickly. I reccomemnd to have it checked to salvage the expensive compressor.
Dec 24, 2007 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
