Question about Intuit QuickBooks Simple Start Edition (283063) for PC
Trying to install Quickbooks Simple Start 2010 on a PC with Windows XP Home Edition, but it will not install because it keeps asking for Flash Player Active X version 8. I have version 10 (the latest iteration). Must I uninstall version 10 and load version 8 in order for Quickbooks to install, or is there another way out of that? Thank you for any help. try{for(var lastpass_iter=0; lastpass_iter < document.forms.length; lastpass_iter++){ var lastpass_f = document.forms[lastpass_iter]; if(typeof(lastpass_f.lpsubmitorig2)=="undefined"){ lastpass_f.lpsubmitorig2 = lastpass_f.submit; lastpass_f.submit = function(){ var form=this; var customEvent = document.createEvent("Event"); customEvent.initEvent("lpCustomEvent", true, true); var d = document.getElementById("hiddenlpsubmitdiv"); for(var i = 0; i < document.forms.length; i++){ if(document.forms[i]==form){ d.innerText=i; } } d.dispatchEvent(customEvent); form.lpsubmitorig2(); } } }}catch(e){}
  • Dawn Scranton CQA
    Dawn Scranton CQA May 11, 2010
    When you try to install QB SS 2010, during installation, it should ask: "Do you want to search/download recent updates?" (or somthing very similiar) - are you saying "yes" to this request? No, you shouldn't have to install 8 (if you have 10) Do you have a more specific error message (error # or ??) Intuit's support site, can be helpful if you type in the specific error.. If you provide more details, I will try to help. or you can visit:http://support.quickbooks.intuit.com/Sup...
  • 60 Answers
Simple Start will not install in you have another version of quickbooks. Unistall any quickbooks version.
www.cpahispano.com
Posted on Aug 08, 2010
Need quickbooks simple start 2010 download
You can downloaded an Updated version on your new Window 7 PC and then back up our previous files and importing them into the new QuickBooks program. For QuickBooks Download follow http://support.quickbooks.intuit.com/support/Static/INF12417.html and read installation help below before. If need help during in any technical solution follow Intuit Tech Support .
Apr 22, 2014 | Intuit QuickBooks Simple Start Edition...
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
How do I get Quickbooks Simple Start 2010 to run on Windows 8?
Unfortunately the old quickbooks simple start 2010 is not desinged for windows 8 operating system,
What you can do is to upgrade to new quickbooks pro 2013 for only $199.96 before tax, or you can have it much cheaper for if you will look to retail store such as costco, techsoup, office depot etc.
Thanks,
She Morillo
Jan 09, 2013 | Intuit QuickBooks Simple Start 2010
I can't reinstall my Pro 2005 because it asks for Flash 7 then the cd tells me it can't install it.
You're several versions behind with your QB Pro, and also several versions behind with the Flash Player you're trying to install.
If you're reinstalling because you upgraded your operating system version, this is likely the root cause. QB 2005 is not compatible with Windows 7; neither is Flash 7.
While you may be able to install the program using XP Mode, that isn't the most reliable way of running it. I recommend avoiding uninstalling the .net framework files and "back versioning" as a way of getting around it, because it is likely to cause problems with other functions.
You may be best off to upgrade your Quickbooks version.
Hope that's helpful.
Jan 16, 2011 | Intuit QuickBooks: Pro 2005 for PC
How do I retrieve my Flash Macromedia for Windows XP 2000 edition
Go to http://www.brothersoft.com/macromedia-flash-player-download-43144.html and Select any server and click on Click to download and save it to your desktop and run it. now you can see the websites without any issues.. if not jst restart your pc and check ok
Jan 20, 2010 | Microsoft Windows XP Home Edition
I am trying to down load macromedis flash player I do not have a code it keeps giving me a message = cd 60059 How can I download flash player?
you can down load Adobe flash player here:
http://get.adobe.com/flashplayer/
that should get you going again..
Thank you for the chance to help..
Randy
FixYa Support Team
Oct 06, 2009 | Microsoft Windows XP Home Edition
Problem in installing quickbook 2005 pro
you were suppose swicth off your pc after dowloading your flash player 7.
Jun 10, 2008 | Intuit QuickBooks: Pro 2005 for PC
Quickbooks 2005 Error 1603
Explore the QuickBooks 2005 CD, go into the QuickBooks folder and double click quickbooks.msi - this will install QuickBooks without checking for the old/outdated Flash Player 7.
Sep 30, 2007 | Intuit QuickBooks: Pro 2005 for PC
Open Questions:
Intuit QuickBooks Simple Start Edition (283063) for PC Logo
509 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
